2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions F22 coding cheat sheet
      01-07-2018, 05:27 PM   #1915
JumpY
Drives: BMW
Nice Work! Thanks
      01-12-2018, 01:09 AM   #1916
ZPrime
I INDIC8
ZPrime's Avatar
Drives: 2018 LBB M2, 6MT
2018 BMW M2  [9.50]
First, I can confirm that:
FEM_BODY / 3060 / PARKLICHT_MOEGLICH
works on a NAR/US-spec car. I believe it starts at "nicht_aktiv", you'd change it to "aktiv" to enable it. (Anybody outside of North America should already be aktiv.) "Parklight Possible" is the translation.
This gives you the European "parking light" mode - put turn signal stalk to left or right when car is off, and the angel eyes and rear parking light / dimmed brake light turns on, only on that side of the car. It bongs at you once or twice to remind you that you have it on, and you'll get a message in the BC display about it.
I can also (sadly) state that FEM_BODY / 3060 / Blinkzyklen_anzahl_tip does not work on my 2018 LCI car. Might be worth noting this in the cheat sheet somehow - apparently later code versions on the car won't obey this. I can set (via iDrive) either 1 blink or 3, and that's it. Coding "werte=4" (I want 5 blinks) doesn't seem to do anything, even after power-cycling the car (acc-off, wait a while, then acc-on again).
Now that I've helped, I have several random questions...
Comfort closing / opening - if I set the mirrors to fold with this, is there any way to not activate the windows but still fold the mirrors? E.g. I want to leave windows cracked in summer for ventilation, but I want to fold the mirrors... presumably I can't do both (since holding the lock button will close the windows while folding the mirrors?) I don't want to fold the mirrors all the time either, since I don't want them trying to fold in the winter (when there could be ice build-up on the bases and I don't want to damage a motor due to that). Just trying to wrap my head around how the window-closing interacts with the mirror folding. Is it even possible to fold the mirrors via comfort access, or do you need to use the remote to make them fold (and comfort access can only close windows)?
Rain closing - this is confirmed 100% to not work? Had this on my 2008 Volkswagen and it saved my interior a couple times in summer...
ASD disabling -- is it confirmed that F006 is the best value to code (into ASD/3000/Model Range) to totally disable ASD? I read elsewhere that people had tried setting "Model Range" to F20 or F21 but that apparently doesn't fully kill it. The cheat sheet implies that HU_NBT/3000/ASD_SOUND_OFF doesn't work - is that 100% confirmed?
VLD re-enabling -- is it just the two values in the cheat sheet? (FEM_BODY / 3073 / C_AFS_ENA -> 01 / enabled && LUT_FLC_FORWARDLIGHTING_Y -> 9C, 9C, 9C) My car (US-spec 2018/LCI M2) has the camera and auto-highbeam function, but from what I've read, enabling the European high-beam-assist (HBA) portion can cause glare since we haven't yet confirmed if the LCI LED headlights can "window" correctly in high/"main" beam mode. Is it confirmed that VLD on its own (without coding HBA) is safe / glare-free to other drivers? Will the NA-region auto-highbeam feature continue to work "as normal" if I enable VLD but do nothing else?
2004 Matrix XRS 6MT => 2008 VW R32 DSG => 2012 Audi TTRS 6MT => 2018 BMW ///M2 6MT
I'm an IT guy by trade and tech nerd by choice.
I like HPDEs, parts of US Hwy 129, NC 28, and the Cherohala Skyway.
I'm also a fan of aural pleasure.
      01-12-2018, 01:14 AM   #1917
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Comfort closing / opening - if I set the mirrors to fold with this, is there any way to not activate the windows but still fold the mirrors? E.g. I want to leave windows cracked in summer for ventilation, but I want to fold the mirrors... presumably I can't do both (since holding the lock button / handle ridge will close the windows while folding the mirrors?) I don't want to fold the mirrors all the time either, since I don't want them trying to fold in the winter (when there could be ice build-up on the bases and I don't want to damage a motor due to that). Just trying to wrap my head around how the window-closing interacts with the mirror folding.
You can keep or increase delay so that mirrors do not always fold. Mirrors are all or nothing, but windows only continue to move while pressure is maintained.
For any of the newer firmwares, setting anything other than expected disabled.
VLD can be VO coded as well as manually FDL-coded or use Cheat Codes. VLD will not affect HBA.
ZPrime611.50
      01-21-2018, 10:03 AM   #1918
mrfattbill
Drives: 2016 EB M235i xDrive
Car went in for service and came back needing to be partially recoded, however there seems to be an issue:
I am missing 2 files, I-level F020-17-11-540 I need two cafd files:
cafd_0000067b.caf.002_015_001
cafd_000009c8.caf.006_004_101
Can anyone help.
Thanks
Bill
      01-21-2018, 10:52 AM   #1919
Almaretto
Almaretto's Avatar
2374
Can anyone help.
Thanks
Bill
Here. Download secondary 3mb archive, which comes from ISTA+.
      01-22-2018, 08:15 AM   #1920
mrfattbill
Thank you very much Do I just put the two I need into the "Data\CAF" folder or is there something more involved.
