2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum The 100,000 miles Club
      07-06-2023, 06:00 PM   #23
German1967
German1967's Avatar
Drives: 2015 M235xi - 2022 992 C2S Cab
[QUOTE=mecheng77;30284134]Congrats! Report back with a comparison
Any other repairs needed?
That was a typo. Car is in great condition. 😊
Hoc Lapidem Non Vi Sed Saepe Cadendo!
      07-06-2023, 06:53 PM   #24
james4321
Czech_Republic
38
Drives: 335i+
129k here 2016 M235i. Still pushing strong.
Stage 2+ was put on at 100k.
Cos270608.50
      07-07-2023, 06:07 AM   #25
morphomeman
morphomeman's Avatar
593
Drives: 2015 M235ix
2016 BMW X3  [0.00]
2015 BMW M235ix  [0.00]
Every once in a while, I do a virtual build of a new 240, but honestly, I am perfectly content with my 2015 235x and I don't see much of a difference in the new model, based on reviews. Admittedly, the mileage is just shy of 60,000 and I can imagine wanting to get a newer car at double that number.
I kept my 325 until it had 160,000 miles on it and the mechanic begged me to get rid of it, because it was costing as much to maintain as it would to pay for a new one. I might wait until that point, though my grandson might be driving the car by then.
Cos270608.50
      07-07-2023, 08:26 PM   #26
Hapbob
Hapbob's Avatar
230
Drives: M240 2018
I bought it with 19135 now at 19800.
Doubt I’ll get 5K a year.
Long winters here and I won’t drive it.
That’s the story for now.
Hap
      07-07-2023, 09:53 PM   #27
60_Driver
60_Driver's Avatar
Drives: 2016 M235i 6mt vert
Same here with long NH winters & young kids that make it easier not to swap the carseats into the 2. Oh well, someday we’ll get some mi on her
      07-13-2023, 10:57 AM   #28
CardsWin
Rookie
Drives: 2017 230i with XDrive
Just bought a 2017 230i XDrive with 70k miles...
I'm waiting for service records from "near local" BMW Dealership.
Without knowing anything about the car's history - what are some things that I should have checked out between 70k and 100k?
My previous car was a 2001 Audi TT Quatro Turbo... I bought it 12 years ago with 80k miles... and it now has 134k.
      07-13-2023, 01:04 PM   #29
alig2
Drives: 2018 230ix, F5 Cobra
91k on 2018 230i XDrive.
Routine maintenance at factory intervals, except for trans fluid at 60k.
Only issues:
Pass taillight at 50k (warranty) common problem.
Coolant overflow hose at 70k (CPO warranty) common problem.
Mouse ate wiring harness at 88k, not a common problem.
      07-13-2023, 01:17 PM   #30
CardsWin
Rookie
Only issues:
Haha! To those of us that live around the corn/bean fields, it might be more common than others!
So - I need to do the trans fluid if it isn't showing up on the service records (which I'm assuming it will not - why sell it if you just changed it).
      07-13-2023, 01:58 PM   #31
MC77
Drives: BMW 228i
Yes, find an indy to do your transmission fluid/filter. Should be 500-600$. Dealership won't do it. Plugs if not done already
      07-14-2023, 02:16 PM   #32
Ajowhan
Drives: m240i 'vert
62.5k miles on my 2018 m240i. Got this slightly over 2 years ago at 22k miles. Will likely join the club in 2025.
Water pump leak coolant and was replaced at 53k-58k miles, Cant remember which.
Stage 2 since 38k miles
      07-14-2023, 09:27 PM   #33
B58togo
Drives: M240i
72k, but 64k of that was from 4/2017 to 7/2021. I've laid off the miles considerably the past two years. Stock turbo let go around 64k; went with the Vargas GC since DAW and Pure were running two month lead times in 2021. Upgraded to the Pure 800 cast/DS2 this past spring. Then the ZF8 started slipping, so sent it off to Pure Drivetrains for some Stage 1 love. Otherwise, just pads @ 37k (gonna do pads/rotors this fall), lots of tires, wiper blades, cabin filters, oil changes, brake fluid flushes, coolant flushes at the turbo swaps, plugs every 15k or so, coils at 64k, injectors @ 71k. Installed a slightly used LSD @ 36k, so should probably think about swapping out that fluid soon.
      07-15-2023, 04:11 AM   #34
mecheng77
mecheng77's Avatar
Drives: 2007 328i / 2014 M235i
  [0.00]
  [0.00]
Wow, that is very low mileage to blow both a turbo and transmission!
Cos270608.50
      07-15-2023, 09:55 AM   #35
nikijack
Drives: 2016 M235i, Grey, manual
208,000 km.
