2Addicts | BMW 2-Series forum Technical Topics Tracking / Autocrossing DIY Brake Cooling Ducting
      06-26-2022, 03:22 PM   #1
BillG2A
BillG2A's Avatar
Drives: 2017 M240 6spd.
I have experienced very high front brake temperatures using stock 340mm rotors Moutol 660
And Hawk DTC 70 pads at longer tracks like Road Atlanta. Calipers discolored and piston dust seals appeared compromised.
I installed Porsche Gt3 open ducts on front thrust arms to direct air. That helped some but am looking for more.
A little research I took measurements and mocked up a few different configurations with cardboard and paper then ordered from Pegasus and summit . I am now doing final fitting using CF duct tape and the parts: 3" double walled hose , partial backing plate/spindle flange with 3" Outlet and 3" ring and clamps.
The goal was get air from front bumper /inner wheel well duct to the inside rotor hat. There is not much room but enough. I am close to having it fit with 235/40/18 front tires with a 20" length of 3" hose. It is a good fit but I am getting rubbing at full lock right (picture #5 upper left hand corner) I believe if I swap out the round flange I have on the inner wheel well to a NACA angled duct I can clear the tire at full lock wish me luck
Also I recently installed 380mm F8x m2/m3 rotors using brackets and stock rotors That should give me more gear sink a larger center hub and better inner rotor vane design to pump air through rotors.
dradernh4413.00
msendit424.00
      06-26-2022, 07:55 PM   #2
ggggbmw
Drives: 2017 M2 Manual
A valiant effort and I wish you luck. Is there any way to get the hose outlet closer to the inside of the hub? The 3rd picture looks like the outlet is facing the inside brake surface, and not the center of the brake hub. Also looks like a fair amount of flange on the hub side of the outlet that could be trimmed if there is any inside clearance.
Also curious what wheel studs those are. They don't look like anything else I've seen.
BillG2A69.50
      06-26-2022, 09:49 PM   #3
BillG2A
BillG2A's Avatar
Appreciate your comment - the hose is currently positioned toward inside rotor surface which is undesirable. , I can trim about 1.5 " from the bottom of the spindle duct and otherwise position it lower on the hub for better alignment with air to hat. See pictures below for final targeted placement. These spacers have ~ 3" inner diameter. Also note I just installed SPL mono balls (last picture- not easy)
Looks like About 60% of air would be directed to rotor hat I may also weld a metal or insert a plastic diverter inside hose spindle bracket to direct 100% of air to hat. Removing the backing plate completely is preferable to have a cooling hose to the rotor surface, which would likely lead to crackled rotors
The stud conversion kit is by TPI These are Grade 12.9 carbon steel race studs. I found them at Tirerack last year for $39. I should have bought 4 sets. TireRack said they overbought quantities for their test fleet of BMW's And had them on clearance TPI shut down during COVID and while open now does not make these
I just bought backup stud set Grade 10.9 for $150 from Turner
Bill
ggggbmw432.50
      07-01-2022, 07:33 PM   #4
ggggbmw
Dang. That would have been nice. I especially like how they have flats you can use instead of relying on double-nutting. I have the Bimmerworld studs, and they are nice, but very pricey. I'll have to make a note to look for the TPI studs the next time I need them.
      07-04-2022, 01:17 PM   #5
BillG2A
BillG2A's Avatar
Next installment -DIY
Almost done - Got clear NASA ducts which move hose inboard a few inches. Cut spindle bracket to feed air more towards rotor hat.
      07-04-2022, 01:29 PM   #6
BillG2A
BillG2A's Avatar
Final remaining issue is that at full lock 235/40/18 front tires is making contact with duct. (See last picture below) It looks like I only need 0.5 - 1.0" more clearance. I can get that by moving the duct a little more inboard or by using a heat gun and reshaping the back of ducts
Final fitment coming soon
Bill
ggggbmw432.50
      07-07-2022, 12:52 PM   #7
jb-slow
Drives: m235i
Have any pictures of the Porsche ducts? Where did you get the caliper brackets?
      07-07-2022, 09:36 PM   #8
BillG2A
BillG2A's Avatar
Here are pictures of open Porsche Gt3 brake ducts , brackets were from Kearn from Ohio he has a YouTube channel. Search my posts I posted his email address in a brake comment
Bill
      07-27-2022, 10:07 PM   #9
BillG2A
BillG2A's Avatar
Tested the M2/3/4. 380mm front rotors at Road Atlanta this weekend. Did not use full brake ducts and hoses. But did test fit/clearance of driver side duct - it was a fail , at full lock the tires tore up the duct. Picture below.
I refit using a heat gun to reshape the ducts for more clearance Front clearance is now fine but side clearance between tire and sway bar is not enough .
