2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Weather strip on chassis missing
      03-18-2016, 01:14 PM   #67
gdoan
Drives: 2016 M235i
January '16 build and not installed.
2016 M235i Mineral Grey/Black, all but LSD...
2008 X5 4.8i Mineral Green/Black (daily hauler)
1998 740iL Arctic Silver/Black (occasional trawler)
2003 ///M5 Jet Black/Black (sold); 2002 330Ci Jet Black/Tan (RIP); 1995 318is (Boston Green/Tan) (sold)
      03-18-2016, 03:30 PM   #68
Zooks527
On order. $38.71 after tax for the pair, 8 - 10 business days for delivery. I'll need to drive 10 miles each way to pick them up. That's OK, I like driving my car.
      03-18-2016, 07:08 PM   #69
gdoan
Drives: 2016 M235i
On order. $35.90, before tax, for the pair, from the venerable bavauto. I bought a 'few' other things, so free shipping. Not sure of shipping time but probably about a week.
      03-19-2016, 06:46 AM   #70
Spydeputy
Spydeputy's Avatar
Germany
205
Let me know if you need help on the install?
      03-19-2016, 12:05 PM   #71
ORIGIN M.
Drives: ///M
Originally Posted by neilr_
Checked this morning - my 2016 228i (production complete 10/3/15) has them on both sides.
I'd be pissed if it did not. And BMW needs to buy them not the other way around.
      03-20-2016, 07:30 AM   #72
Spydeputy
Spydeputy's Avatar
Germany
205
Seems the 228 have them more than the 235's ???
      03-20-2016, 12:04 PM   #73
AlpsRider
AlpsRider's Avatar
2865
Drives: M2 Competition, LBB, 6MT
Yeah, I don't know what happened with this one, I had mine only on the passenger side.
      03-20-2016, 12:10 PM   #74
ORIGIN M.
Drives: ///M
They'd be good-willing me a new one I guarantee you that.
      03-20-2016, 12:12 PM   #75
ashley1251
Drives: Best Car
Mine is a 2016 M235i, maybe it is a model issue fix?
      03-20-2016, 12:24 PM   #76
AlpsRider
AlpsRider's Avatar
2865
It seems to be just hit or miss with these seals from what people have reported, maybe they had too many beers on the weekend?
      03-20-2016, 12:28 PM   #77
AlpsRider
AlpsRider's Avatar
2865
I agree, I tried that, they looked it up on the comuter and said that the M235 doesn't come with seals... They didn't understand why my car had just one installed. It is a lame excuse.
      03-20-2016, 02:39 PM   #78
ORIGIN M.
Drives: ///M
Make an appointment with the regional service manager.
Tell him or her in person what you expect.
      03-21-2016, 06:42 PM   #79
ThreeToTwo
England
27
Drives: 2016 6MT M235i
UK Spec Confirmed
Talked to the Parts department at my dealer here in the UK today. We confirmed that neither 235 nor 228 should be fitted with them but that the one diesel model checked does have them.
I ordered a pair for my 235 at UKP12.75 each (about 18.30 US each). Being in Europe, I get next-day delivery.
      03-22-2016, 02:00 PM   #80
ThreeToTwo
England
27
Seals Installed
Collected and installed the seals today. They are a bit fiddly to install but don't take too long and need no tools. Haven't had time to go very far but the cabin is definitely quieter, losing some road noise (I think).
Here's my thoughts on fitting:
I started by opening the door wide and, working from inside, dropping the seal down beyond the hinges, straps etc so it was lightly wedged within the back of the wing (ie ahead of the door's inner leading edge. The rounded top of the seal has a recess for the prominent bolt which makes it easy to get it at the right height (and to tell the top of the seal from the bottom).
I chose then to work from half way down the seal and hook it around the flange of the front wing - the space to work is biggest there. Once a few inches are tucked in, the seal is quite well located so you can adjust the height. I then worked back up to the top, outside the car with the door partly open just pushing the seal by hand until it wrapped around the flange and sat neatly in place (my picture of the partly installed run of seal shows that it's obvious when it's correctly fitted).
At the top, from inside the door the curved section of the seal falls into place and tucks in if the height is right; if not, a gentle tug will still move it up and down at this stage. Then I worked down to the bottom.
The bottom end of the seal seems quite big. There's a kink in the bodywork and a matching kink in the seal - when they align it all just falls into place. Part of it disappears into the bodywork and the rest forms a rounded lip that protrudes a little towards the door. At the very bottom, there's quite a big lip.
Probably 5 minutes each side and the second one is much easier than the first, no great skill required: just a little patience.
Appreciate 13
      03-22-2016, 05:26 PM   #81
selmeralto
selmeralto's Avatar
227
Drives: 2021 M2 Competition
Very nice description. Thanks.
      04-06-2016, 05:35 PM   #82
225_AB
2014 M235i  [0.00]
2009 BMW 330D  [0.00]
Which dealer did you get them from?
      04-10-2016, 02:27 PM   #83
Zooks527
In today. Knocked the noise down a noticeable amount. 5 minutes to figure out how the first one went in, 2 minutes to do the second.
      04-10-2016, 02:36 PM   #84
bimmerfile
bimmerfile's Avatar
621
Drives: 2019 BMW X2 F39
Originally Posted by Spydeputy View Post
So, I answered my own question of a few post back.
Can you install these on a F23, (convertible)?
Yes, you can. the install took me about 15 minutes.
5 of which was looking at the rubber piece, and the pictures of other installs here on the post. Then figuring out how to put them in. Once that was done each side took 5 minutes. Just get it in place loose from top to bottom. Once it is lined up I started pushing it in at the top and worked my way down. You have to open the door in between halfway and all the way open to use your fingers to push it in the opening. I used the end of a 12 inch wooden ruler to make sure it was seated properly. Don't use something pointed, like a screwdriver, it will go right thru the soft rubber.
Now I'll drive it and see if it is any different, quieter.
Ummm, so when are you going to tell us???
2019 X2
      04-10-2016, 05:06 PM   #85
ThreeToTwo
England
27
Ridgeway in Bournemouth but I think any Parts department should be able to find them for you.
Someone posted the following diagram (I can't remember where so I'm repeating it here). It came up the same on the Parts Department's computer - just ask them to look at a diesel model, not an M235i.
      04-12-2016, 05:35 AM   #86
Spydeputy
Spydeputy's Avatar
Germany
205
So, at highway speeds the cabin might be a little less noise from the from up front. But under acceleration, no difference that I noticed.
      04-12-2016, 10:07 PM   #87
XutvJet
Today I figured out why the 228's come with this insulation the M235's do not. As I was walking out of the office, a brand new 328 started up and drove off and it was shocking how loud that turbo 4 is on a cold start. It sounded almost like a diesel. Many of the magazines have noted the volume as well. It's so "knocky" in fact that I had to look at the back end to make sure I saw the 328 and not a "D". LOL
      04-14-2016, 10:59 PM   #88
Gabrola
Gabrola's Avatar
191
Drives: 340i
I have a 2016 218i convertible and it has them on both sides.
