2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning CEL 194606
      12-20-2023, 04:59 PM   #1
F22Cam
F22Cam's Avatar
61
Drives: ‘15 Bmw M235
2015 BMW M235  [9.25]
CEL 194606
Hi all, just looking to see if I can get some help on what may be causing this code.
I recently got a catless downpipe installed. All good and cel came on about 5 days later, I assumed it was for the dp.
Today I flashed bm3 stage 1. I enabled the setting to clear the cat codes and flashed. All went well.
However after I started my car 2 hours later the CEL came back on showing this code.
Anybody have this happen before and know the cause/fix ? I just find the timing super odd because I don’t think this code is cat related. Thanks
      02-26-2024, 08:09 PM   #2
albexl2006
Drives: 2013 BMW 528i
For anyone having this issue. It is a DMTLH line disconnection (broken or shorted somewhere inside the car). It is the communication cable from the NVLD to the DME. You would need the wiring diagrams to see exactly where are your modules and which pins connect them. You would basically need to run new cable from the NVLD to the DME. Check this video out for reference:
      02-26-2024, 08:16 PM   #3
F22Cam
F22Cam's Avatar
61
https://youtu.be/XE8DsG8tl4o?si=YnlBGY8cIde4X2a9
Thanks for the video. I have since coded this out with bm3.
