08-27-2015, 06:04 AM | #90 |
7485
Rep 12,307
That's actually not 100% the case. The N55 that'll go in the M2 and indeed the X4 MPA is supposed to have S55 hardware. So it won't just be a simple tune with overboost function
08-27-2015, 06:08 AM | #91 | |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
Plus look at the N54 in a 335, 335is vs the 1m. Not much differed in terms of end result tuning. But different engines different era. Gotta wait n see
FBO-PS1 and stuff
08-27-2015, 04:46 PM | #93 |
Rep 275
08-27-2015, 06:57 PM | #94 | ||
Rep 4,323
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
08-27-2015, 09:12 PM | #95 |
Rep 12
08-27-2015, 10:37 PM | #96 | |
Rep 4,323
My impression is that parameters set by BMW like throttle response and steering, etc, aren't altered (ie PPK). Boost/AF ratios by load and rpm/CEL deletes are parameters that would be altered. It's an engine tune like we're used to...
08-27-2015, 10:38 PM | #97 |
Rep 1,192
Drives: 2011 335i MT
Have you had a custom tune, such as PTF or Wedge? I had a JB4 I got the PTF and the PTF tune took it to a whole new level. Plus, I can easily remove it when I take it to the dealer.
PTF Map, Pure Turbo Stage 1, GFB DV+, Mfactory LSD, AA FMIC, B12 Pro Kit, M3 FCA, AR DP and
Dynavin N6, Mosconi AS100.4, AS100.4, AS200.2, Micro Precision tweeters & woofers, Esotar2 1200 |
08-27-2015, 10:56 PM | #98 | |
Rep 893
2019 SG M5C
08-28-2015, 12:46 AM | #99 | |
Rep 12
08-28-2015, 08:29 AM | #100 |
Rep 275
Once we read the ECU we change the parameters accordingly. The new file gets uploaded with all the necessary changes. Our tune does not sit on the existing but replaces the factory file with an updated one.
08-28-2015, 10:24 AM | #101 | |
Rep 1,192
If you get a tune, I highly recommend the GFB DV+ diverter valve as it helps hold boost better than the stock diverter valve. Not very difficult to install.
08-28-2015, 11:51 AM | #102 | ||
Rep 893
2019 SG M5C
08-28-2015, 03:28 PM | #103 |
Rep 275
Hello Everyone,
We are finalizing Group Buy details for the N55/N20/N26 engines. We will be posting early next week with further instructions. Cheers, Enzo Performance Team |
08-28-2015, 04:43 PM | #104 |
Gettin It Figured Out
1820
Rep 2,669
Nice! Yours is a GSR/PureTurbo BEAST!!
08-28-2015, 04:53 PM | #105 | |
1820
Rep 2,669
08-29-2015, 12:45 PM | #107 | |
Rep 137
check this out http://www.2addicts.com/forums/showthread.php?t=1127263 Last edited by Jasond13; 08-29-2015 at 01:24 PM.. |
08-30-2015, 03:32 PM | #108 |
Rep 846
08-31-2015, 04:43 PM | #110 |
Rep 354
Drives: 2017 F80 ZCP MW/SO
Just talked to Chris @ Enzo!
Excited will see you guys soon! |