      07-15-2023, 12:56 PM   #36
Trilllz
I may hold the current record.
I'm currently @ 138,0000 miles.
Mine has been completely stock it's whole life, but driven quite "spirited". I've consistently changed the oil myself for the entire life of the car @ 8,000 miles.
My vehicle history looks similar to many others I've seen.
@ 30,000 BMW replaced the blower motor for the climate control.
@ 40,000 BMW replaced the charge pipe.
@ 55,000 BMW replaced the Oil Filter Housing Gasket & Tranny Fluid change.
@ 107,000 I replaced:
  • Fuel Rail Pressor Sensor;
  • Coolant Temp Sensor;
  • Valve Cover;
  • Tranny Pan;
  • Brake Fluid Change;
  • Spark Plugs Replaced; and
  • Replaced all Fuel Injectors.
Overall, it has been highly reliable.
UPDATE 12/2023:
Currently @ 149,000
I recently got a fault code for the thermostat and Cat.
I'm currently in the process of replacing;
  • thermostat (code)
  • water pump (while im there)
  • belt tensioner (while im there)
  • belt (old belt)
  • pulley (while im there)
  • coolant hose flange (while im there)
  • oil filter and cooler gaskets (leaking)
  • oil cooler line o-rings (leaking)
  • charge pipe (while im there)
  • cabin air filter
  • Cat (to examine if it needs replacement or just cleaning)
  • ignition coils (no code, but very rarely have a split second loss of power when under hard acceleration at higher speeds)
harma24402.50
      07-15-2023, 10:02 PM   #37
B58togo
Drives: M240i
That's what happens when you push the envelope. Was likely somewhere around 650 ft lbs at the tire when the trans started slipping.
mecheng771006.00
      07-16-2023, 05:29 AM   #38
mecheng77
mecheng77's Avatar
  [0.00]
  [0.00]
Valve Cover;
Tranny Pan;
Brake Fluid Change;
Overall, it has been a highly reliable.
Why did you change the injectors, coolant temp sensor and fuel rail sensor?
Cos270608.50
      07-17-2023, 10:28 AM   #39
Trilllz
Coolant Temp Sensor as preventative maintenance.
I had a check engine light on due to the fuel rail sensor intermittently failing, so changed that as well. I forgot the actual code the led me to that diagnosis.
The injectors were done after I had done the valve cover gasket, and figured while I was in there, I'd replace the injectors as well. I also replaced all the spark plugs since I was in there.
I was going to do the ignition coils as well, but my research indicated that it wasn't a part that failed very often. I probably should have changed them since I was in there anyways.
mecheng771006.00
      07-17-2023, 04:56 PM   #40
mecheng77
mecheng77's Avatar
  [0.00]
  [0.00]
Ok because I never heard of widespread injector failures on the n55, that was an n54 problem with the piezo injectors.
I wouldn’t worry about the coils, they are easy to change. On my 328i, one just failed at 150,000km, so I replaced them all, but I think the more modern BMWs don’t have this issue
Cos270608.50
      07-20-2023, 11:23 AM   #41
farshman
farshman's Avatar
Drives: 2015 228xi
Originally Posted by harma24 View Post
I'm at about 104,000 miles in my 2017. Like you, I changed all the lifetime fluids changed at 60k and plan to do so again at 120k. Unlike you however I have not had any other major issues with the car (other than windshields; I've had two cracks in the exact same way while using defrost).
What are the "lifetime fluids"?
      07-20-2023, 07:04 PM   #42
harma24
Oh, you've got me beat! I'm only at 123,000 miles!
There's no such thing as a lifetime fluid, but BMW claims the transmission fluid is good for the lifetime of the vehicle for some reason. I guess in a sense they are right; if you don't change it, the transmission will fail, and most people would scrap the car at that point!
I did both differentials and the transfer case at the same time as the transmission at 60k, and just did them again at 123k.
Family Cars: 1993-2014: 1993 Honda Accord 10th Anniversary Edition | 2014-Present: 2014 Honda Odyssey
Stable-mate: 2019 - present: 2020 230xi Seaside Blue Convertible
Cos270608.50
      07-22-2023, 04:42 PM   #43
Trilllz
Congrats! I wish you many more trouble free, enjoyable miles!
      07-26-2023, 12:56 PM   #44
P0!ntBlank5436
Drives: 2015 F22 M235i Xdrive
Going at 95k here!!
Only some minor issues to date:
  • CP replaced, cracked when installing DP
  • Coolant overflow hose cracked, but thankfully was close to a shop when it happened
  • Blower motor failed, I think some leaves got in the HVAC system since this isn't common
So sad to say that I am finally giving my m235i up and trading up to a 23 m2
