2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Looking for pictures of F22 with 19" wheel"s
      07-29-2018, 09:25 PM   #45
Kiloptero
Drives: M240i 2018 White alpine
Originally Posted by Gilda G View Post
Here you go
Here you go
Which model are those wheels ? Amazing!!
      07-30-2018, 03:17 PM   #46
Bibopp
Drives: BMW M235i
BMW 660 19" Wheels
Original BMW wheels for the F20 F21 F22 F23 = stock compatibility without any modifications. Installed with PS4S.
I had on the past the OEM 18" wheels with PSS and the new 660 19" with the PS4S are more comforatable to everyday ride and also performs well, the PS4S have unquestionably progressed compared to PSS.
I was very surprised to feel how this new 19" wheels / tires are comfortable even on damaged roads ( compared to OEM settings ).
      07-30-2018, 04:20 PM   #47
714_2er
714_2er's Avatar
108
Drives: 2015 AW M235i
VMR 702 Gunmetal w/brushed face
19x8.5 et35
19x9.5 et45
Goodyear Eagle F1 Asymmetric
225/35 Front
255/30 Rear
H&R sport springs (1” drop)
No rubbing
      07-31-2018, 02:05 AM   #48
Sonertial
Sweden
47
Drives: M240i 6MT
Here's a fairly aggressive setup.
Rims: OZ racing Leggera HLT
19" x 8" ET45. I thought they were ET35, they're actually ET45. I discovered this when I switched to winter tyres. The supplier was mistaken.)
19" x 9" ET40
Tyres: Michelin Pilot Sport Cup 2
235/35R19
265/30R19
Stock springs and suspension.
The front is probably about as good as it can be as far as strut clearance goes.
You would not fit a 245/35 Cup 2 tyre up front with this offset/width (you'd need a 5mm spacer). Other tyres may be narrower, the stock (7.5" ET45) 225/40R18 Bridgestone Potenza S001 RFTs had >~5mm strut clearance, the PSC2s should in theory have had more clearance on an 8" ET35. They do not - it is more like 2mm, the Michelins are perhaps oversized.
Fender and wheel well clearance is excellent, at least 5-10mm at full lock.
The rear pokes. An ET45 or possibly even higher offset would arguably be better. There is room inside the wheel well but higher offsets were not available in 9".
I actually love the look, despite the practical considerations.
I went the 19" route in order to open the possibilities for using the PS4S (18" not available here) and when the time comes I may go 255/30. 255s would reduce the poke to flush, but PSC2s are not available in this size here.
No rubbing observed so far under fairly heavy loads. Will see how it goes on track in a few weeks.
      07-31-2018, 07:49 AM   #49
tennisfreak
Drives: M240i
I really like your setup!
Hard to find the OCZ Leggara in those sizes here in the US
      08-08-2018, 05:51 AM   #50
EVEda235i
Mr. Clutch
EVEda235i's Avatar
Drives: 2015 M235i
2011 BMW 335i  [9.50]
19" x 8" ET35
19" x 9" ET40
235/35R19
265/30R19
19" x 8" ET35
19" x 9" ET40
235/35R19
265/30R19
Thank you! I'm running 255x35 on a 19"x10" with 45 offset. Was wanting to go for 275x35. Do you think its possible?
Quiet M235i
      08-09-2018, 02:20 AM   #51
Sonertial
Sweden
47
Drives: M240i 6MT
That would almost certainly not work.
You're already 16mm higher wheel radius than stock, going to 275/35 would be ambitious - +23mm or a 7.3% speedo error, probably illegal, and will likely rub on the fender.
I would consider /30 profile instead. That brings you back to +10mm or 3.2%.
If you went with 275/30R19 instead, according to http://www.rimsntires.com/specspro.jsp, you will poke the same as me, but the tyre will be 6mm closer to the suspension and inner wheel well.
I think 275/30 might work, but you will probably need to cut the fender liner a bit, there is a higher risk (+3mm) of fender rubbing, and you will poke.
      08-09-2018, 06:51 AM   #52
EVEda235i
Mr. Clutch
EVEda235i's Avatar
Drives: 2015 M235i
Wow thanks fornthe analysis. Honestly idk what i was thinking running 35 sidewall. Next set i'm going to run 265/30 and go from there. Thank you!
