07-11-2014, 12:04 AM | #45 | |
Rep 2,337
07-11-2014, 11:10 AM | #46 | |
Rep 926
m |
07-11-2014, 11:55 AM | #47 |
Rep 2,337
It's just a rough idea as the tune and other accessories are not available yet, but a Stg 2/3 flash should be $2k or more, an oil cooler might also be required at $1.5k, along with a FMIC at $1k and a free-flow exhaust for another $1k. That's $5,500-6,000 in parts alone, plus installation costs at a Dinan authorized location, which isn't cheap in itself. All in all, you're walking away with $8k in parts in labor.
07-11-2014, 12:39 PM | #48 | |
Rep 926
even if you have money to dump, its just plain stupid imo to go that route. |
07-11-2014, 01:12 PM | #49 |
Rep 246
2 1/2 pages of garbage fellas.........can we avoid the thread jacks please!!!!
M235i (Black) Auto, JB 4 (Stage 2 / Map 7 with EWG & FF wires) ER DP, resonator delete, running E35, BMW Performance LSD, Hankook Ventus R-S3's (255/35/18 & 235/40/18) ATE Super Blue Racing brake fluid, 35% tint, black grills!
07-11-2014, 01:37 PM | #50 |
Rep 1,040
Dinan Software Upgrades are taking a slightly different path as you may have noticed on their site lately. They are now using a programmable module that that plugs inline with the ECU. Similiar to the Piggyback systems with the main difference being all the ECU subsystems can be reprogrammed without ever touching the main ECU code. This is very similiar to other devices on the market like the COBB AccessTuner, but with the main difference being the Dinan tuner has no customer interface and must be programmed by Dinan directly. COBB stopped making tuners for the newer BMW do mostly to the lockdown of the BMW ECU and not worth the engineering cost to develop a box such as Dinan's device.
By using an auxillary device for the ECU reprogramming the DME can be copied (flashed) to the auxillary device and changes made there. My hope is you can use the purchased tuner on your next BMW and save a little money by having it updated with the new model information. Haven't checked, but you might simply just need to disconnect the device to return back to stock programming. How new factory flashes get applied is a question, where as before the BMW dealer could copy and reload the Dinan software back on the ECU. |
07-24-2014, 09:23 AM | #51 |
Rep 17
07-25-2014, 06:47 AM | #52 | |
Rep 4,128
Drives: M235i & G30 540i
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
07-25-2014, 07:25 AM | #53 |
Rep 3,071
As someone who has used Dinan products in the past, I agree that they are higher cost and less power than other tunes. If my car was out of warranty I would have a different take, but the risk of warranty issue over a few more $$ for the tune and a few less hp is not a risk I personally want to take.
(I had a Stage 2 tune with intake, exhaust and throttle bodies on my 2000 M Roadster.) The cost of the Power Package for a 135is is $2,878.20 and gets you 47 more hp and 65 lbs of torque. Does not include intake (perhaps not needed?)
Previous BMW: 16 M4, 13 M6; 14 M235i, 12 BMW M3; 11 BMW M3; 08 BMW M3; 08 BMW Z4M; 04 X3; 02 M3 Convertible; 02 M3; 00 M Roadster; 94 325 convertible; 92 325i Convertible; and 85 635csi
My Car Photo Blog: http://carfisheye.blogspot.com/ |
07-25-2014, 08:58 AM | #54 |
***** noob
1372
Rep 10,479
Dinan M235i on instagram
2006 325xi (Sold)
07-25-2014, 10:48 AM | #55 |
Rep 79
07-25-2014, 02:26 PM | #56 |
Rep 17
So word is that stage 1 ecu dtronic will be available for order next Thursday:
Around 360 hp and 400 ft/lb peaking around 3k rpm (don't have exact numbers yet) This should be priced at $2000 |
07-25-2014, 02:29 PM | #58 | |
***** noob
1372
Rep 10,479
Or comes with better cooling??? If just a tune for $2k...Fuk you Dinan
2006 325xi (Sold)
07-25-2014, 02:38 PM | #60 |
Rep 623
Welll...you would get to put a Dinan license plate frame on your car too.
2014 BMW M235i 6MT
2012 Mercedes E350 Bluetec |
07-25-2014, 05:26 PM | #61 | |
Rep 4,128
07-25-2014, 06:20 PM | #62 | ||
***** noob
1372
Rep 10,479
I know they are pricy but not $2000 pricier
2006 325xi (Sold)
07-25-2014, 08:57 PM | #65 |
What goes here?
453
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
They use crank HP as the "Stock Horsepower" on the website.. if that is the baseline, then is the advertised 364 at crank also? If so.. that would translate to lower at the wheels even.
If it is roughly 364 to the wheels (keeping in mind that stock is roughly 300) that is a again of ~60hp+ which is not too bad...
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
07-25-2014, 09:04 PM | #66 | |
Rep 926
These are the specs on the website... not very clear
Torque looks great! Max HP Gain 64 Max Torque Gain 77 Peak Horsepower 364 Peak Torque 407 Stock HP 320 Stock Torque 330 Included Notes D-TRONICS Performance Tuner, Dinan® wiring harness, Dinan Stage 1 softwareMax HP Gain 64 Quote:
