02-21-2024, 06:18 PM | #4 |
Rep 5,683
The N55 was used in the F87 M2 from 2016-2018. The B58 wasn’t available when the M2 development initially started back in ~2013-2014. The B58 was introduced in MY 2016 in the F30 340i.
The S55 was used in the F87 M2 Competition from 2018-2021. The S55 was used in the F87 M2CS for 2020. |
02-21-2024, 06:21 PM | #5 | |
Rep 43
02-21-2024, 06:23 PM | #6 | |
Rep 43
02-21-2024, 06:25 PM | #7 |
Rep 1,019
I don't think there was a B58 when M2s had the N55. AFAIK they went from N55 to S55 to S58, which seems like a normal progression of updates over time to me.
02-21-2024, 06:35 PM | #8 | |
Rep 5,683
Edit - from a quick look, I think he has a N55. His dash shows a 7k rpm redline which is the N55 redline. However, I could be wrong. Last edited by M3SQRD; 02-21-2024 at 06:40 PM.. |
02-21-2024, 06:41 PM | #9 | |
Rep 43
So say the year 2015, my 235 had a n55, what did the 240 and the m2 have? |
02-21-2024, 06:47 PM | #10 | |
Rep 43
02-21-2024, 06:53 PM | #11 |
Rep 1,019
02-21-2024, 07:02 PM | #12 |
Rep 43
Ohhh, I didn't realize it worked like that. I thought there was a 220, 228, 230, 235, 240, every year and each was just a step up in size.
02-21-2024, 07:02 PM | #13 | |
Rep 5,683
The F87 M2 was released in 2016 with the N55. The M2 used the N55 from 2016-2018. When the F87 M2 Competition was released in 2018 it had the S55 engine which was used until the end of production of the F87 M2 Competition in 2021. |
02-21-2024, 07:28 PM | #14 | |
Rep 1,019
So yeah, its hard to keep track of, especially when you also get into 5's and 6's and 7's and '8s and x's and i's and M's. And then there are the diesels as well. Last edited by Kernel Kurtz; 02-21-2024 at 07:36 PM.. |
02-21-2024, 07:34 PM | #15 | |
Rep 43
02-21-2024, 09:13 PM | #16 |
Rep 46
Drives: 2019 G20 330xi, 2015 F22 M235i
it started out OK where the last two digits were basically the engine displacement in liters, but at some point BMW decided that it was more of a relative power scale than an actual measurement. So, a 240 (with B58) has the same displacement as a 235 (with N55), but makes more power so gets a bigger number.
tn508s7.50 |
02-22-2024, 09:14 AM | #17 |
E4 Mafia
329
Rep 418
Drives: E30, E36/5, E46x2, F22, F30
Garage List 2004 BMW 330xi [0.00]
1990 BMW 325i [0.00] 1998 BMW 318ti [0.00] 2003 BMW 325i [0.00] 2015 BMW 335i [0.00] 2015 BMW M235i [0.00] |
BMW USA (not sure what BMW Canada does) usually brings over 2 motors for the each series of vehicles. Usually during the middle of a models life, they replace both motors with newer power units so it helps to follow the lifecycle of different motors too.
While both have the N55, they have different version of it. The M235i has the N55B30O0 while the OG M2 had the N55B30T0, which I believe was the only bimmer to receive this iteration of the N55 (edit: the F26 X4 also had the T0). Here is a link to a FCP article with the differences: https://blog.fcpeuro.com/the-definit...specs-upgrades
Squad - '90 E30 325i MT (225k) | '98 E36/5 318ti MT (153k) | '03 E46 325i MT (152k) | '04 E46 330xi MT (198k) | '15 F22 M235i MT (60k) | '15 F30 335i MT (80k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k) Bring back the purple M stripe Last edited by celsdogg; 02-22-2024 at 09:21 AM.. Reason: more and corrected info |
tn508s7.50 |
02-22-2024, 09:39 AM | #18 |
Rep 5,683
I’m not a b58 guy, I’m really an s65 guy who just happens to have s55, b58 and b48 engines
The n55 and b58 engines are both 3.0L single turbo I6 engines. The B58 has the advantage of learning from two other BMW turbocharged I6s - the n54 and n55 engines. The b58 has several improvements over the n55 such as a forged steel crankshaft, a closed deck block and an improved fuel system. These changes make the b58 more reliability than the n55 which had an open deck block, a cast crankshaft, and a weaker charge pipe setup. However, the n55 is a much freer revving engine and sounds better (less restricted exhaust setup), although sound quality is a subjective thing. In terms of tuning potential, the b58, due to its forged crank and closed deck, is capable of handling higher boost levels and, therefore, higher horsepower and torque output. |
tn508s7.50 |
02-22-2024, 02:29 PM | #19 | |
Rep 5,374
The open deck of the N55 isn't an issue unless you have plans to push 600whp+. Same goes for fueling. Unless you plan to push 400whp+, fueling isn't an issue. Luckily, it's a cheap fix if you need the capacity. The main reason BMW went with the N55 in the 2016-2018 was because the B58 did not meet their requirements for track usage, specifically oiling under high Gs. The N55 in the M2 has the S55 oil pump and sump system allows the motor to handle sustained high G loads. Many of the S55 parts are interchangeable with the N55, but not the B58 as it's an entirely difference generation of motor. The reason the B58 uses a closed deck block is not because of all out power potential, but rather it's the same block used in the diesel variants. The block of the B58 is super stout, but other expensive internal parts need replacing if you want to push 600whp in the B58 over the long term. The B58, just like the N55 or N54, aren't designed for huge power like so many try to push through. The S55s and S58s are specifically designed to handle big power. The N55 in the M2 weakest link is intercooling on the track. If you plan to track these cars, a larger intercooler is a must. Cheap and easy fix.
tn508s7.50 ferraricare55.00 |
02-22-2024, 06:05 PM | #20 | |
Rep 5,683
tn508s7.50 |
02-22-2024, 06:06 PM | #21 | |
Rep 2,243
Drives: 2007 328i / 2014 M235i
Well said. So stock for stock there isn’t much difference betweeen the two. Yes the b58 has more power but it also has a difficult to access timing chain and vanos if something goes wrong and yes the N55 sounds much better. Open vs closed deck doesn’t matter day to day until you tune it. If you plan to track it, yes the N55 can suffer in tight turns but the N55-M2 solved that. I’m not sure how good the B58 oiling system is, can someone chime in? There are many high mileage N55 engines, especially with the updated bearings |
tn508s7.50 |
02-22-2024, 11:04 PM | #22 |
Rep 278
Is there any report of timing chain failure on the B58? This seems to be terribly expensive to service.
2019 M240i, Melbourne Red, Black Interior. 3M Tint, Premium Package, Harman Kardon, Adaptive LED Head Lights, M Performance Exhaust and Diffuser, Chrome Exhaust Tips, 719M Bi Color Wheels, Black Kidney Grille, Burger Tuning JB+.
