07-03-2020, 04:20 AM | #46 |
Rep 26
Drives: BMW 320i Touring (F31)
One thing i have always wondered about wireless carplay - As i have Connected+, Remote Services etc. would it interfere with my range, fuel level etc being written back to the app?
07-18-2020, 02:25 PM | #47 |
Rep 1
Interesting to see there is a solution! I just got a 2018 230i with no Nav or CarPlay; is it possible to have CarPlay added without it being a huge cost?
shawnsheridan steve@codemybimmer Not sure what other information is needed to make this determination; let me know and I can DM |
07-20-2020, 01:20 PM | #48 |
Rep 112
Count me as another one of Steve @ CodeMyBimmer's happy customers. I have a non-Nav 2015 F22 w/ Harmon Kardon (6/15 build date) and Steve set me up with a new screen and head unit to support wireless Apple CarPlay. After the installation, everything works - parking sensor graphics and sounds even got upgraded. I did have to watch a few different videos on YouTube to figure out how to run the new cable for USB through the console to the arm rest, but that was probably the hardest part.
Along the way, I had multiple questions for Steve, and he was always able to get back to me within a couple hours. It made for a relatively quick and clean installation, especially given that the last time I worked on the interior of a BMW, it was an E36! Thanks to Steve and the CodeMyBimmer crew! DBinOC |
09-07-2020, 05:34 AM | #49 | |
Rep 1
And help would be greatly appreciated |
10-02-2020, 12:31 PM | #50 | ||
Rep 2
Car play
I have a bmw 318i (2018) without navigation. I don't really know the exact type of the headunit. But the dealer told me there is a missing item Which is preventing me from adding carplay. But I found this on aliexpress. The seller confirmed to me that this works even if your car does not have navigation in it. Has anyone tried any of these? Does it actually work? Or is there any easier way to add carplay? steve@codemybimmer shawnsheridan |
12-21-2020, 01:20 AM | #51 |
Rep 81
You have plenty of threads one these MMI boxes : https://f30.bimmerpost.com/forums/sh....php?t=1675929
04-11-2021, 03:45 PM | #52 |
Rep 2
I could use some guidance
Hello, My head unit looks the same as the one you posted here. I have a 2018 330i. My HU doesn't have nav, but I pulled it and verified that it has the WLAN port on the back - referencing Steve's post. Can someone point me in the right direction on getting this working? I am new to BMW, but am not new to programming. There are a lot of various posts on this subject, but it looks like this post is what I am looking for.
Thanks. PS - I am willing to pay for the codes. I don't expect a handout |
04-13-2021, 09:57 PM | #53 |
Rep 33
Hi all, I wanted to share how I got Airplay working with my 2 Series!
What I have: - ENAVEVO head unit - SirusXM enabled - Wifi - Bluetooth What I do not have: - Navigation - touchscreen - Wireless charging What you need: 1. Dash trim tool kit (Click here) 2. ENET Cable (Click Here) 3. Depending on your computer, you may need a ethernet to USB port adaptor (Click Here) 4. Windows based machine with Intel processor (This is important) Steps: 1. Install Wifi Antenna (plenty of tutorials out there that were super helpful on this - example of antenna here) 2. Got to Bimmer remote website and purchase the following and schedule a time to have it remotely installed. (Click Here) This site is operated by a forum member Kubax86 All up the process took about 45 min - 1 hour! I really recommend Kubax86 work, super flexible and helpful! Everything was super smooth! |
04-13-2021, 10:53 PM | #54 | |
General
10446
Rep 40,804
Drives: 2018 Alpina B6 650ix GC
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
04-15-2021, 05:58 AM | #55 | |
Rep 351
Currently have ENTRYNAV, can source ENTRYNAV2 with the WiFi port but this would obviously be from a newer production vehicle. Is it beneficial to find a HU that had nav working, or will a nav FSC be required anyway? |
04-15-2021, 10:01 AM | #56 | |
General
10446
Rep 40,804
04-16-2021, 06:21 AM | #57 | |
Rep 351
So once the donor VIN, or any other VIN (matching HU) with nav is used with the activation module it’ll work on my car? I have a question below about connected services but assume this is not retained using this method? Is this the kind of activation module you refer to? Few other points I had in mind to help keep a track on costs and tasks necessary. Feel free to PM if that works better. 1.) WiFi adapter/antenna 2.) HU, either ENTRYNAV2 or NBT EVO 3.) TCB?? Does not exist in newer HU, is there an adapter. How would connected services now be handled. E.g remote unlock subscription, or RTTI 4.) Service history, including upcoming services. 5.) Activation module to allow for coding. 6.) I-step upgrade to get full screen CarPlay 7.) USB CarPlay activation (pre/post Istep upgrade?) - does this have to be original fsc from a source, or similar usb activation methods available online. 8.) OABR cable? 9.) voltage converter for older type 8.8” Does your below quote remain the case? I have found a Technical pdf document for EntryNav, unlike EntryNav2. What are the remaining unlabelled ports that I could not make out? Thanks. Last edited by KTE; 04-16-2021 at 08:46 AM.. |
04-16-2021, 09:18 AM | #58 | |
General
10446
Rep 40,804
No, that is not the activation module I am talking about. The only one I know to work with ENTRYNAV2 is the one from Custom Retroft I provided link to above. ENGTRYNAV2 and EVO requires ATM. If car has older TCB, you will loose Telematics. Activation for ENTRYNAV2 must use Donor OEM FSC Codes and activation module. EVO can be same or use non-OEM car VIN Matching FSC Codes and no activation module. Full Screen on ENTRYNAV2 support was added to 20-07 firmware. ? Connector is GPS Connection. Your GPS Connection is actually USB2 Connection.
08-06-2021, 04:19 PM | #60 |
General
10446
Rep 40,804
08-07-2021, 05:44 AM | #61 | |
Rep 3,056
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
08-14-2021, 04:24 PM | #63 |
Rep 8
New OABR how to connect to Quadlock of BMW
This is the new OABR connector I need to know diagram.
If some body know please let me know. The diagram from OABR to the Quadlock Thanks |
08-15-2021, 05:56 AM | #64 | |
Rep 5
Carplay
Hi shawnsheridan i have X1 F48 (Nov.2017) with Entrynev2 HU ID6 and 6.5" Touch Display. I already added the WIFI antennas to the HU (Brand Magneti Marelli Model EE0001) BMW P/N: 8798035 How i can activate the Carplay trough E-Sys or INSTA-P ? |
08-15-2021, 09:43 AM | #65 |
General
10446
Rep 40,804
Your Receive PM function is disabled. PM me when working.
08-15-2021, 11:58 AM | #66 |
Rep 8
the HU (Brand Magneti Marelli Model EE0001) BMW P/N: 8798035 How i can activate the Carplay trough E-Sys or INSTA-P ? What is the screen part number for 6.5 inch. I have the head unit the same as your Model EE0001 and I want to use 6.5 inch. If you have time please contact me. Thanks |
