12-11-2018, 05:39 AM | #1 |
Rep 524
MPE length
Just realize I posted this on the 240 side instead of here.
I've been playing around with some BMS tips on my MPE and once I got them on, my driver's side tip sticks out further. I figured it was because these tips weren't meant for the slightly larger diameter of the MPE and that in the process of bending the internal spring clamps, it just didn't fit the same on the driver's side. I took the tips off and the bare pipe does stick out further on the driver's side. It's probably only 3/4"-1", but OCD rules won't allow this. This would have been masked with the MPE tips since they use a set screw and you can adjust as needed. Has anyone else noticed this? Just wanted to double check before I go cutting a bit off to even them up.
2019 M2 Comp, MT, BSM
2015 X5 Msport, CB (Hers) 2014 M235i MT, BSM, MPE, Dinan Springs (Sold) |
