2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Moisture on the passenger floorboard
      09-20-2016, 02:09 PM   #1
RonCawley
RonCawley's Avatar
Drives: 2016 228i xDrive - on order!
2016 228ix with 2500 miles
I have been noticing moisture under the rubber floor mat on the passenger side. We have had a lot humidity lately and obviously, I've been running the air conditioner too. I was wondering if anybody else is experiencing this. Not sure if it's coming from the air-conditioning condensate or possibly a seal on the window
      09-20-2016, 02:16 PM   #2
3.0L
3.0L's Avatar
8935
Drives: M235i, 20k miles
Originally Posted by RonCawley View Post
2016 228xi with 2500 miles
That sounds very abnormal. You probably should take your car back to your servicing dealer and have it checked out before the moisture starts causing damage.
When writing your life's plan, use a pencil with an eraser
      09-20-2016, 05:48 PM   #3
Nito310
Nito310's Avatar
It could be something similar to this?
http://f30.bimmerpost.com/forums/sho....php?t=1304953
      09-20-2016, 09:36 PM   #4
Gilda G
Gilda G's Avatar
Drives: M235i xdrive
I had the same thing back in 2006 with my E60. The roof drains were clogged after a heavy rain storm. Its not covered under warranty to fix per BMW NA. I called my insurance company and they covered it because after lifting the carpet and releasing the water from the drain plug I realized BMW put a lot of electronics on the passenger side. One by one things stopped working within a few hours of finding the water. If I was you I would check under the carpet. If there is a lot of water have BWW check your car. Also the tell tail sign of something is wrong other than the water or dampness is a sweet smell. After BMW fixed it the SA said if you smell something sweet chances are water is getting in again and generating mold..
Good luck to you and I hope its just moisture..
SOLD: 2015 BMW M235i Glacier Silver on Coral Red
35% tints, Gloss Black Roof, AFE Magnum Force Stage 2 Intake, AFE Power Scorcher, P3 Vent Gauge and Fabspeed muffler delete.
      09-22-2016, 06:08 AM   #5
morphomeman
morphomeman's Avatar
593
Drives: 2015 M235ix
2016 BMW X3  [0.00]
2015 BMW M235ix  [0.00]
Yes, most likely clogged drain, either A/C or roof.
One common cause of a clog is a spider's nest.
I used to have this problem recurrently on a Toyota 20 years ago and it was fairly easily solved with a blast of compressed air.
      09-22-2016, 07:29 AM   #6
RonCawley
RonCawley's Avatar
I've got an appointment to take it to the dealer tomorrow and have it checked out. Thanks for the suggestions, and I'll follow up on what they find.
