A little more Pop and Growl: Exhaust amplifying questions |
08-20-2015, 09:17 AM | #1 |
Rep 98
Hi all,
I have been considering grabbing this OBDII Can Flap module from Burger (http://www.burgertuning.com/f_series...odule_BMW.html). I would use this primarily to open both valves while in comfort mode to get a bit more sound. Does anyone have experience with this item? It appears to be a totally passive system and doesn't risk hurting the car, but I am pretty neurotic so I'm interested to poll the community. (Yes, I know it's expensive, but let's assume that doesn't bother me for the moment). Any thoughts are welcome! Last edited by beenthere1; 08-20-2015 at 09:29 AM.. |
08-20-2015, 09:37 AM | #2 |
Rep 5,103
Would this accomplish the same thing, for free?
http://www.2addicts.com/forums/showthread.php?t=995453
08-20-2015, 09:41 AM | #3 | |
Rep 98
08-20-2015, 09:43 AM | #4 |
What goes here?
450
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
Not to pay devils advocate because you seem to be willing to pay for it.. but it is not nearly as involved as you might think. The connector is easily accessible by reaching behind the rear driver side wheel, all that is required is that you get on one knee and peer under, no jacking of the car required. I would want to keep my OBD2 port handy for other things.
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
08-20-2015, 09:53 AM | #5 | |
Rep 98
08-20-2015, 09:55 AM | #6 |
What goes here?
450
Rep 1,356
I personally did not do the mod but I have replaced the exhaust on my car three times so I know just how easy it is to get to. I suppose you could zip tie it to one of the exhaust supports back there out of the way or, if you wanted to maybe put it on kind of a bungee cord so that you can pull it down and connect it/disconnect it whenever you want to do the mod but not having it dangling when it's not plugged in.
2019 G30 M550i
08-20-2015, 09:58 AM | #7 |
Rep 40
08-20-2015, 10:05 AM | #8 | ||
Rep 166
08-20-2015, 10:39 AM | #9 |
Rep 893
Also look into the cg precision valve controller. The advantage over the canflap is it does not take up your obd port.
2019 SG M5C
08-20-2015, 12:09 PM | #10 |
Rep 1,334
I can confirm that it will leave a shadow code when you remove the sensor so if you're ok with that I would go ahead and do it. It somewhat of a negligible code so most dealerships will ignore it.
08-20-2015, 01:23 PM | #11 | |
Rep 98
If I don't like it, does it matter whether the valve is open or closed when I plug it back in?! |
08-20-2015, 06:20 PM | #12 |
Rep 887
Drives: Enzo F23 228i
no
08-21-2015, 08:06 AM | #13 |
Rep 98
08-21-2015, 08:18 AM | #14 |
Rep 98
08-21-2015, 01:44 PM | #15 |
Rep 1,334
no, only way to delete it is at dealership, BT cable, JB's OBD CAN Moduke, or if you have a JB4 that auto-deletes.
X3 M40i G01, M235i F22, 335 F30 MSport, 135 DCT, 335 E92, Audi A3