Quiet M235i
      12-05-2018, 11:06 PM   #53
icin235
icin235's Avatar
Drives: 2015 M235i Silver 6spd
M235i Glacier Silver with Silver VMR 703 19s.
      02-20-2020, 07:33 AM   #54
gabssilvagarcia
gabssilvagarcia's Avatar
Philippines
Drives: BMW M235i
Originally Posted by Bmw.Fan View Post
Just got some new wheels put on yesterday.
Zito - ZS05 Satin Black
19 Inch
235/35/19
265/30/19
Not lowered
No issues rubbing or any of the sort (In case anyone was thinking about it like I was!)
Attachment 1614920
Attachment 1614928
love the aggressive look! what are the offsets of your rims?
      02-20-2020, 07:35 AM   #55
gabssilvagarcia
Philippines
Drives: BMW M235i
Originally Posted by Icy J View Post
what are the specs of your rims? are these 19x10 in the rear?
      02-22-2020, 10:18 AM   #56
icin235
icin235's Avatar
      03-09-2020, 07:36 PM   #57
PeanuKeeyes
PeanuKeeyes's Avatar
366
Drives: E34 | MX5
Velos design werks
Front Tires: 235/35/19
Front Wheels: 19x8.5
Rear Tires: 265/30/19
Rear Wheels: 19x9.5
Was lowered on HR when purchased, but returned to stock height to save shock life. Photos are of stock spring setup. Everything fits and drives smooth.
      03-09-2020, 07:54 PM   #58
El Conquistador
Drives: M240 Vert - 6M as god intended
The real lesson of this thread is that Estoril Blue really is the best color for the 2 series.
dradernh4413.00
E46ZHP254.00
      03-09-2020, 09:12 PM   #59
PeanuKeeyes
366
Drives: E34 | MX5
It’s true though. That color is wicked on our cars.
      03-11-2020, 09:54 AM   #60
Pillz17
Pillz17's Avatar
Drives: 2016 228i xdrive
[IMG]undefined[/IMG]
      03-31-2020, 03:36 PM   #61
Mark.h
Drives: 2015 bmw m235i
Originally Posted by PeanuKeeyes View Post
Velos design werks
Rear Wheels: 19x9.5
What offset are you running?
      04-20-2020, 09:18 AM   #62
ZhpSteve
Drives: Retired - 2015 M235i
2015 BMW M235i  [0.00]
Considering a set of OEM 19's in the following sizes
Front rims are 8.5Jx19 offset is 33
Rear rims are 9Jx19 offset is 44
What would be required to run those on stock suspension and what size tires would you recommend?
      04-22-2020, 12:43 AM   #63
dbs_jd
Drives: ‘18 BMW M2
Hi there, very nice wheels everyone! I also want to change mines on a m235i and this thread has helped me a lot.
I have been searching on the internet if the 788M fit on the m235i. So far, I think they don't because they are 9x19 on the front and 10x19 on the back, and the m235i seems to have fitment for 8.5x19 on the front and 9.5x19 on the back. Am I right?
Thanks in advance!
      04-26-2020, 04:43 PM   #64
513Mugsy
Just a dude...
Drives: BMW M240i xDrive
Running INOVIT 19X8.5 ET37 square setup. Continental DWS06 235/35/19. No rubbing. Stock suspension, and camber settings.Name:  IMG_20200411_130032.jpg
      04-26-2020, 04:46 PM   #65
Solid67
Drives: 2019 M240i xDrive MP Edition
2019 M240i M Performance Edition on 19" m405
2019 M240i M Performance Edition / xDrive / ZF8 / BM3 Stg 2+ E30 / xHP Stg 3 / Dorch Stg 2 HPFP / Evolution Racewerks Catless Downpipe / MPPSK Exhaust / FTP Drop in Filter / FTP Intake Pipe / FTP Chargepipe / NGK 94201 Spark Plugs .022 / Michelin PS4S - 225/35/19 + 245/30/19
      03-05-2021, 07:05 PM   #66
jaymeson
Drives: 17' M240i xdrive
Originally Posted by 513Mugsy View Post
Running INOVIT 19X8.5 ET37 square setup. Continental DWS06 235/35/19. No rubbing. Stock suspension, and camber settings.Attachment 2295520
no rubbing on this set and no serious poke in the rear? i have an xdrive m240 and wnating to go 19x8.5 or 19.95 et 35 but not sure of fitment?
Resoelg244.00
