2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum 2 Series Photos and Videos M235i Modified
      08-29-2014, 01:39 PM   #45
LAwolverine
LAwolverine's Avatar
Drives: Cannondale
tastefully done. minus the bbs sticker
      08-29-2014, 01:40 PM   #46
nieue
United Kingdom
169
Drives: M3 E92 & M235i
Thanks for the comments guys :-)
Will post some more picture on Sunday :-) Colour as well
The wheels are 18x8.5 ET35 with a 10mm spacer at the front. The 3 way clubsport suspension has quite a bit of camber on the front. But this is the set up on this car. It will run a square set up on tyre size as well - 245 fronts and rears for the supersports.
LOL on the stickers - understand tho :-)
      08-29-2014, 01:44 PM   #47
ron_jeremy
ron_jeremy's Avatar
Norway
513
Drives: 13' F25 X3 20d & 16' i3
The best looking 2 i've seen.
In general i love BBS on BMW's but yours looks smaller than it is, that's my only detail i'd change.
Everything else is perfect.
3 series: E30: 89 325i, E36: 92 325iC, 94 320iC, 96 320i Convertible, 94 320iaC, E46: 99 320ia, E90: 06 318i Le mans, E91: 07 318dt
5 series: E39: 97 520ia, 01 530Dat, E61: 09 520Dat
X series: E83 05 X3 2.0d, E84 10' X1 2.0 X-drive DA, F25 13' 2.0da X-drive.
      08-29-2014, 01:58 PM   #48
nieue
United Kingdom
169
Yeah they are 18's so I can use specific tyres for the track :-)
      08-29-2014, 02:00 PM   #49
WCM3
Î canŧ főcus mŷ attėntĭon
WCM3's Avatar
Drives: 13 Rubicon
Love what you've done! I keep liking the M235i more and more each day.
I would lose the BBS stickers for sure though.
2011 M3 Coupe - Individual Fire Orange/Black Novillo Extended Leather, 6MT, Mode Carbon, Eisenmann Race, BBS CH-R, BC Coil-overs (Sold)
1995 M3 Coupe - Avus/Hurricane, AEM EMS, Precision Turbo, Boostlogic, H&R, Fikse FM/5, MaxVelocity, Maximum PSI, 20% Tint, etc etc..(Sold)
2009 M3 Coupe - AW/Fox Red, 6MT, Carbon Roof, Shadow Trim, etc (Sold)
      08-29-2014, 02:08 PM   #50
brio
brio's Avatar
Drives: e90 330i
2006 BMW 330i  [0.00]
I think it looks stunning! Best black M235i I've seen.
      08-29-2014, 02:10 PM   #51
nieue
United Kingdom
169
Just uploaded images of the 3 way clubsport suspension
      08-29-2014, 02:32 PM   #52
Eddy@ApexWheels
Eddy@ApexWheels's Avatar
445
Drives: E30 M3, F10 M5
Originally Posted by GeoBem007 View Post
No offence, but are you sure about your wheel specs?
'cause if you're saying you're running a 10mm spacer in the front, that means your wheel spec goes to 18x8.5 ET25. I don't know exactly how it is on 2-series, but on my 1-series 18x8.5ET40 was already pushing it...
Otherwise, great looking 2-series. One of the nicest out there. Only a dislike for the BBS sticker on non-BBS wheels
Since the car is located in Leeds, we were able to look in our records and confirm a recent shipment of 18x8.5" ET35 wheels. Looking at the photos and seeing how flush the rear wheel is, it also confirms that they are 18x8.5" ET35 all around. It's not a fitment advisable to most people, so I'll explain below. It looks absolutely stunning though and we appreciate difficult fitments and beautiful cars
From the look of the photos this car is reusing the stock 225/40/18 Michelin super sports stretched up front, and the stock 245/35/18 in the rear. The stretched tires are helping this fitment work.
