2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Need help on wheel selection to clear AP brakes
      10-22-2022, 12:58 PM   #1
Cattanachc12
Drives: BMW M240
I'm looking for some advice on wheel selection.
Bought some AP radical 6 pot calipers and 383mm discs
I need wheels that would clear them and really want Apex ARC-8, i would prefer to stay 18", can anyone point me in the right direction of size and ET to buy. Would prefer not to use a spacer if i can.
My standard 18inch wheels aren't a million miles away from fitting so hoping not to go to big.
Pictures might hopefully help
      03-16-2023, 03:21 PM   #2
McBobby Jr
McBobby Jr's Avatar
212
Drives: '18 240i xDrive
Sick brakes btw, I’m curious as well. Anybody know of any 18” wheels that will clear a big brake kit?
current
'18 F22 240i xDrive - FBO
'16 F82 M4 ZCP - FBO
previous
'08 E90 335i Montego Blue
      03-17-2023, 07:09 PM   #3
LanceM26
LanceM26's Avatar
Drives: BMW M235i, BMW M240iX
You can email apex btw, they provide lots of help with BBK clearance. I did the f80 f+r brakes on my car and the arc-8 18.8.5 et38 do not clear. Apex EC7 has the most clearance
      03-18-2023, 04:15 AM   #4
McBobby Jr
McBobby Jr's Avatar
212
Was it the rotors that didn’t fit or the calipers?
current
previous
      03-18-2023, 04:16 AM   #5
LanceM26
LanceM26's Avatar
Calipers didn’t clear the barrel.
      03-18-2023, 04:18 AM   #6
LanceM26
LanceM26's Avatar
To add, the 1 series (e82) group is a good source of wheels that will work.
      03-18-2023, 04:19 AM   #7
McBobby Jr
McBobby Jr's Avatar
212
You had the standard 4 piston front / 2 piston rear setup correct? That should fit on an 18” wheel.
current
previous
      03-18-2023, 04:22 AM   #8
LanceM26
LanceM26's Avatar
Yes, 380mm fronts and 370mm rears.
Not all apex arc8s are made equally. If you go to the apex fitment page on f80… they specify that only some arc8s have bigger barrel clearance designed for f80. The ones that fit 2er (18x8.5 et38) are not part of that.
      03-18-2023, 04:24 AM   #9
McBobby Jr
McBobby Jr's Avatar
212
That sucks to hear, this chassis is somewhat problematic when it comes to finding the perfect wheel/tire setup.
current
previous
LanceM26115.50
      03-18-2023, 04:34 AM   #10
LanceM26
LanceM26's Avatar
I just bit the bullet and bought some vs5rs. I’m gonna buy EC7 for winter
      03-18-2023, 06:04 AM   #11
McBobby Jr
McBobby Jr's Avatar
212
The VS-5RS wheels were my top choice, however I’m trying to stick with a square setup and a lower offset but it doesn’t look like that will happen until some suspension modifications are done. Titan 7 TS-5’s or BBS RI-A’s are my next option. But it looks like some camber plates and other mods will be necessary regardless.
current
previous
      03-18-2023, 11:23 AM   #12
LanceM26
LanceM26's Avatar
I got the 18x8.5 et 40 VS-5RS, I'm already upgraded to ohlins R+T and Millway camber plates
      03-19-2023, 08:06 PM   #13
McBobby Jr
McBobby Jr's Avatar
212
Sweet, how do you like the Ohlins Coilover system?
current
previous
      08-19-2023, 06:30 PM   #14
SmellyGreek
SmellyGreek's Avatar
Drives: Estoril Blue F22 M235i
Hey I bought the same front wheels and doing some rudimentary measurements it’s not looking like the 4-pot Brembo calipers will clear the barrel (even if you clip the anti-squeal weights on the pads). Did you get them to fit? I’m also on Ohlins w/ cambers plates btw.
      08-19-2023, 07:13 PM   #15
LanceM26
LanceM26's Avatar
They cleared you can dm me on insta I have some pics and videos of the clearance
      12-28-2023, 04:01 PM   #16
M3SQRD
M3SQRD's Avatar
2164
Drives: E92 M3,G20 330ix,F22 240iX,F82
World Radi-Cal II calipers are designed to fit 19” wheels but will clear certain 18” forged wheels with large frontspacing and maximum barrel diameter. Specific Forgeline wheels will clear the CP9562 caliper and 380 mm-dia rotors. Brembo GTS with 380 mm-dia rotor setup has the same issues with 18” wheels - very limited 18” will clear the caliper. You’ll need to print their caliper fitment template and try it on 18” wheels to find a set that fits.
