11-08-2014, 06:56 PM | #23 | |
lieb923
Rep 49
Drives: '15 M235Xi
11-09-2014, 02:49 AM | #24 |
Rep 104
I am curious if anyone has got a good upgrade option for the low end on the HK system...I don't want to put a box in the limited trunk space and options for replacing the underseat woofers e.g. Focal or stealth mods e.g. BAVSOUND don't appear to be widely available / in use.
11-09-2014, 03:31 AM | #25 | |
Rep 2,337
11-22-2014, 11:35 PM | #26 | |
Rep 765
11-23-2014, 11:57 AM | #27 | |
Rep 272
Those are foam insulators/sealers. I actually had Dynamat sheets with me but elected not to use them on front doors due already existing clearance issue I had with speaker+adapter which as about 25mm thick compared to 20mm thickness of the OEM. I'm sure it would have fitted as door panels were flexible enough and I did not wanted to have bulging area around the speaker panel area. I also do not think it ould have make a huge different as the speaker is a bit de-coupled from the door due to the adapter and thick layer of foam insulation that was added. The rear speakers are not coupled or attached to any metal surface so it will be a waste of money to add deadnening material there. |
11-23-2014, 04:16 PM | #28 | |
Rep 765
https://www.woofersetc.com/p-10841-s...ofer-pair.aspx
11-23-2014, 04:26 PM | #29 |
Rep 2,337
I posted a link to a list of different speaker upgrades available a few posts up. Those speakers are 6.5" vs the 8" OEM woofer. How do you figure they'll drop right in? More like they'll drop right through the mounting bracket. Lol
11-23-2014, 05:03 PM | #30 | |
Rep 765
Or does the SWS 8xi fit with no modifications necessary? Follow up question to SWS: Is the OEM amp strong enough to drive two of these? My guess is no.
11-30-2014, 03:24 AM | #31 |
Rep 356
If I don't have the upgraded HK audio, can I install a sub under my seat?
Plan on tearing out the stock audio and replacing it with something a little better in the future. |
11-30-2014, 09:07 AM | #32 |
Rep 2,337
Your car already has the two eight inch subs under the seats. You can replace them if you want.
11-30-2014, 09:48 AM | #33 | |
Rep 356
Would you happen to know what components (amps, speakers, subs) I can purchase to upgrade each one that fits in the stock mounts? I saw a huge list for 4" speakers earlier, but someone said that it's outdated. |
11-30-2014, 10:39 AM | #34 |
Rep 2,337
Yeah. I posted that. It is a bit outdated.
HK might even use the same speakers, but you get two tweeters and power. I'm personally looking at Jehnert for new subs unless I decide to throw something big in the trunk for low extension. Focal, Mb quart and a few other companies make drop-in replacements, though with a mounting bracket, most 3.5-5.25" speakers with low mount depth should fit the doors. For amps, pm user Technic for a wiring harness and he can set you up to plug in an aftermarket amp. Gonna have to do some research as the options are out there, just not all so easily available. Crutchfield is a good place to start.
11-30-2014, 01:33 PM | #35 | |
Rep 765
11-30-2014, 02:31 PM | #36 |
Rep 272
Amp Upgrade
You don't need line converter if you replace amp with one that accept balanced input like those from JL audio amps.
I recommend getting Technics' hardness so you can do a clean install without cutting any wires. I will be using a 6 channel amp JL audio XD600 and skip center channel. It actually sounds better without center channel speaker. Here is my amp with wire hardness. I only need to unplug 42-ping plug from the amp and plug the hardness adapter and connect +12V and ground wire. I've not installed it yet as I'm being lazy and not in a hurry as having done speaker upgrade already has tremendously improved the sound. |
11-30-2014, 04:13 PM | #37 |
Rep 2,337
You only need the LC6i or some other line output converter if you plan to tap into the speaker lines and will not but amps that accept speaker level inputs. You can get the harness from Technic too.
11-30-2014, 06:33 PM | #38 | |
Rep 6,934
Drives: 2018 M2 AW DCT
11-30-2014, 06:43 PM | #39 |
Rep 2,337
12-02-2014, 12:15 PM | #40 | ||
Rep 817
Drives: E30 M3 Darth Vader Trackcar
T |
12-02-2014, 01:34 PM | #41 |
Rep 2,337
I just sent an e-mail to Don at Exquisite Marketing for price quotes on the drop-in sub replacements and the full front soundstage kit by Jehnert.
12-02-2014, 06:15 PM | #42 |
Rep 2,337
I might order these. Have been e-mailing Don with questions about the set and he seems accessible and like he knows what he's talking about. First off, these are not MB Quart rebrands - they are built in the old Ehmann factory in Germany where the old MB Quart speakers were manufactured. If you guys know about car audio, you know MB Quarts used to be extremely good back in the day.
MB Quart makes a QM200.3BMW which is similar to what you get with BAV Sound. That being said, these are much more expensive than your average drop-in replacement system. Compare the MBQs at $399 for six drivers and two crossovers and $859 for the Jehnert set (which includes the same front sound stage replacement - minus the center channel as no one seems to care about it ). Don also sells the underseat woofers separately for $459 without crossovers. Even though these will work as drop-ins (which is probably how I'll start the upgrade), a dedicated amp would be best to run an active setup with proper crossover points. I think the nice thing about something like this is especially with a lease, you can put the stock system back in and use this for the next car. The BMW lines don't seem to change much from year to year. So this could potentially save me from purchasing upgraded audio on the next Bimmer too.
12-02-2014, 09:17 PM | #43 | |
Rep 765
12-02-2014, 09:30 PM | #44 |
Rep 2,337
That $459 was for the pair and it includes the spacer brackets for guaranteed fit. Plus these can play down to 50hz, but the stock cross points might filter before then.
I like the full set since they have real components for better imaging like the HK. But these should sound much more crisp. Not sure anything can be done about the insulation though... |
