2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Aftermarket Amplifier Mounting
      01-21-2024, 04:24 AM   #1
carchrism5
carchrism5's Avatar
Drives: M2, X3 M40i, 911
I'm finally looking at upgrading my audio as the stock HK in the M2 is mediocre at best. Planning on disconnecting center channel, replacing front and rear speakers and new underseat subwoofers. For the amplifier I have seen a few of the full plug and play options like the MATCH, Rezenant, Audison, etc. While they seem to be nice options they also come with a price tag to match and I recently came across the Tehcnic harness that really opens it up to use whatever amplifier you want. So with that if anyone could provide some insight on how they mounted aftermarket amps into the factory location that would be much appreciated as I really haven't seen much so far. Thanks
      01-22-2024, 08:53 AM   #2
MarcoZandrini
Drives: 2018 M240i
I have the AF MATCH amp, and it came with a mounting bracket. But, you've already ruled that option out. So, your next best bet is repurpose the factory amp bracket. If you're handy with tools you could buy a piece of metal to adapt the new amp's mounting requirements to the factory bracket. The bigger issue is to connect the new amp to the factory wiring. That's one of the reasons I bought the AF MATCH amp-plug and play. Here's a link to the audio wiring harness: https://www.2addicts.com/forums/show....php?t=1124786
      01-22-2024, 02:03 PM   #3
carchrism5
carchrism5's Avatar
Thanks, I've seen that amp and it's a pretty good option and easiest to install but looking to see what else can be done. As for the wiring in general, this harness opens up options (https://technicpnp.com/product/7ch-h...hk674-harness/).
      01-23-2024, 08:08 AM   #4
MarcoZandrini
Drives: 2018 M240i
But a new amp that isn't plug and play will require wiring mods.
      01-23-2024, 09:20 AM   #5
carchrism5
carchrism5's Avatar
Wiring a new amp uses the technicpnp harness is both easy and fully reversible.
