05-27-2017, 02:55 PM | #1 |
Rep 183
Comfort mode engine on ready
Hi guys
I know from the dealer that i got some sort of battery issue... My question is that in comfort mode the engine will stop when im stopped on a red light which is normal but sometime it wont do it...the car will stay on when fully stopped in comfort Does ur car does that too? Im thinking the engine wont go to ready cause they detect the battery being weak or.low or something could that be true? Does urs always go to ready on all stops? |
05-27-2017, 02:59 PM | #2 |
Rep 598
its normal. the car wont turn off if its not warmed up or if you have your a/c on and the interior temp goes to high. it also wont always turn off if you are stopping very frequently.
05-27-2017, 03:11 PM | #3 |
Rep 610
Also depends on if the auto start/stop button is on or off. (It's the button above the start button)
I leave mine off, if I want that feature I would rather flip to eco pro. But yeah there are other reasons it won't stop the engine. One being that the battery is low |
05-27-2017, 08:01 PM | #4 |
Rep 518
Reasons why start/stop isn't working
The car is coasting (manual transmission) Brake vacuum reading is too low (manual transmission) Insufficient brake pedal pressure is being applied to hold the vehicle stationary (automatic transmission) Stopping on a hill/downhill with a 12% or greater gradient If the steering angle is more then 6 degrees If the steering wheel is being moved after approximately one second of coming to a stop The system has not yet be activated by going over a speed of 5mph for automatics, 3mph for manuals since the last engine switch off If the gas pedal is being pressed (engine must be at idle speed only) You're coming to a stop from reverse The driver gets out of the car If Hill Decent Control (HDC) is activated If the engine is not up to temperature If the carbon canister is being purged if the grade of the fuel is too low for the engine Transmission adaptation is active (automatic transmission) The hydraulic pressure accumulator is not yet up to pressure (automatic transmission) Stop-and-go traffic - system is only activated by driving over 5mph for automatics, 3mph for manuals Batter charge is low Outside temperature is colder then 37.4 F / 3 C Outside temperature above 95 F / 35 C and the air conditioning system is on Fogging of the windshield is detected by the IHKA system Climate control system is on but passenger compartment has not yet reached desired temperature ABS system was used when coming to a stop
Estoril Blue 6spd M235i LSD Sunroof delete AWE touring exhaust Fabspeed sport cat
TigerTrump1.50 |
05-28-2017, 05:32 PM | #6 |
Rep 3,256
