2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum 2016 228i tail light ground issue
      02-28-2024, 04:41 PM   #1
kjazz1958
Drives: 2016 228i
I have the somewhat common tail light "melted ground" issue. I did order a replacement plug kit, but I am wondering if I might be able to simply splice the brown ground wire to the chassis. This would be simpler than having to strip and splice all the wires. The question is: will it work and can I attached the new ground to any metal to achieve an adequate ground?
      02-29-2024, 07:59 AM   #2
MarcoZandrini
Drives: 2018 M240i
It will likely work fine.
      03-10-2024, 12:03 PM   #3
kjazz1958
Drives: 2016 228i
Thanks for the reply! I'll give it a try.
      03-11-2024, 01:45 PM   #4
owenscj21
owenscj21's Avatar
53
Drives: 2016 BMW 228i M Sport
Post back when done. I'm curious if this works out for you.
Having the same issue, I recently changed out the bulb holder and replaced with the new harness.
In hindsight, I think it may have been easier to de-pin the old connector and only pin and add the affected ground wire. Would have been much easier than trying to crimp the other 7 pins.
2016 228i M-Sport 6M RWD- CTS Intake, CTS FMIC, VRSF charge pipe, CTS catted downpipe, FTS Stage 2 ECU
      03-21-2024, 02:32 PM   #5
f22liam
f22liam's Avatar
Did this end up working for you?
      04-15-2024, 05:33 PM   #6
kjazz1958
Drives: 2016 228i
Sorry for delay. No, this did not work. I suspect the place where i attempted to screw in the alternate ground did not provide a proper ground. I drilled a hole into the metal housing. Not sure what to try next.
      04-15-2024, 07:39 PM   #7
harma24
https://www.2addicts.com/forums/show....php?t=1663556
Family Cars: 1993-2014: 1993 Honda Accord 10th Anniversary Edition | 2014-Present: 2014 Honda Odyssey
Stable-mate: 2019 - present: 2020 230xi Seaside Blue Convertible
      04-20-2024, 09:45 PM   #8
Uridian
Uridian's Avatar
42
Drives: E36 M3, 228i M Sport
I cut the wire outside the housing, spliced in a split a soldered to the locations in this post.
https://www.2addicts.com/forums/show...67&postcount=6
I did that about a year ago and it's been holding up just fine.
