2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum BMW Windshields
      03-24-2019, 07:36 PM   #1
Winemaker2
Drives: 2017 230i MSport THP Dinan V2
BMW Windshields
Has anyone noticed how soft the glass on the new BMW's is getting? I accidentally dropped my wiper blade arm on the glass and it destroyed the windshield. The replacement has now shown scratches from relatively new wiper blades and a cat crawled up the windshield when I parked outside and left a fine thin scratch. Today I treated the window with Rain X hoping it would add some resiliency. This never happened with all the BMWs I have owned before. Any thoughts on how to keep the windshield looking new or removing the fine scratches?
      03-24-2019, 07:48 PM   #2
CP911
Drives: '18 M240i 6-speed Coupe
So the wiper blade's rubber strip that makes contact with the windshield scratched it? Doesn't sound right at all. What older BMWs are you comparing it to? My uneducated guess is that regulations for laminating the glass could be changing and are to blame here.
CP911
      03-25-2019, 06:44 AM   #3
jmwilson125
Drives: 2016 M235i
The rubber wouldn't, but a fine grit under them like sand or dirt could.
I've gone through 3 windshields in 4 years which is crazy. One was a rock chip on the highway. Seemed like the smallest little ping.
The no the other 2 times were for no apparent reason. once it was cold outside and I had the defroster on....but that shouldn't be enough to cause a crack.
      03-25-2019, 01:13 PM   #4
Winemaker2
Given the fine scratches that match the blades travel, as you say probably just a bit of sand. But cat claws...c'mon. My previous BMWs were a 2004 E46 330i, 2006 E46 vert 325ci and a 2007 E90 325i. Never had to replace a window. I'm thinking that the glass may be more porous also for safety reasons.
      03-25-2019, 06:04 PM   #5
Redsauce
Drives: M240i
I cracked the windshield on my '03 Z4 while changing blades. The bladless arm came down under spring tension after I nudged it accidentally.
      03-25-2019, 07:16 PM   #6
XutvJet
A strike with wiper arm minus the wiper will almost always break the windshield. I've done it and many other people I have done it. My M235 is closing in on 3.5 years of ownership. The windshield has a few chips. That's it. I have read of very few instances on this forum of people having to replacement windshields on a routine basis.
      03-25-2019, 07:36 PM   #7
harma24
This happened to me as well, but after taking a close look, the crack started at what was likely an existing chip in the windshield. However, it did curve right around the defrost vent from there.
Otherwise, I've had no issues. I've taken some hits from stones / whatever that have been kicked up from cars in front of me off the windshield without any damage. 58k miles on the original windshield and it only had mild pitting and no scratches.
Family Cars: 1993-2014: 1993 Honda Accord 10th Anniversary Edition | 2014-Present: 2014 Honda Odyssey
Stable-mate: 2019 - present: 2020 230xi Seaside Blue Convertible
      03-26-2019, 08:39 AM   #8
Winemaker2
Anybody try to polish very fine scratches out of their windshield or just settled for it's just a windshield get over it? I was going to try to polish with Brasso as it has worked on a table I had.
      03-26-2019, 09:43 AM   #9
Zwei
Drives: 2014 M235i AW
1998 Porsche 911  [0.00]
2014 BMW M235i  [0.00]
I have polished windshields with my buffer. I used windshield specific polishing compound. Both times I spent half an hour of actual polishing and it made a noticeable difference in windshield clarity.
2014 BMW M235i AW
1998 Porsche 911
2007 Mercedes E350 Wagon 2001 Toyota MR2
1977 Lancia Montecarlo 2002 Acura RSX Type S
      10-27-2019, 10:26 PM   #10
MerlinMc
Drives: 2020 M240i
Just happened to me
Just happened to me on my 2020 M240i. While cleaning the wiper blade, the arm slipped free a few inches above the windshield and struck the windshield. It will need to be replaced.
Did you use the dealer for the replacement? Thanks.
      10-28-2019, 12:54 AM   #11
Uwrwilke
Drives: BMW 230i
Bras so is too abrasive. Use a finer polish.
      10-28-2019, 08:58 AM   #12
AndDown
Just Copacetic!
Drives: 2019 F22 230i MSport
Lesson learned from these posts: place a towel over the windshield before replacing the wipers.
'01 X5 3.0 AlpWhite
'16 428i GC AlpWhite
'19 230i MSptPkg AlpWhite
      10-28-2019, 10:44 PM   #13
MerlinMc
Drives: 2020 M240i
You can buy glass polish made explicitly to polish glass. See this for an example: https://www.griotsgarage.com/product...ks&from=Search
      10-28-2019, 10:47 PM   #14
MerlinMc
Drives: 2020 M240i
I was simply cleaning the wiper blade when the blade slipped off releasing the arm back onto the windshield. At first a loud sound and then a starburst of cracks.
An expensive lesson.
      10-29-2019, 11:08 AM   #15
MarcoZandrini
Drives: 2018 M240i
I don't think that dealers actually replace windshields. They have an account with a windshield replacement company. Insist on an original equipment replacement and not a cheep replacement. Your insurance company will balk but be firm.
      10-29-2019, 10:18 PM   #16
MerlinMc
Drives: 2020 M240i
Thanks.
That's the plan. My deductible is high, so no push back on OEM as it will probably still be < than the deductible.
      10-30-2019, 12:27 AM   #17
BM235iW
BM235iW's Avatar
Drives: 2015 Black Sapphire M235i
Living in Southern California there is sand and desert just about everywhere. After a couple of drives through the surrounding desert my windshield is pitted and requires replacement. I'm curious if anyone has tried using a windshield protection film. I ran across this project by "CLEARPLEX", any thoughts or users?
http://www.clearplexap.com/clearplex/story/8896/1287336
      10-30-2019, 03:45 PM   #18
Winemaker2
Thanks.
I had to pony up the difference between AAA's cheap glass and OEM. If I recall it was about $100 more.
I just renewed my insurance and checked the box to replace any damages with OEM parts. I should have the quote for this change tomorrow.
I am going to try the referenced glass polish and see if it handles the fine scratches.
Speaking of scratches, what product has anyone found to gently polish the bright shadow line plastic around the side windows?
      11-21-2019, 12:00 PM   #19
fmzip
Spoiler Bandit
fmzip's Avatar
1650
Drives: 2019 M850i / 2016 228i
My Audi shows the same type of scratches from the wiper blades....Must be cheap German glass, needs to be re-engineered with better space-aged polymers
      11-22-2019, 02:52 PM   #20
Shovelman
Shovelman's Avatar
244
Drives: 2017 230i
American cars may have better glass but it wasn't invented in Germany so it's not going to get considered for us. So that OEM replacement might not be the best call.
      11-22-2019, 06:31 PM   #21
John in VA
Drives: 2015 228i M Sport
Not cheap, just "soft" - this has been an issue with the German windshields in my 2002tii, E30, E39 and E46s.
      11-23-2019, 07:31 AM   #22
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
It's not just BMWs...I've owned Porsches with the same problem. Seems to be common to German cars, and possibly other European makes.