I reshaped the 3" duct / hose outlet to ~ 2.25 x 3.25
But have to thin it to under 2"
The good news was there was no brake fade with the larger rotors on the m240. I may not need the brake ducts
msendit424.00
dradernh4413.00
ggggbmw432.50
      08-21-2022, 04:13 AM   #10
LanceM26
LanceM26's Avatar
Drives: BMW M235i, BMW M240iX
I discolored my brakes, what symptoms did you get from compromised piston seals
      08-21-2022, 07:23 AM   #11
BillG2A
BillG2A's Avatar
Hi I just edited my post to be more precise . The piston dust seal boot gasket looked compromised.
See picture below. The actual seals are inside the caliper look like flat "o" rings. Their job is to seal in brake fluid. It was the visual inspection of the dust boot gasket that had concerned me. The functionality of brakes was fine / not compromised
In fact the seals when I finally removed them were in very good condition.
I had read other member's track experiences which in the extreme included leaking calipers and a brake fire.
I bought rebuild kit from bimmer world and replaced the seals and gadgets
aerobod3625.50
      08-21-2022, 10:49 AM   #12
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
Did you have to remove the calipers to do the cylinder seal?
I did one of the dust boots in mine cause when i was swapping pads I noticed one had a puncture.... It was a pain in the ass to put the dust boot in.... seems like the caliper needs to be pushed out a bit and you need to use a couple of pick tools at the same time to prevent one side from coming off while seating
      08-21-2022, 05:04 PM   #13
BillG2A
BillG2A's Avatar
I did remove them from car and used compressed air to push out pistons. The seals were tough to remove. Hardest part was pushing out pistons at same time to a position I could remove them. They were very tight.
      08-27-2022, 07:47 PM   #14
edycol
Drives: 2011 328i xDrive
Titanium shims on pads?
      08-27-2022, 08:10 PM   #15
BillG2A
BillG2A's Avatar
Have not tried that
      09-02-2022, 09:25 PM   #16
edycol
Have not tried that
Try it. Titanium is worst heat conductor.
      09-02-2022, 11:19 PM   #17
aerobod
aerobod's Avatar
3626
Although for a metal Titanium has low thermal conductivity (25 W/mK compared with steel alloys in the range of 30 to 60 and aluminium alloys in the range of 150 to 250), brake pads are typically around 4 W/mK.
With 10mm of pad thickness, a 5mm steel backing plate and a 0.5mm shim, assuming steel conductivity of 45 W/mK, then a 0.5mm titanium shim would only reduce thermal conductivity by 0.34% compared with a steel shim of the same thickness.
      09-05-2022, 10:20 AM   #18
edycol
ISK, I know a lot of guys on M2 are using it. Worth trying.
      09-05-2022, 11:22 AM   #19
aerobod
aerobod's Avatar
3626
Inconel would be better with a thermal conductivity 60% that of titanium and a similar raw material cost, but will also have fairly minimal effect in a thin shim.
      09-07-2022, 05:48 PM   #20
CSBM5
CSBM5's Avatar
2723
Drives: 2019 M2 Comp, 2011 M3, etc
It's not just the thermal conductivity of Ti that's useful (especially since the thickness of the typical plates/shims is very small to begin with, hence not a huge help in reducing thermal conduction)...the main thermal resistance added to the path from the backing plate to the piston(s) is from the two added thermal interfaces that the introduction of the Ti plate in the heat path creates. Additionally, the Ti plate shields the dust covers from "seeing", from a radiation heat transfer point of view, the hot backing plate surface. That Ti plate sort of floats 95+% of the time (until the transient brake application) with convection off it and runs at a much lower surface temperature than the backing plate; hence it is a nice benefit to protecting the piston dust covers in more ways than one.
Current Stable:
2024 G20 M340i Melbourne Red/Cognac
2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg
2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8
      09-07-2022, 07:51 PM   #21
aerobod
aerobod's Avatar
3626
Sounds like a lot of theory there, that would require controlled testing with thermocouples at each interface. The most important time for thermal conductivity is when the brakes are applied and any gap will be minimized under brake pressure. The rotors cool very quickly after that in the air flow. If they are up to cherry red at 900C or so, as soon as brake pressure is removed they go back to dull, dropping 500C or so in a few seconds, so any gap between the pad, shim and piston isn’t particularly meaningful when the brakes aren’t being used, the thermal capacity and conduction under brake pressure is much more important.
Fully blind testing with thermocouples on brakes either side with different shims fitted either side would be needed. I would be surprised if there is more than 5C drop on the back of a titanium shim 0.5mm thick compared with a steel one.
I’m sure manufacturers of them will claim otherwise as they have an expensive product to sell (even though the material cost by weight is only a couple of $), but they would need to provided properly conducted experimental results to show any meaningful improvement. Nothing to lose if they were $5 a set, though.
dradernh4413.00
ggggbmw432.50
      09-07-2022, 08:50 PM   #22
dradernh
dradernh's Avatar
4413
Drives: 2017 M240i
If you'd like to try them, I have an unused set I got from another forum member. lmk
If I wanted to get the most out of a shim made from any material, I'd first have Swaintech's White Lightning applied to the pads' backing plate or to the backing plate side of the shims: https://swaintech.com/race-coatings/...aust-coatings/.
aerobod3625.50
