02-13-2020, 12:58 PM | #67 | ||
Bimmer Nut + Software Dev
555
Rep 802
Drives: 2018 Audi S3 IE Stage 1
Current: 2018 Audi S3 IE Stage 1
Past: '08 Infiniti G37S, '87 Porsche 944 Turbo, '13 328i, '15 M235i, '15 F80 M3, '16 M235i, '15 335i, '17 X5 xDrive35i @whoismorggan |
02-13-2020, 01:11 PM | #68 |
Rep 3,506
Indeed it would. I'm in agreement with XutvJet that the increase in grip will transform your car's front-end handling.
02-15-2020, 03:28 PM | #69 |
555
Rep 802
VRSF 5" intercooler installed today! Started at 10:00 am and ended up finishing around 1:30 pm. Not terribly difficult. Just a lot of screws/bolts to remove. We had trouble with the cold side getting caught on the charge pipe spring clip.
Gave her a good wash afterwards and then flashed MHD Stage 2+ until Bob dyno tunes it next week.
Dylan861330.00 |
02-19-2020, 02:32 PM | #70 |
555
Rep 802
Got the car dialed-in by Bob at Stage Fab today. Results are 377 WHP / 438 WTQ
AmuroRay2315.00 |
02-19-2020, 02:49 PM | #71 |
Rep 2,214
Not bad, is this an OTS tune? Numbers seem consistent with off-shelf tunes for MHD/BM3 but would be a 20-30whp lower than most custom tunes I've seen, with equal mods.
Also, what altitude are you at? D
02-19-2020, 03:27 PM | #72 | |
555
Rep 802
Agree that it seems a little low
02-19-2020, 03:38 PM | #73 | |
Rep 5,385
If you want to gain some power, simply convert to STD (~+3%). So that means using the STD calc, your car is making ~390whp and ~455wtq. That's quite stout, especially on the torque side.
whoismorggan555.00 Dylan861330.00 |
02-19-2020, 03:51 PM | #74 | ||
555
Rep 802
02-19-2020, 03:54 PM | #75 |
Rep 5,385
Here you go.
whoismorggan555.00 |
02-19-2020, 04:59 PM | #76 |
555
Rep 802
Hell yea, that looks great. Are you lowered or stock springs?
02-20-2020, 12:30 PM | #77 |
Rep 5,385
Thanks. Dinan springs with 1/4" lift spacers in the back only. I really wanted the rear springs because they are 30% stiffer and these car's tend to be bouncy in the rear with the stock springs. The Dinan's lowered the rear ~1" (nearly 1.5" without the spacer) and better matched the stock spring rate of the front. I have no desire to add the Dinan's to the front because I feel the front axle spring rates are good, the wheel gap is fine in the front (~1"), and the Dinan front springs are only about 8% stiffer. The chassis dynamics feel so much better with the Dinan springs out back. It was really surprising to me the difference.
02-25-2020, 02:29 PM | #78 |
555
Rep 802
Very cool. Love the look. I've seen other 2ers dropped on springs and the front always looks too low imo. Where did you purchase the 1/4" lift spacers? And did you have to buy the front/rear spring set or did you find rear springs separate?
02-26-2020, 11:47 AM | #79 | |
Rep 5,385
The spacers are available from Dinan and they are hilariously expensive for a piece of solid and round 5mm thick white plastic ($100). But since they fit perfectly and raise the rear a much needed 1/4"+ inch, I said screw it and bought them. The improved spring rate makes a big difference in perceived chassis control from the seat of the pants. The chassis feels way more controlled and a bit more taunt out back and much of rear axle's secondary motions reduced significantly. I'm not sure if they actually improved handling or not because I don't track the car. You do have to buy the springs as a set. It's expensive for just two springs ($450 with the spacers) but they are quality pieces, improve the look, and improve the chassis. It was worth it for me.
02-28-2020, 01:25 PM | #80 | |
Rep 32
02-28-2020, 01:37 PM | #81 |
555
Rep 802
Not yet! I need to clock some new 0-60 runs in RWD mode soon. I've been wanting to see how they are after my new tune
03-01-2020, 03:28 PM | #82 |
555
Rep 802
3.69 0-60 run today! Pretty impressed
03-04-2020, 05:35 PM | #83 |
555
Rep 802
Updated my navigation with the 2020 maps. Found a torrent link on here and partitioned a 1TB drive I had lying around. Only problem was the torrent did not include a .nmf file that I had to add manually.
03-05-2020, 06:49 PM | #85 |
Rep 5,385
03-07-2020, 11:24 AM | #86 |
Rep 187
subd
03-18-2020, 08:33 PM | #87 |
555
Rep 802
Finally received the alcantara steering wheel I ordered from Spain on eBay. Tri-color stitching with red indicator stripe and it retains the heating function!
Installation was a b$@%h. Couldn't get the airbag released for an hour or so, and then I had to cut away some of the material so the trim would fit flush. THEN, as I was removing both paddles the wires stripped out from their connectors. So, will be running paddle-less until I can get new ones ordered But, overall the steering wheel looks and feels AMAZING. So happy with how it turned out.
Dylan861330.00 |
03-19-2020, 11:37 AM | #88 |
555
Rep 802
More photos in daylight:
