2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum In need of URGENT help
      12-28-2018, 08:36 AM   #1
mani12354
Unhappy In need of URGENT help
Hi Folks,
I got a major issue, I have no top end power at all I've lost all my horses and torque and when I put my foot down to accelerate I have no power but goes into limp mode.
I have got a video of the problem, data log and error codes.
Please, can you help me before I sell my car :'(.
video
https://youtu.be/HbmoiUmYGR8
Screen shots
[IMG][/IMG]
[IMG][/IMG]
Datazap log:
https://datazap.me/u/manminderbirdig...og=0&data=4-17
      12-28-2018, 09:18 AM   #2
XutvJet
Modifications?
      12-28-2018, 09:37 AM   #3
Sportstick
Sportstick's Avatar
4654
Drives: '15 228i and '24 X3 sDrive30i
At that point...
https://www.bmw.co.uk/find-a-bmw-centre#gref
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner
      12-28-2018, 10:05 AM   #4
mani12354
Originally Posted by XutvJet View Post
Modifications?
Exhaust - downpipe - intercooler - bms oil mod - charge pipe - induction - stage 2 map
      12-28-2018, 10:06 AM   #5
mani12354
Originally Posted by Sportstick View Post
its going tomorrow
      12-28-2018, 11:09 AM   #6
Joe240
Joe240's Avatar
Drives: 2021 C8 Corvette 1LT
Yea it’s something with the flash. The shadow codes are showing with a scan tool which means that Bmw is going to turn their back on you for warranty work and the service center will offer you a factory flash that will cost you and arm and a leg, plus say goodbye to your warranty.
My only suggestion would be to attempt to reflash the DME again if you can (did you do OBDII flash?) or send it back to MHD.
      12-28-2018, 11:57 AM   #7
mecodoug
Drives: 2017 M240i 6-speed
Wrong fuel type?
      12-28-2018, 12:03 PM   #8
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
did you flash the wrong map?
flash back to stock, see what happens.
www.nybmwcca.org
Current Cars:
      12-28-2018, 12:23 PM   #9
mani12354
Originally Posted by mecodoug View Post
Wrong fuel type?
Shell v power only!
      12-28-2018, 12:23 PM   #10
mani12354
Did that and did not cure anything. Map is hcp
      12-28-2018, 12:26 PM   #11
mani12354
Haven't flashed the car the issue started when I was driving back from Wales to London there was a iPhone plugged in the car and it jerking like a donkey at top end like it was losing power. Then week 2 later it got worse and worse and now this how it is.. 😢
      12-28-2018, 01:29 PM   #12
bryan_G01
bryan_G01's Avatar
1165
flash it back bro. you need to eliminate all issues.
#1 - flash back to stock
#2 - rescan car for codes (using ISTA)
#3 - check charge pipe, intake pipe, intake filter
#4 - Change MAP sensor (the one on charge pipe)
www.nybmwcca.org
Current Cars:
      12-31-2018, 05:13 AM   #13
mani12354
Unhappy
Update for everyone: - Spoke to BMW they flash it back to original with the latest update and the problem still exists no boost or power.
      01-02-2019, 11:10 AM   #14
mani12354
Got a update from bmw the car is back now the said one test has failed - charge pressure control tester failed. Which could mean a issue with the air circulation
Does anyone know of this issue!?
      01-02-2019, 11:11 AM   #15
XutvJet
Sounds like there's a boost leak somewhere.
How long did you have all the mods before the problem showed up?
Were you messing with modifications or something under the hood shortly before the issue popped up?
Next time you get superknock codes, the LAST thing you should be doing is driving the car hard as superknock is deadly to pistons, rods, and rod bearings. Unless you have a desire to pluck down $15K USD+ on a replacement short block, I recommend not driving at all until you can get the issue sorted.
Lastly, if you do not pocess the mechanical skills to install mods and do under the hood troubleshooting, I wouldn't recommend modding a car like you've done unless you want to be paying big money to have techs troubleshoot issues most likely brought on by aftermarket parts.
Not trying to preach..
      01-02-2019, 11:34 AM   #16
mani12354
The car was modified from a professional company and I worked for bmw headoffice so I do posses some technical skills. I'm just curious about this air recirculation issue and if anyone else experienced it.
      01-02-2019, 08:52 PM   #17
amw896
amw896's Avatar
Drives: 2015 BMW M235i
2015 BMW M235i  [10.00]
what is hcp tune? Sounds like whoever did the work botched the job. I'd bring it back to them and not bmw.
      01-03-2019, 02:08 AM   #18
mani12354
Bmw confirmed the map is not the issue as they have wiped the ecu and done a full software update so everything is stock, they have said there is a issue around the turbo and sucking not enough air in.
      01-03-2019, 10:15 AM   #19
amw896
amw896's Avatar
fair enough....have u tried an independent shop that specializes in building cars? Their mechanics are often way better than the stealers who mostly only know how to read codes and replace what the computer tells them.
      01-16-2019, 11:38 PM   #20
Transfer
Transfer's Avatar
5254
Drives: Bronco Wildtrak, Tesla MYP
Help before I sell my car. LMAO so dramatic. Dude your mods are the problem, duh! Modding always carries risk to screw up your ride. Take it to your independent shop or tuner and have them figure out where it all went wrong.
      01-17-2019, 01:39 AM   #21
snaketh
Drives: 2015 M235i 6MT
What's with the condescending bs? We are here to help each other.
Tags
engine, low power, m235i, n55, n55 m2, n55 m235i, transmission 8-speed, turbo, waste gate