Thanks again for the help.
Bill
      01-22-2018, 12:06 PM   #1921
Almaretto
Almaretto's Avatar
2374
Bill
C:\data\psdzdata\swe\CAFD
      01-22-2018, 05:47 PM   #1922
mrfattbill
Almaretto,
Just wanted to stop in and thank you again, I was able to get everything back to the way I wanted with the addition of those files as well as some other posts of yours I found while searching.
Bill
Almaretto2374.00
      01-22-2018, 06:04 PM   #1923
Almaretto
Almaretto's Avatar
2374
Almaretto,
Bill
      01-23-2018, 01:11 AM   #1924
ZPrime
I INDIC8
ZPrime's Avatar
2018 BMW M2  [9.50]
Is there any way to configure a maximum startup volume for HU_NBT2? Prevent the music from being super-loud on startup if I was listening to something loud when I shut it off?
Additionally, is it possible to set an individual "gain" for each "input" on the HU, or have the car use a different (separate) volume level for each input? It's super irritating to go from Sirius to USB or Bluetooth and have to turn the volume way up on the latter two... and then if I go back to Sirius, the volume is extremely loud (because Sirius is broadcast at a higher level) and I have to rush to turn it back down.
      01-23-2018, 01:12 AM   #1925
Almaretto
Almaretto's Avatar
2374
Is there any way to configure a maximum startup volume for HU_NBT? Prevent the music from being super-loud on startup if I was listening to something loud when I shut it off?
You can code max start volume (search VOL_MAX_ON in HU). But, never seen any coding to adjust different inputs.
ZPrime611.50
      01-23-2018, 02:17 AM   #1926
ZPrime
I INDIC8
ZPrime's Avatar
2018 BMW M2  [9.50]
One is better than none.
I appreciate all the help Almaretto
Almaretto2374.00
      01-23-2018, 01:43 PM   #1927
bmw_fascinated
bmw_fascinated's Avatar
15
Drives: F22 228i
Check FEM_BODY: RLS_DEF_FLC_SCHWELLWERT_SATZ
Supposed to be for rain light sensor and headlamp.
Is there a chance to set the sensitivity for the rain sensor (could be more sensitive) and the sensitivity for the automatic headlights (could be less sensitive) separately?
      01-23-2018, 01:48 PM   #1928
Almaretto
Almaretto's Avatar
2374
You can change frequency. But, there is only one FDL for sensitivity.
      01-25-2018, 10:58 PM   #1929
ZPrime
I INDIC8
ZPrime's Avatar
2018 BMW M2  [9.50]
Anybody having a hard time getting an answer from Tokenmaster about the Pro version?
I e-mailed a few days ago, never got an answer... sent the info he requested a couple days later and still nothing.
For some reason my old installation of Launcher stopped working after I updated PSdZdata (Launcher keeps wanting to generate a new token and repeatedly asks me for a PIN and never seems to work)... so I figured I should move to the latest version, and then I discovered it's Pro-only now.
      01-26-2018, 02:53 AM   #1930
Almaretto
Almaretto's Avatar
2374
If you do not hear anything after a week, PM shawnsheridan the email used to contact TM.
All Premium launchers stopped working 12/31/17; it has nothing to do with changing PSdZ.
EDIT: Premium Launcher 2.8 was released with June 2018 expiration.
ZPrime611.50
      01-27-2018, 05:31 PM   #1931
Rommel42
Drives: M235i 2016
Good to know,was not aware of the expiration date.
Almaretto,can you please guide me to 2.8 launcher link?
      01-27-2018, 05:57 PM   #1932
Almaretto
Almaretto's Avatar
2374
Links never change:
      02-05-2018, 03:12 PM   #1933
Rommel42
Drives: M235i 2016
I never updated my Launcher 2.53.Just found out recently that one needs version 2.8 to do any coding at all.My question is,do I have to totally uninstall the old version before installing v 2.8.
Thanks for any help Almaretto.
      02-05-2018, 04:53 PM   #1934
Almaretto
Almaretto's Avatar
2374
E-sys, if updating, should be first uninstalled. Launcher can just be updated.
      02-05-2018, 09:51 PM   #1935
Icy J
im a car
Icy J's Avatar
Hong Kong
736
Drives: 220i M Sport | 520i M Sport
2014 BMW 220i  [10.00]
Is it possible to code oil temperature to be displayed on the dashboard without having to access the hidden menu on a pre-LCI non-extended cluster?
'14 220i M Sport | AW/CR | PUR Wheels RS07 19" | KW V1 | MTC Design F2X Kit [CF] | Stage 1 ECU Tune | Eventuri CF Intake | Manhart Race Exhaust/Resonator Delete | ER HFC Downpipe | F8X LCA + TS | M Style Grilles | Gloss Black Roof | Custom Steering Wheel | Autotecknic Competition Shift Paddles [YMB]
Instagram: @icyj95 | FB
      02-05-2018, 11:07 PM   #1936
Almaretto
Almaretto's Avatar
2374
No.
