2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning RaceChip Ultimate discussion thread
      02-15-2015, 03:49 PM   #1
AlexGT
AlexGT's Avatar
Guatemala
420
Drives: G05 X5 MSport
Fellow M235i owners, I'm taking the liberty to start this thread that could include all RaceChip Ultimate tuning piggy back related information, installation, results, problems, questions, etc..
I'm starting this first post by sharing with you that I've just unboxed my unit and that I'm currently in the process of installing it. I was reading the instructions and did a research in RaceChip's youtube channel to be sure how to install it due to the fact thar this is the first time that I'm installing this type of item to one of my cars.
Call me ignorant ('cause I am on this) but I've just bumped to my first doubt, the installation instructions talk about ONE connector, the MAP, and that's it, but my cabling has TWO connectors (see the attached pic I took), so for you that have installed JB4 and other piggy backs to our cars, any pointers? How do I know which one goes where?
Thanks, so I can finish the installation today and make some tests!
EDITED (after installation with RaceChip's factory settings):
Originally Posted by AlexGT View Post
My FIRST impressions:
1.- Acceleration definitely feels better
2.- I have 8speed auto, hard acceleration in manual mode is scarily aggressive!
3.- I think this box frees the gearbox because in manual mode if I don't shift, the car no longer autoshifts when reaching above the red line. I will need to be careful from now on when in manual.
4.- I have been using ScanGauge II since December, in full acceleration, the higher number I've got in the HP gauge was 332hp (of course, crank HP), tonight I got 390HP in my best run (RaceChip website claims increase to 379HP). Sadly no GoPro to record a video but I have a picture (just one decent with one hand on the iphone) while I was doing these runs and you can see that the number at that moment was 369HP and I wasn't finished reaching to the max rpms
Thanks chaddy74 and Delnari for helping me out to find out where the two connectors had to be placed!
Installation was plug and play, no CEL / ECU errors at all. I think I found a nice location for the box too
I will try to keep the updates going, hope to go to the dyno soon to see about WHP rather than just crank HP.
Delnari's contribution about RaceChip compared with JB4:
Originally Posted by Delnari View Post
Yes, the JB4 will give more tuning options and allow for custom tuning as you swap out factory parts for higher performance ones. What the Racechip, BMS Stage 1, and aFe Scorcher offer is a quick connect/disconnect using just 2 sensors. Make those who worry about dealer warranty the ability to remove quickly when they take their cars in for factory service. These piggyback systems are more plug-n-play and forget with nice performance gains.
      02-15-2015, 04:44 PM   #2
Delnari
Delnari's Avatar
Drives: 2014 MG F22 Auto
The device should connect up the same way in which the BMS and aFe unit does. You just need to look at the connector plug ends on the car for the TMAP and MAP sensors. Look at the different pinouts for both plugs and match up accordingly. This video install will help:
      02-15-2015, 05:14 PM   #3
configt
configt's Avatar
150
Drives: 2015 EB M235i
Subscribing to this thread. Looking forward to hearing your experience with the unit.
      02-15-2015, 05:49 PM   #4
chaddy74
chaddy74's Avatar
Australia
231
Drives: M135i
I would think #1 is the first image and #2 the second image
      02-15-2015, 05:56 PM   #5
AlexGT
AlexGT's Avatar
Guatemala
420
Thanks guys, I will give it a try and let you know! so excited my friends!!!
      02-15-2015, 07:05 PM   #6
chaddy74
chaddy74's Avatar
Australia
231
Drives: M135i
I reckon its a 10min install tops !! Good luck , I take it your factory settings on the Racechip are B1 ?
      02-15-2015, 07:49 PM   #7
horsepower_and_hounds
Drives: BMW
I didn't find any dyno result graphs on their site
      02-15-2015, 07:53 PM   #8
chaddy74
chaddy74's Avatar
Australia
231
Drives: M135i
I did !! But watch this space !! sure it will happen very soon
      02-15-2015, 07:59 PM   #9
Drives: BMW
I looked again and found them.....
      02-15-2015, 08:08 PM   #10
AlexGT
AlexGT's Avatar
Guatemala
420
Here's one ehagerty
      02-15-2015, 08:08 PM   #11
chaddy74
chaddy74's Avatar
Australia
231
Drives: M135i
My only concern with the graph is that the scale of the RPM looks rather dodgy !! 4000 max power ??? look closely !! I was like Hmmmmm..... could just be a misprint
      02-15-2015, 08:15 PM   #12
AlexGT
AlexGT's Avatar
Guatemala
420
Yes chaddy, it came at B1. I left it that way
      02-15-2015, 08:18 PM   #13
chaddy74
chaddy74's Avatar
Australia
231
Drives: M135i
Look closely at this graph !! Something weird going on
Here's one ehagerty
      02-15-2015, 08:21 PM   #14
chaddy74
chaddy74's Avatar
Australia
231
Drives: M135i
Thanks ...Yes this is the default setting ! In the manual it will give you a stage 2 setting ... whats that number ?
      02-15-2015, 09:03 PM   #15
AlexGT
AlexGT's Avatar
Guatemala
420
I don't see stage 2 config in the manual chaddy actually the manual is very very general, not specific for the M235i, that's why I was so confused that the instructions where for one connector only while my harness had two.
The two pics you sent me saved my day btw, THANKS!!!!
      02-15-2015, 09:08 PM   #16
chaddy74
chaddy74's Avatar
Australia
231
Drives: M135i
No Worries mate !! Im sure there is a page ... think its page 9 of the install manual that mentions configurations, I will check it out when I get home from work and post the stage 2 configurations
      02-15-2015, 09:33 PM   #17
AlexGT
AlexGT's Avatar
Guatemala
420
Yes please, share that info! Cheers!
      02-15-2015, 10:08 PM   #18
AlexGT
AlexGT's Avatar
Guatemala
420
      02-15-2015, 10:31 PM   #19
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
Congratulations AlexGT
Thank you for helping Delnari chaddy74 you guys are amongst the best on this forum. Reminds me a lot of opasha and TShoot
I was a bit late to responding to Alex's PM but you guys saved him
TShoot installed it on his 535 (n55 too) a few weeks ago http://f10.5post.com/forums/showthread.php?t=1068292
And pdawg on his F15 35i http://f15.bimmerpost.com/forums/sho....php?t=1077731
I know variations of the N55 might have a little difference of where the plugs are but I know it is much easier 2 sensors vs 3 sensors (N20) on mine.
Alex again hope you enjoy it, drive it in all modes, notice your MPG will improve and post some pictures of your installation and where you will have it stored by.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      02-15-2015, 10:46 PM   #20
configt
configt's Avatar
150
Thanks for the info AlexGT Can you show where you put the box?
Also what octane are you running?
Thanks!
      02-16-2015, 12:11 AM   #21
chaddy74
chaddy74's Avatar
Australia
231
Drives: M135i
Mate my recommendation as per the stage 2 Performance settings are E-2 for the M235i !! Give that a go and watch what happens !! I cannot see this setting throwing any codes either So its safe to go there !!
      02-16-2015, 07:00 AM   #22
alz0rz
What goes here?
alz0rz's Avatar
450
Drives: 2019 G30 M550i
The "horsepower" number you get with scangauge or any other obd2 app are completely bogus.
2019 G30 M550i
GBNF:
2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i
