2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum M235 comments after 1st track event
      03-09-2015, 03:18 PM   #1
Ramos
Ramos's Avatar
Drives: G20 2020 M340
Hello all,
This weekend I had the opportunity to take my M235 to its first track outing with the BMWCCA at chuckwalla.
I have 6 years of moderate track experience, and recently graduated to the A run group.
The car is stock with the exception of running a square tire setup 245-40-17 Dunlop Star Specs, and performance brake fluid.
My wheels setup is: Team Dynamics Pro Race 1.2's 17x8 ET 40 all around.
No rubbing but very close to the strut! Thanks Timsev for the help on wheel and tire fitment
Here are my takes:
1) BMW has done a wonderful job with the cooling on this car, the ambient was 90 degrees on track, and I was watching the temps through the secret menu. They stayed constant throughout the weekend, never overheated in the slightest. Coolant was constant at 105 Celsius (220 F) and oil was also steady at 115 Celsius (240 F)
Gone are the days of the 335 overheating and limp mode.
Accessing the secret menu is quick and easy but in no way does any of that excuse the lack of an oil temp gage.
2) I ran in Sport + (Plus) the first day and DSC all the way off the second day. DSC off is the right setting for the track, it keeps the steering and suspension in sport (6MT) car, and the throttle in normal lazy mode, which is better for the track because it makes heel and toeing easier and less sensitive to over revving when blipping the throttle.
DSC all the way off is not that scary, car was still neutral but more playful and tail happy.
Yet it remains very easy to control over steer and correct. Recovering from slides and pretty hair raising slip angles is a piece of cake in the M235.
Also this mode saves your rear pads from the constant application caused by the traction nannies.
3) Stock brakes are good enough, strong and easy to modulate with very little fade but not quite great or what I would call track worthy. Pedal does get a little long half way through a session.
4) Overall the car is very neutral and at home on the track, turn in a little loose (read initial oversteer) likely caused by my square tire setup, which is how I like the car to be setup. Minimal under steer mid corner and exit, even with no added camber. Definitely more E36 M3 feel than E90 335 feel.
5) The lack of an LSD was felt on tight off camber corners but not much anywhere else. The E-diff cannot be turned off even with DCS all the way off, and seemed to really struggle to stop the inside rear wheel from spinning. I tried multiple lines and speeds through that one corner (17) and no matter what I did, the car and the E-diff just did not work well through there.
Overall, the lack of a mechanical LSD is definitely manageable although it would be a nice upgrade for sure.
All in all, the car handled brilliantly and I had an awesome experience.
Bring on the M2!! The platform is already amazing even in M235 guise.
Happy to answer any questions.
Appreciate 4
      03-09-2015, 03:26 PM   #2
Liquidpaper
Liquidpaper's Avatar
Drives: '15 M235i
2015 BMW M235i  [0.00]
Originally Posted by Ramos View Post
Hello all,
Here are my takes:
1) BMW has done a wonderful job with the cooling on that car, the ambient was 90 degrees on track, and I was watching the temps through the secret menu. They staying constant throughout the weekend, never overheated in the slightest. Coolant was constant at 105 Celsius (220 F) and oil was also steady at 115 Celsius (240 F)
According the secret menu is quick and easy but in no way does any of that excuse the lack of an oil temp gage.
Yeah, the cooling is really impressive on this car. You can flog the crap out of it and the engine takes it in stride. Very impressive.
      03-09-2015, 03:37 PM   #3
ddmyte
Australia
Hi Ramos, great to see you actually "use" your car. Wondered if you could advise how to access the temperatures through the "secret menu"
Thanks
      03-09-2015, 04:26 PM   #4
Ramos
Ramos's Avatar
Thanks
Here you go:
http://www.2addicts.com/forums/showt...ht=secret+menu
Notes:
1) The "Unlock code" is the SUM of the last 5 digits of your VIN
2) Hold the Trip reset button with the ignition off, then switch on the ignition, while keeping the Trip Reset button pressed for a few more seconds until the secret menu comes up
3) Short presses on the button to scroll, long presses to select.
It's quite easy once you get the hang of it.
      03-09-2015, 06:23 PM   #5
ddmyte
Australia
Thanks Ramos
      03-09-2015, 06:49 PM   #6
jordantii
Drives: M2 Sea
I was under the impression that DSC all the way off does not put the chassis in sport mode. Is this only on the 6mt?
      03-09-2015, 06:50 PM   #7
Year's_End
Year's_End's Avatar
Drives: 2020 Shelby GT350
Fantastic write-up!
Past: '08 E92 335i|ZPP|ZSP|6AT
Past: '15 Mustang GT|401A|PP|6MT
Current: '20 Shelby GT350|6MT
      03-09-2015, 06:54 PM   #8
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
It does...at least on the AT.
I don't think it depends on the transmission anyway...
DSC OFF = sport chassis, comfort thorttle response, comfort transmission shift AT, louder exhaust
      03-09-2015, 07:21 PM   #9
Xiaoxi
Xiaoxi's Avatar
269
Drives: a Miata
So just to be clear, does DSC off enable both tailipips / dual throttle?
2015 M235i | AW | 6MT | Tech | Heated Seat | Parking Assist | Fabspeed DP & Muffler Delete | Apex PS7s
1999 MX5 NB | Emerald Mica | 5MT | Sport Edition | Kosei K5Rs | Heated Rear Glass
ig: @bee2ven
      03-09-2015, 07:31 PM   #10
jordantii
Drives: M2 Sea
Hmm, ok. I'm going to have to see what happens when the AT is put in sport with the DSC fully off.
      03-09-2015, 07:31 PM   #11
pikcachu
pikcachu's Avatar
1403
DSC off enables louder active sound.... not sure if it opens the second exhaust valve at all times
      03-09-2015, 07:31 PM   #12
Ramos
Ramos's Avatar
I don't know anything about dual throttles,
all I know is that DSC off = Sport damping (same as Sport +), Sport steering (same as Sport +), Lazy throttle response (same as Comfort)
Plus obviously all the nannies are off, but the E-diff CANNOT be turned off
In my experience this weekend, DSC off is great for track, and Sport + is a waste of rear brake pads
      03-09-2015, 07:33 PM   #13
Ramos
Ramos's Avatar
You cannot, that's what the whole debate is about.
DSC OFF is its own mode completely separate from any other mode.
      03-09-2015, 07:34 PM   #14
Ramos
Ramos's Avatar
If you guys don't mind, I would like to keep this thread about the OP, and not all about what DSC off mode is and what it isn't.
Thank you
      03-09-2015, 07:44 PM   #15
VMRWheels
General
VMRWheels's Avatar
2042
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Great write up! Next time.. vid and pics! haha
      03-09-2015, 07:46 PM   #16
Ramos
Ramos's Avatar
I'm getting a GO Pro for next time and some form of data acquisition. Hopefully I can benefit and learn from that.
Wish I had video cuz the footage of the 928 Porsche spinning in front of me and coming back across the track facing the wrong way and me having to drive off the track to avoid it would have been epic !!!
      03-09-2015, 08:19 PM   #17
Iceman51sn
Drives: 2015 AY M4
Great review! Looking forward to some video next time! How did you like Chuckwalla? That's one track I haven't checked out yet.
      03-09-2015, 08:24 PM   #18
pikcachu
pikcachu's Avatar
1403
do you have the M laptimer?
      03-09-2015, 11:07 PM   #19
hoppy6698
hoppy6698's Avatar
Drives: M235i, Estoril Blue on Black
Thanks for the write up and experience notes! Recommend steel brake lines and ATE 200 brake fluid for the next track event, may help with the peddle mush throughout the day. Cheap upgrade, still burns OEM brake pads which are replaced for free anyways
      03-10-2015, 02:39 AM   #20
Ramos
Ramos's Avatar
Omg, I totally forgot about the M lap timer!!
About the brake fluid, I actually did have high performance fluid in there. Unfortunately my pads were not free, I had maybe 25-30% left on the initial pads. Not enough for a track weekend but also not little enough to get them replaced by BMW
I paid for new pads out of pocket, was gonna go after market but no one makes matching front / rear pads for this car yet,
      03-10-2015, 05:39 AM   #21
Béhème
Here you go:
Notes:
It also works if you hold down the Trip reset button with the car running until the menu comes up, then follow the steps to unlock and select as described above.
While it is possible, I don't recommend doing it while driving.....
      03-10-2015, 08:04 AM   #22
Liquidpaper
Drives: '15 M235i
Yes they do. Porterfield R4-S. I have a set. They're great.
