2Addicts | BMW 2-Series forum Classifieds Commercial Classifieds Suspension / Brakes / Chassis / Spacers KW Street Comfort Kit BMW 2series F22 Coupe M235i 2WD without EDC
      09-21-2023, 01:52 AM   #1
HP Autosport
Supreme Allied Commander
Drives: F80 M3
KW Street Comfort INOX-LINE coilovers are the perfect solution for drivers who want maximum ride comfort and a more discreet lowering range. In addition to stainless steel coilover struts, and corrosion-resistant components built for long term durability, KW Street Comfort coilovers utilize TVR-A (Twin Valve Rebound - Adjustable) technology -o allow Adjustment -f the rebound damping characteristics with 16 clicks so you can fine tune the ride comfort to your satisfaction. As with all KW coilovers our engineers develop vehicle specific damper settings that undergo comprehensive testing on the vehicles and in our KW 7-post Driving Dynamic Test Center. With a KW Street Comfort coilover kit the driving experience is tailored for absolute comfort. With the rebound adjustability you have direct influence on the handling and comfort of the car. With 16 precise clicks you can adjust the KW dampers (more firm or more comfortable) without affecting the compression damping fine-tuned by our engineers. The two-stage, patented TVR-A (Twin Valve Rebound - Adjustable) technology -nables a small volume of oil flow through an adjustable, conically shaped, low-speed bypass during low damper speeds, while at high damper speeds, the main rebound stage valve opens allowing a larger volume of oil to flow. This provides a big improvement in terms of ride comfort without influencing the high-speed range. There are 16 precise clicks available for individual settings, so you can choose between more comfort or more body control. For over 20 years, KW automotive has been the market leader and driving innovation as a manufacturer of individual suspension solutions for the road and in all types of motorsports. No matter where in the world, gearheads, automobile manufacturers and reputable tuners rely on our KW coilovers made in Germany. With an application list comprising more than 4,600 options KW guarantees an outstanding selection backed by our Limited Lifetime Warranty.
This Part Fits:
Year Make Model Submodel
2012-2015 BMW 335i Base
2016-2018 BMW 340i Base
2014-2016 BMW 435i Base
2017-2020 BMW 440i Base
2014-2016 BMW M235i Base
2017-2021 BMW M240i Base
Order here:
https://www.hpashop.com/products/kw-...wd-without-edc
A great little tool to make the job a little easier:
https://www.amazon.com/ATLIN-Strut-S...&creative=9325
      11-15-2023, 01:03 PM   #2
HP Autosport
Drives: F80 M3
bump
      12-19-2023, 02:31 PM   #3
HP Autosport
Drives: F80 M3
bump
      01-12-2024, 01:38 PM   #4
HP Autosport
Drives: F80 M3
bump
      02-14-2024, 07:15 PM   #5
HP Autosport
Drives: F80 M3
bump
