11-20-2023, 06:25 PM | #1 |
Rep 42
Bilstein B6's SUCK???? Yes!!
Need to replace front struts on my '17 240ix. Wanted to upgrade over stock to take care of the instability over expansion joints etc. Article I read said the Bilstein B6's were the upgraded shock that still kept the other functions and variable damping.
Now that they are installed it's like sport mode all the time. I feel zero difference between eco, comfort or sport. Anyone else running B6's how do yours feel? Edit: put a few more miles on it and it feels slightly better. But still not much difference in modes and mostly if pushing a corner. Still harsh for eco or comfort mode. (Sorry about the overdramatic verbag before) They do feel like an upgrade and if they breakin a bit they should be an upgrade. Thoughts? Last edited by rvt1000; 11-20-2023 at 09:35 PM.. |
11-21-2023, 07:20 AM | #3 |
Rep 250
You mention they retain variable damping. Did you buy the B6 Damptronics?
11-24-2023, 02:13 PM | #4 |
Rep 338
I have the b6 damptronics on my car, they are stiffer across the board, and I'm pretty sure they lifted up the ride height a bit. They're fantastic on track though.
11-25-2023, 01:53 PM | #5 |
Rep 132
I have the B4 damptronics on my M235i and they too are rather harsh. A lot more NVH, especially over high freqency road imperfections. However the car handles really well. Can get tiresome at times. Mine definately raised the ride height by about 8-10mm. Sometimes in Sport mode I can feel the rear rise slightly.. not by much though
11-26-2023, 10:58 PM | #6 | |
Thaumaturge
181
Rep 211
Just my experience. ///Rich |
11-27-2023, 02:47 PM | #7 | |
Rep 132
12-10-2023, 01:34 PM | #8 |
Rep 5,548
The B6 are a high nitrogen pressure monotube damper. The nitrogen pressure provides a lifting force on the valve stack so you’ll see a 1/2-1/3” increase in ride height.
12-10-2023, 01:39 PM | #9 |
Rep 132
The passives maybe, but the B6 damptronic shocks are twin tube..when I compared my OE shocks to the B4 damptronics the spring cup on the B4's were tapered differently to OE which results in the very small height difference.
12-10-2023, 04:45 PM | #10 |
Rep 5,548
From the literature I’ve read about b6 and b6 damptronic dampers is they’re all high pressure nitrogen monotube dampers.
12-10-2023, 05:29 PM | #11 |
Rep 250
they reused the same description of the damptronics and the regular B6's. The damptronic are indeed twin tube which is evident by the thinner shaft.
Matthewricha43.00 |
12-10-2023, 05:51 PM | #12 | |
Rep 5,548
Here’s the link the B6 product page and a screen cap pic of the b6 features
https://workshop.bilstein.com/en/products/bilstein-b6/ Quote:
Directly from Bilstein’s website (third bullet from bottom): Last edited by M3SQRD; 12-10-2023 at 10:12 PM.. |
12-11-2023, 06:53 AM | #13 |
Rep 5,548
The Subaru front dampers are a twin tube design buy the rear dampers are still a high gas pressure monotube design. So some brands do use twin tube; however, BMW is using F and R monotube designs.8
12-12-2023, 12:07 AM | #14 | |
Rep 5,548
12-12-2023, 12:10 AM | #15 |
Rep 5,548
So please show documentation where bmw b6 passive and damptronic dampers use a twin tube design. If not please stop spreading misinformation regarding bmw b6 dampers.
12-12-2023, 02:16 AM | #16 | |
Rep 132
https://f30.bimmerpost.com/forums/sh...296041&page=17 The M3/M4 B6 Damptronics ARE monotube however, which are different part numbers obviously. https://web1.carparts-cat.com/defaul...04&14=4&12=130 look up 23-250734, 23-250727 & 20-250744 Last edited by Matthewricha; 12-12-2023 at 01:29 PM.. Reason: added links |
Dom14790.50 |
12-24-2023, 01:22 PM | #17 |
Rep 5,372
My current suspension is quite the Frankenstein setup. I have OEM dampers with Dinan springs in the front and Bilstein B6 Damptronics, shorter E series bumpstops, and Eibach Pro Kits in the back. I didn't like the Dinans in the back as their linear rate was too soft and created more squat and crashing into the stops. The Dinans were also really low in the back even with their ride height increasing spacer. The Eibachs are stiffer, progressive rate, and sit about 1/2" higher than the Dinans with the height increasing spacer.
I had B6 Damptronics in the front for about 2 weeks. They were terrible. They were harsh in all mods, crashed over bumps, clunked (common B6 issue), and raised the front end a full 1/2" (known issue). I told FCP Euro that I wasn't happy with them and they said to send them back for a full refund including shipping their dime. The B6s in the rear have been great for 3 years. I've always felt the rear axle on these cars just weren't damped and sprung right. The B6s and Eibachs fix much of it.
Matthewricha43.00 |
