2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Gas pedal feel: Comfort vs Sport/+
      11-18-2019, 02:20 PM   #1
Bimmerg621
Bimmerg621's Avatar
Drives: '22 G20 M340ix
After driving my 240i for months, I've noticed a weird "quirk" about the gas pedal. I don't know, it might be a normal thing but its quite strange to me. When in comfort mode, the gas pedal has soft, normal feel when pushed just like any other car. However in Sports mode it feels a lot stiffer and takes more effort to physically push the pedal down.
I'm not talking about throttle response or mapping, just the gas pedal itself when pushed. What I've done to temporarily to fix the "stiff" pedal feel while still wanting to be in Sport mode is configure it to Drivetrain only and just deal with the comfort steering.
Is the hard gas pedal feel something that is programmed with the sportier driving modes or am I imagining things?
Any insight is appreciated!
22 G20 M340ix AW / TR
19 F22 M240i BSM / CR (Sold)
      11-18-2019, 03:29 PM   #2
Ron Jeffries
388
Drives: 2018 M240i xDrive convertible
I do not believe the feel changes. The sensitivity definitely does. I think that's what makes it feel different. I could be wrong.
      11-18-2019, 04:06 PM   #3
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
You are correct. Just the sensitivity changes. It gets more sensitive with the more Sport you select.
78' Honda CB400A project
      11-18-2019, 04:18 PM   #4
XutvJet
There's a simple spring in the pedal assembly. There is no adjustment being made to the spring firmness/rate. The only change is in the way the throttle sensitivity is mapped by the DME.
      11-19-2019, 07:09 AM   #5
240Newbie
Learning
Drives: 19' M240 M Performance
It's the point of comfort mode. It's supposed to be the most efficient as possible so the response in the throttle is dulled and non reactive so that you get the best mpg's. That's why I only use it when I'm cruising on the highway in case I have to make some sort of quick move.
      11-19-2019, 08:14 PM   #6
harma24
I think you mean economy mode for most efficient operation. The throttle mapping in comfort is the same in comfort as it is in DSC Off mode. It's linear, but not non-responsive or dulled.
Economy mode on the other hand will shift to neutral and coast (a mode which drives me nuts as it eliminates engine braking when lifting off the throttle and also takes forever to re-engage when you get back on the throttle. Economy mode feels like it neutered the car.
Family Cars: 1993-2014: 1993 Honda Accord 10th Anniversary Edition | 2014-Present: 2014 Honda Odyssey
Stable-mate: 2019 - present: 2020 230xi Seaside Blue Convertible
      11-19-2019, 08:29 PM   #7
ralawren
Drives: 2015 228i MSport w/Trk Pkg
I agree the throttle is linear in comfort mode but mu h more abrupt in sport sport+. I have my car set-up with the throttle in comfort but the chassis (dampers) and transmission in sport/sport+. It is much easier to control the throttle this way, especially at the HPDEs.
      11-27-2019, 05:26 PM   #8
DaleHeinz
DaleHeinz's Avatar
221
Drives: M240Xi Estoril Blue
I noticed a good change in comfort mode response when I had the DINAN V1 Stage 1 installed. Removed most of the comfort mode lag and made off the line starts in comfort less strange, but not snappy like sport or sport+. Haven't heard from other folks with different tunes, but they may have similar results.
      11-29-2019, 05:59 AM   #9
Shovelman
Shovelman's Avatar
244
Drives: 2017 230i
In sport modes you are slammed back in the seat and your leg is heavier so you have to push harder
