02-11-2024, 09:57 AM | #1 |
1296
Rep 3,533
Drives: 2017 m240i, 2015 X3 x35i
Car is a 2017 m240, xdrive. Stock ride hight.
Wheels 18x8.5 +32 18x9.5 +35 Tires 225/40 255/35 It looks like this will clear front and rear with some poke correct? Doesn't even look like any crazy camber need to be done either... but I'm no expert, can anyone chime in before I order? Thank you!
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
02-11-2024, 11:22 AM | #2 |
Rep 5,550
From my experience and what I’ve read, the rear will not fit. A more aggressive 9.5” wide wheel offset would be in the 42-45 mm range and a conservative offset would be 58 mm. Your front fitment is also more aggressive than the typical aggressive offset of 35 mm for an 8.5” wide wheel. 8.5” conservative offset is 40-45 mm
n55david1295.50 |
02-11-2024, 04:17 PM | #4 | |
1296
Rep 3,533
02-11-2024, 06:43 PM | #6 |
1296
Rep 3,533
Gotcha.. so this would rub on the fender? Damn fitment industries and their fitment guide sucks lol
02-11-2024, 07:05 PM | #8 |
1296
Rep 3,533
Would it work with an 8.5?
02-11-2024, 07:24 PM | #9 |
Rep 5,550
02-11-2024, 07:25 PM | #10 | |
1296
Rep 3,533
The problem.is, I really want to run a certain wheel for the price, weight etc and would love the extra tire put back for the new turbo. I don't wanna run apex as they are heavier than I want.
02-11-2024, 07:39 PM | #11 |
Rep 5,550
No. It would barely work with a stretched 225 tire on the rear. To run a 255, you need an 8.5et45, maybe a 8.5et40 with decent rear negative camber. I’d recommend 8.5et45 over an 8.5et40. A front 8.5et45 with a 255 may require a spacer depending on the dampers you have.
02-11-2024, 07:41 PM | #12 | |
1296
Rep 3,533
Thanks for all the help!
02-12-2024, 01:02 PM | #14 |
1296
Rep 3,533
02-12-2024, 01:38 PM | #15 |
Rep 5,550
Front should be fine with a 225/40-18, may require some negative camber if it’s a wider 225 tire (depends on the brand/type).
Rear 9.5et45 with a 255 is very aggressive and will likely rub even with -2 deg of camber. 9.5et58 is ideal and your 9.5et45 is 0.51” more outboard. The most aggressive you’d probably want to go in the rear with a 9.5 would be 9.5et52 but it’ll require some negative camber (at least -2 deg, possibly more). I’m running a rear setup that’s equivalent to a 9.5et50 BUT it’s running a stretched 235 tire. It would definitely rub with a 255 tire. I’d say 9.5 with an offset of 52-58 (closer to 58 is better) is where you want to be for a simple direct bolt on setup. The width of the 255 also needs to be accounted for. There can be a 1/4-1/2” difference in 255 section and tread widths. Which tires are you planning on running? Is your car lowered? |
02-12-2024, 01:42 PM | #16 | |
1296
Rep 3,533
02-12-2024, 02:18 PM | #17 |
Rep 5,550
Is your car lowered or do you plan on lowering it?
The DWS06 runs close to nominal 225 and 255 (0.2” and 0.1” narrower tread width front and rear, respectively). If you’re not lowered and you don’t mind an aggressive setup then the 9.5et45 might work but you’ll likely need to dial in more negative rear camber. I personally would not run this setup. |
n55david1295.50 |
02-12-2024, 02:19 PM | #18 | |
1296
Rep 3,533
I'm checking to see if they have a et50 instead if the et45
02-12-2024, 04:16 PM | #19 |
Southern Fried
139
Rep 140
My rear VMR's are 9.5 +45 and I run 255's with no rubbing or added camber.
Stock suspension. |
02-12-2024, 04:59 PM | #20 |
1296
Rep 3,533
Which ones do you have?
02-12-2024, 06:26 PM | #22 |
1296
Rep 3,533
Wow, okay. Thanks for this!
Jcoop901138.50 |