ET35 with a 10mm spacer up front is extremely, extremely aggressive for the 2 series and 1 series. Because the front wheels are turned in the photos and the tires are stretched, there is no reference point to gain a sense of perspective on the front fitment. 18x8.5" ET35 with a 235/40/18 extreme summer tire rubs the front fender on stock cars, so I can see how a 10mm spacer could be used up front to push the wheel out when stretching a 225 tire. If a photograph was taken directly from the front down the side of the car, the front wheel is almost certainly protruding from the fender unless this car has camber plates installed, with a lot of camber dialed in. I don't believe KW V3 kits include plates though.
The offsets of this configuration are much more aggressive than what we would advise for a track setup, under compression the rear will likely rub at ET35 as this is 23mm more aggressive in the rear with the same size tire. If a 10mm spacer is being used up front, that makes the front 33mm more aggressive. Even with a stretched tire, it's really pushing it for most members on the forum.
The 2 series specific square setup is 18x8.5" ET45, although a staggered 18x8.5" ET45 Front and 18x9.5" ET58 rear is an even easier fit, due to 2 series specific rear offset.
Originally Posted by nieue
KW 3 Way Suspension (three spec)
(It will run Pilot Sport Cups/ Dunlop Dirreza for track 235/40/18)
In your Original post, you mention wanting to eventually run Pilot Sport Cups or Dunlop Direzza tires in a 235 size. You'll need to pay very close attention to your wheel/tire/suspension setup both up front and in the rear if you decide to change to a meatier or wider tire.
The front 10mm spacer could definitely not be used, when moving away from the stretched tire. ET35 will still be a concern, but if you get camber plates and run about -2 degrees it will clear the fender properly. At ET35 you should not encounter any suspension clearance issues with your KW V3 suspension, but it could be very close.
Below is a fitment test of an 18x8.5" ET45 EC-7 with a 235/40/18 Nitto NT-05 Extreme summer tire. The NT-05 runs narrow for it's overall physical size in comparison to other extreme summer tires, and especially r-compounds.
in the below photos you can see the strut tube clearance at the ET45 offset. It's a very tight fit, but it was designed to keep the 235 tire inside the fender properly on 100% stock cars. Note: this tire has a bead protector, which is what's closest to the strut. Tire shapes vary, so tires without a bead protector will have more clearance, as rim to strut clearance is another 5+ millimeters.
Although you'll have 10mm more clearance on the strut side, you will still have to watch out for potential clearance issues with an r-compound tire if your ride height is set too low. The KW V3 suspension comes with a cone shaped spring. The variant spring shape is long, so it sets the spring perch low. Most likely the lower spring perch is currently next to your front tire. Because you are running a stretched 225 tire and an ET35 offset + a spacer, there is clearance. But when you take the spacer out, and switch to a wider tire like a 235/40/18, you will lose a lot vertical and horizontal strut side clearance as the tire will grow in overall diameter too.
The rear fitment will be negatively impacted with a switch to 235/40/18 as well at the ET35 offset vs. ET45 since a 235/40/18 is over a half an inch taller. A 235 Pilot Sport or Direzza will be physically wider than the current 245 you are running in the rear, which already looks very close to your fender from the pictures.
Below are some photos (at stock ride height) of M235i's running 18x8.5" ET45 with 235/40/18 NT-05 tires. You can see how much meatier and taller 235 tires run.
Below are images of the recommended staggered setup of 18x8.5" ET45 and 18x9.5" ET58. Here you can see that the 9.5" ET58 allows a 265/35/18 extreme summer tire to fit cleanly in the rear. The switch from 8" ET52 to 9.5" ET58 only pushes the wheel out 13mm, but 25mm of it moves in-board. This allows a 265 (and in some cases with careful attention a 275) tire to fit, as 2/3 of the added with is moved inward.
If you were to encounter major rear fitment issues as you switch to meatier tires, one option would be to keep your current front wheels, but switch to the 9.5" ET58 wheel, or you could switch all 4 wheels to the ET45 offset and run the 10mm spacer up front to clear your suspension.
      08-29-2014, 02:52 PM   #53
automotiveaperture
automotiveaperture's Avatar
93
Drives: Frozen Black M3
Stunning ride sir! The apex wheels are perfect, can't wait to see the finished product
      08-29-2014, 02:52 PM   #54
nieue
United Kingdom
169
Thanks for comments on fitting - the car been tested heavily at the ring on various wheel combinations with the 3 way clubsport and this seems to suit the car best.
Also we have test the rear wheels on the front the 245 fit fine with plenty of space. I think this is due to the camber running
Looking at your pictures on clearance your looks a lot closer (but will take pictures to compare)
235's was the preferred tyre size allround after testing at the ring - so ill use the existing tyres for the road before changing :-)
      08-29-2014, 03:06 PM   #55
Eddy@ApexWheels
445
245/35/18 is our preferred front tire size on the 2 series and 1 series if the car has camber plates. This is because 225/40 and 245/35 are the same height, so you get width without the height compromise which can result in contacting the suspension or fender liner.
Yes, your car has a lot more suspension clearance because your offset is 10mm more aggressive and you're running a 10mm spacer (20mm total more clearance to the wheel rim than our photo).
      08-29-2014, 03:26 PM   #56
Greenkirby21
Vrooom :)
Greenkirby21's Avatar
Drives: C7 Stringray
those rims are amazing!!!
2014 C7 Corvette Stringray - Laguna Blue - NPP Exhaust - Competition Seats
      08-29-2014, 03:35 PM   #57
wilwinchester
wilwinchester's Avatar
Drives: 2012C350
Sex!
      08-29-2014, 03:45 PM   #58
nieue
United Kingdom
169
Thanks Eddy :-)
      08-29-2014, 03:46 PM   #59
nieue
United Kingdom
169
I'm happy to test a wider rear set if you want to send me some :-)
      08-29-2014, 03:48 PM   #60
bxsinster
Drives: 2009 n54 135i SedonaRed
wow just wow beautiful..
      08-29-2014, 04:30 PM   #61
nepats81
Drives: 2018 BSM ZCP M4
more pics please. Wheels look awesome!
      08-29-2014, 05:29 PM   #62
Enilder
Drives: Porsche Macan S
Love the mods. Not a fan of 2series but this is an exception. Well done.
      08-29-2014, 10:31 PM   #63
playground
Hong Kong
32
Drives: M3
bbs stickers on an apex wheel. WHY?!
Become like water my friend.
      08-29-2014, 11:44 PM   #64
pkimM3r
pkimM3r's Avatar
205
Drives: m3 saloon in granny mode.
Originally Posted by Small Yellow
Lol 3 way adjustable KW? So KW competition coilovers? Thats some baller coilovers I didnt know 3 ways were out for this car yet. You sure it isnt the KW variant 3 / KW V3?
they have 3way clubsports. oh oops specifically for this car you mean?
OP posted pics. yep 3 way cs.
      08-30-2014, 12:17 AM   #65
nieue
United Kingdom
169
The 3 way kit is been developed and is available - this one has been done specific for the ring so tweeked compared to the standard one.
      08-30-2014, 12:31 AM   #66
nieue
United Kingdom
169
Originally Posted by BimmerEngineer View Post
This is realky a 235i M-package. Please BMW stop calling it a M235. And to Neue, remove the BBS stickers. We don't need a reputation for posers. You know, the guy with the New 550 that put dual tip mufflers and fake fender vents on his 550,then pulled off the 550 badge and put M5 on it. So please remove the BBS stickers.
Total offended with the poser comment - I go to the ring and use the car for what it's being built for - All mods (apart from stickers, all part are there to perform). Attached are pictures of my M3 that stays in Germany and I go every month, and Spa as much as I can.
I build cars to be use and hopefully look good!!!! The M235i is the start of the project more to follow!
M235i is what it's called by BMW, so why not! I've had enough M cars not to be offended so why get hung up over it, great little car well done BMW.
LOL on stickers.
