2Addicts | BMW 2-Series forum Classifieds Commercial Classifieds Suspension / Brakes / Chassis / Spacers SPL Titanium Rear Toe Links BMW F2X/F3X + Eccentric Lockout
      08-17-2020, 03:30 PM   #1
HP Autosport
Supreme Allied Commander
Drives: F80 M3
SPL Parts Rear Toe Arms (RTA) increase stability and response by eliminating bushing deflection while providing an increased range of rear toe adjustment, necessary for lowered cars or for performance alignments. Even small changes to ride height and camber will affect toe settings and the wide range of adjustment allows you to maximize grip on a track car and extend tire life on a street car. The factory rear toe arms utilize an eccentric bolt and washer for adjustment and lack the precision and range that SPL Parts Rear Toe Links offer. Black Anodized and gun drilled 2024 Aluminum main links along with our 360 degree Rotating Clamp design allow for quick and precise adjustment.
3 piece FK Bearings Rod Ends manufactured in Connecticut feature a Teflon liner to provide quiet operation, low friction, smooth articulation, and eliminates bushing deflection under load. The PTFE liner is chemically bonded to the inner diameter of the race. The liner offers a very high load carrying capacity and has greatly increased dynamic wear characteristics. The operating temperatures of the liner ranges from -65º to 325ºF, offering robust reliability for both street and track use.
Sold as a pair.
Made in the USA.
SPL Parts Titanium Series Adjustable Rear Toe Links with Eccentric Lockout Kit Features:
Gun drilled 2024 Aluminum Links to reduce unsprung weight
Blue Anodized Titanium Socket Head Cap Screws
6061-T6 Aluminum Rotating Clamp design
Low friction 3 piece Teflon lined FK Heim joints/Rod Ends
6061-T6 Aluminum Eccentric Lockout Washers
Grade 10.9 Hex Cap Bolts with Lock Nuts
Applications:
2010+ F2X
2011+ F3X
Installation Instructions:
https://www.splparts.com/content/SPL%20RTAEL%20F3X.pdf
order here:
https://www.hpashop.com/SPL-Titanium...-RTAEL-F3X.htm
      10-06-2020, 06:22 PM   #2
HP Autosport
Drives: F80 M3
bump
      11-16-2020, 06:16 PM   #3
HP Autosport
Drives: F80 M3
bump
      11-27-2020, 10:31 PM   #4
HP Autosport
Drives: F80 M3
PM for Black Friday coupon!
      12-30-2020, 09:27 PM   #5
HP Autosport
Drives: F80 M3
bump
      02-08-2021, 08:08 PM   #6
HP Autosport
Drives: F80 M3
less toe changes means more traction!
      03-22-2021, 09:12 PM   #7
HP Autosport
Drives: F80 M3
bump
      05-08-2021, 11:16 PM   #8
HP Autosport
Drives: F80 M3
bump
      05-25-2021, 08:36 PM   #9
HP Autosport
Drives: F80 M3
bump
      09-02-2021, 09:09 PM   #10
HP Autosport
Drives: F80 M3
bump
      10-17-2021, 08:27 PM   #11
HP Autosport
Drives: F80 M3
Less toe changes means more traction
      11-13-2021, 12:03 AM   #12
HP Autosport
Drives: F80 M3
bump
      12-09-2021, 03:46 PM   #13
HP Autosport
Drives: F80 M3
bump
      12-09-2021, 05:16 PM   #14
HP Autosport
Drives: F80 M3
bump
      01-03-2022, 03:51 PM   #15
HP Autosport
Drives: F80 M3
bump
      01-29-2022, 11:45 PM   #16
HP Autosport
Drives: F80 M3
bump
      03-17-2022, 10:45 AM   #17
HP Autosport
Drives: F80 M3
bump
      05-17-2022, 11:26 AM   #18
HP Autosport
Drives: F80 M3
bump
      07-13-2022, 11:56 AM   #19
HP Autosport
Drives: F80 M3
bump
      10-11-2022, 09:06 PM   #20
HP Autosport
Drives: F80 M3
bump
      12-28-2022, 06:42 PM   #21
HP Autosport
Drives: F80 M3
bump
      02-06-2023, 02:46 PM   #22
HP Autosport
Drives: F80 M3
bump
