08-22-2015, 05:29 AM | #1 |
Rep 17
avg_ign
I've searched for most of these questions, and cannot find clear information for all or most. Any help will definitely be appreciated by me, and I'm sure whoever stumbles upon this as well. I have got m235i i had increased the bust level by using map 7. i am loving the performance of the car now. but the avg_ign Increased from 3.9 ( in maps 1 and 2 ) to 6.4 - 8.6 you can see it below what does it meens ? is it safe to drive ? map 7 gear rpm boost avg_ign 3 3180 17.3 7.2 4 5409 14.6 8.6 5 5471 17.6 8.6 6 5289 18.7 6.4 -- |
08-22-2015, 08:54 AM | #2 |
What goes here?
450
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
Wow, that's terrible. That number should be 1.5 or less. You are running the risk of serious damage by using any of the maps that have you over that.
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
08-22-2015, 12:14 PM | #4 |
Rep 1,503
OP, please get off of Map 7, you could be on your way to making permanent damage and your ign avg is showing that something is off. You cannot nonchalantly just put your car into Map7 without seeing how your car reacts in more conservative maps. Map 7 is the most aggressive map there is on the JB4 and will require very high octane fuel (96AKI or higher).
I've seen the things you've posted on N54tech, and honestly I think the language barrier will be a big issue. I would stick with a plug and play solution since it doesn't look like you have a dp.
FBO M235i r
F80 M3 Last edited by ocN55; 08-22-2015 at 02:10 PM.. |
08-22-2015, 01:31 PM | #5 |
Rep 528
Way too aggressive! Always have someone review your logs if your unsure of any of the value meanings before changing maps or upping boost. What someone mentioned above Map 7 must be run on a higher octane gas.
08-27-2015, 04:23 AM | #6 |
Rep 2,357
ign_avg of max 5 on pump gas is considered healthy.
Please use map 1 until you get a downpipe. You can try map 2 or 5 if you have downpipe and run premium gas.
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
08-31-2015, 11:41 AM | #7 |
Rep 190,777
I agree with everyone on this issue, you are running a way to aggressive map for your mods and risking to damage your engine.
Please go back to map 1 or map 5.
