06-17-2020, 01:59 PM | #1 |
Rep 733
Headlight Cracks
There are a few threads on this, but they either lack pictures or don't have a full resolution included, so I figured I'd make one and attempt to change that.
2016 M235i, about 49,750mi, about to go out of warranty. Headlights have developed small micro cracks on the inside in the past few months, and it seems to be getting worse. Dealership service department (which has always been very, very good) claims it's normal. What do y'all think? I'm hoping to get it replaced regardless, as it looks absolutely horrible, and contributes to cloudy looking headlights from a distance. Jon Last edited by JonOhh; 06-18-2020 at 11:28 PM.. |
06-17-2020, 08:00 PM | #2 |
Rep 2,200
Go through the other threads on this for add'l info. Let them know you know they know this is a known issue (!!!), frequently replaced under warranty. This is not due to wear & tear. Push the safety aspect. Good luck!
JonOhh672.00 |
06-18-2020, 11:32 PM | #3 |
Rep 733
So, got the car back. They didn't replace the headlights by the end of it. The paperwork reads as follows:
CUSTOMER STATES BOTH FRONT HEADLIGHT ASSEMBLIES HAVE STRESS CRACKS IN THEM. NORMAL NO ABNORMAL WEAR FOUND ON HEADLIGHTS does that look normal to you... ... ? |
06-18-2020, 11:33 PM | #4 |
Rep 733
It's going back, for certain. Hoping for some input on this thread to gain some traction. I have found many cases of this happening on the forums, but it seems its mostly people under CPO that then don't get it covered, so that doesn't help too much. Ill keep searching though!
06-19-2020, 04:08 PM | #5 | |
Rep 251
JonOhh672.00 |
06-19-2020, 11:31 PM | #6 |
Just Copacetic!
177
Rep 616
Had mine replaced back in 2015, my cracks looked like stress fractures, I suspect the lenses were forced into place and eventually developed those cracks. OP, yours almost look like the lens was sand blasted rather than stress fractures. Here's a link to a thread on these headlights covers:
https://www.bimmerfest.com/forums/sh...d.php?t=842929
'01 X5 3.0 AlpWhite
JonOhh672.00 |
06-20-2020, 03:48 AM | #9 | |
Rep 733
06-20-2020, 11:58 AM | #11 |
Rep 733
Yeah I'm very certain they're cracks, it's just very hard to show that on a camera. There's a few water spots on the lens, here and there, but the cracks are throughout. I'd love to know what they (hopefully after replacing) find the cause to be. It's very odd.
06-20-2020, 12:26 PM | #12 |
Usually 10 over
Rep 25
I've been through this with many cars. The root of the problem is crappy plastic. Plastic itself "dries up" and gets brittle over time and will weaken, crack, and/or break apart. Solvents (especially solvents with alcohol) will promote cracking and micro-cracking. There is NO way to fix the problem except to replace them and use a UV resistant film or religiously treat them with a UV wax or protectant on the new lenses.
It's a shame major manufacturers don't address this ongoing problem. Wet sanding a fogged lense is SOP for used car dealers but cracking is left alone usually and many times tolerated by owners. I miss the days of glass headlights! Look what we have to accept for design considerations, weight reductions and cost of manufacture. Good luck! |
06-20-2020, 01:46 PM | #13 | |
Rep 733
Will keep y'all updated. Cheers |
06-29-2020, 01:06 PM | #14 |
Rep 733
Well, spent some more time talking to one of the service advisors and he continues to push the idea that it's considered wear and tear, just like the cracks in the leather seats, and won't be covered under the manufacturer warranty.
Going to meet with the service manager in a few days to see what the options are from here- would rather not have to eat $2500 in headlights over an issue which should be covered under the cars manufacturer warranty. Lens replacement could be an option too, but if they're anything like the e90s headlights they're incredibly hard to get into without damaging anything. |
06-29-2020, 01:51 PM | #15 |
Luxury at the redline :)
9105
Rep 7,563
Could you actually share a photo with the headlight lens clear of all that dirt and water stains, so we can properly discern the crack in question.
It honestly looks like impact damage, from this distorted angle.. |
JonOhh672.00 |
06-29-2020, 02:58 PM | #16 | |
Rep 733
The main reason for the odd angles, is that it's very hard to get the camera to pick it up well, and those are the angles from which it's most obvious. Except the outside coating coming completely off of the headlight in a small section in the corners, there's no damage noticable to the touch on the exterior surface. Last edited by JonOhh; 06-29-2020 at 03:08 PM.. |
Poochie9104.50 |
06-29-2020, 03:39 PM | #17 |
Rep 5,372
This isn't normal. Are you the original owner? If not, how long ago was the car purchased?
06-29-2020, 04:15 PM | #18 | |
Rep 733
My family is the original owner, it's a one owner vehicle (it's my mom's, I have an e90, but I do all of the maintenance and sorting of issues on the 235)...purchased in late 2016. |
06-29-2020, 08:19 PM | #19 |
Rep 5,372
Has anyone ever treated or cleaned the lenses with anything other than soap and water?
06-30-2020, 11:05 AM | #21 | |
Rep 733
Nope, just regular car washing soap, and water. However, the body panel protectant wax has dripped onto the headlights during hot summers a few times, quicky cleaned off though. (the blackish crap that drips down from the hood on the earlier 2ers) Last edited by JonOhh; 06-30-2020 at 12:11 PM.. |
06-30-2020, 11:52 AM | #22 |
Rep 733
Alright, here's some more normal angles.
As you can see, I attempted to take the same photo with and without flash. This shows that without a bright source of light shining through, the lens looks good, but as soon as there's a light source shining light through it (like uhh...the headlights?) it shows all sorts of cracks that were nearly invisible before. They are as clean as I can get them. Some of are the left, some are of the right- they're both completely identical so it doesn't matter. I went to the dealership and looked at some 2ers, and f30 3ers, and none of them had this issue. EDIT: Some of them didnt upload, ill try again. Last edited by JonOhh; 06-30-2020 at 11:57 AM.. |
Poochie9104.50 |
