03-17-2024, 12:36 AM | #1 |
Rep 61
Is anyone going to HPDE this year at pocono raceway?
Some tips would be appreciated for my first time at HPDE 1 level. I was thinking new michlin PS4’s, hawk pads all around, and motul 660 brake fluid. Suggestions would be great as its my first time and I’d like to be prepared. Thanks all! P.S. currently running BM3 stage 2+ on dorch DS2. Thinking about going backwards to stage 1 or 2 for a little less power to really get the hang of track driving. |
03-17-2024, 08:14 AM | #3 |
Rep 423
Drives: F87 M2 DCT, F15 X5
In the context of it being your first time, your plan sounds good and I would get the power to as close to stock as possible. This event will be about having fun and learning the car, the track, and yourself. You're years away from needing more power to progress your skills
What Hawk compound?
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport Sold in 2023 '12 F30 335i 8AT Sport Line Sold in 2020 '08 E92 335xi 6MT Sold in 2016 '08 E90 335i 6MT - FBO |
03-17-2024, 11:02 AM | #4 | |
Rep 61
03-17-2024, 02:32 PM | #5 |
Rep 423
That should be perfectly fine for your first season. Once you gain more experience and can drive the car harder, you must upgrade to a proper track compound on at least the front brakes. When your skills outpace your brakes, you will notice rapid brake pad wear. You might go through a set of front pads in 2-3 track days.
‘18 F87 M2 DCT
03-17-2024, 09:05 PM | #6 |
Rep 33
You'll probably be HPDE 1 only and riding around with all the other newbs. Usually not going to be passing or running out too hard. Pads/fluid good. Learning the basics on street tires is best. Experience the limits. Learn to listen and feel what the tires are telling you. It will only make you better.
03-17-2024, 09:56 PM | #7 | ||
Rep 61
03-17-2024, 11:30 PM | #8 |
BimmerPost Supporting Vendor
4725
Rep 2,554
First event - basically the goals for the event should be developing your comfort level and awareness of everything that is going on. Make sure you can spot every flag every time around. Make sure you know where any and all cars are around you at all times. Don't worry about pace - it's not a race and there is no award for winning the HDPE cup. Relax, get comfortable, and work on building your awareness level. Once you are comfortable with your surroundings the learning curve can start to take off. Head on a swivel - do not get tunnel vision and/or start to drive out of your mirrors. If someone catches you give them the point by when appropriate and keep on doing your thing.
Brakes - keep in mind that using DSC and tripping it frequently can add quite a bit to the brakes (including the fronts). If you are not going to go with a dedicated track pad absolutely keep a close watch on the braking system (including pedal pressure, stopping distance, etc). Should always be doing this but just something to remind yourself during the event. Tires - PS4's are an excellent learning tire but even if tech passes tires showing dry rot I'm not sure I would still want to run them on the track... When I first read the thread title I though maybe the Mpact event at COTA. If so was going to tell you that you were more than welcome to take a ride along with me if so (we are sponsoring the Track X event they are having there). If they allow passengers at the Pocono event then you might try to catch a ride with someone with experience if you haven't been shotgun on the track before (and preferably in an M2). This can really open your eyes on what the cars are capable of. Doesn't mean to go try to match that immediately but can give you an idea of how capable these cars are. And most importantly - do not forget to have fun!
03-17-2024, 11:35 PM | #9 | |
Rep 61
Thanks everyone, excited for my first time! |
