2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum P# gauges
      05-15-2018, 12:59 PM   #1
roadster675
Drives: 2016 M235, 2019 X5, 2004 330Ci
P# gauges
Anybody install the P3 vent data display?
      05-15-2018, 01:51 PM   #2
stlb5
stlb5's Avatar
217
Drives: '19 M2C MT, '15 X5 Msport
Yes, I have one in.
      05-15-2018, 06:29 PM   #3
WolfGTI
WolfGTI's Avatar
2002 MINI Cooper S  [0.00]
2015 BMW X1  [0.00]
I have the Awron.
      05-15-2018, 06:54 PM   #4
BEM-S4
BEM-S4's Avatar
I have an iPhone app and a BT OBD plug - simple and cheap.
      05-15-2018, 09:10 PM   #5
Joaco135
Joaco135's Avatar
Drives: 2020 M2C LBB
BEM,
Can you PM me the details on the app and the BT OBD Plug?
Thanks,
      05-15-2018, 09:56 PM   #6
VPB74
VPB74's Avatar
38
Drives: 2018 M240i
I'm interested too. Can you post info here? Thanks.
      05-16-2018, 04:33 AM   #7
BEM-S4
BEM-S4's Avatar
App and HW - click on photos for full details
      05-16-2018, 10:13 AM   #8
stlb5
stlb5's Avatar
217
It looks like most of you guys have newer 235's. I have a 14 and could never get oil temp to show up on an app and I tried a few.
      05-16-2018, 03:00 PM   #9
Joaco135
Joaco135's Avatar
Thanks for the info BM-S4
      05-16-2018, 04:07 PM   #10
emtrey
emtrey's Avatar
92
Drives: 16 M235IX, 06 Carrera S, 335i
Does it read oil temp on 2016 235 ?? I really would like that info available to me.
      05-16-2018, 04:12 PM   #11
BEM-S4
BEM-S4's Avatar
This is my standard screen, which you can customize. I never tried it on my 2014 coupe but it works on my 2016 convertible. I cannot imagine they would be different. It reads all zeroes now since I'm not in the car but they do all work properly.
      05-16-2018, 08:08 PM   #12
WolfGTI
WolfGTI's Avatar
2015 BMW X1  [0.00]
I had the same - while it worked - I did not like hiding the phone everytime I parked. Plus I didn't like the added on look. Functionally it was fine.
      05-16-2018, 08:13 PM   #13
Would do an Awron gauge in a heartbeat if I could run it in tandem with the JB4 OBD dongle, one can dream...
      05-16-2018, 08:36 PM   #14
WolfGTI
WolfGTI's Avatar
2015 BMW X1  [0.00]
The AWRON does not use the OBD port - why do you think it cannot work with the OBD dongle?
      05-16-2018, 08:51 PM   #15
BEM-S4
BEM-S4's Avatar
Yeah I run a proclip and have my phone on the dash at all times, so it's actually the cleanest option for me.
WolfGTI716.00
      05-17-2018, 04:52 PM   #16
AFAIK, all of these devices all feed from the OBD CAN-BUS connection. These systems can only support a single device, for live streaming data, regardless if you've plugged into the port itself, or tapped into the wiring behind the scenes. The data transfer rate on the CAN-BUS system will not keep up with two devices, this is something that has been a struggle since the mid-2k's...
Correct me if I'm wrong, though.. I'd love to be wrong in this case!
From Terry @ BMS
"Despite what the AWRON guys will tell you, they are really not compatible. The JB4 relies on accurate and precise CANbus data for it's tuning on Stage2+, with a minimum frequency of 10hz, or 10 updates per second. When you add in the AWRON or other OBDII devices that pull DME data, the JB4 sample rate greatly drops. I've seen it drop as low as 3hz. And the AWRON sample rate drops too, as both are fighting for data priority.
If you insist on using an AWRON gauge then my advice would be to run the JB4 as a Stage1 only. Or downgrade it to a Stage1 tune. That does not have CANbus access."
Viffermike1753.00
      05-17-2018, 08:35 PM   #17
WolfGTI
WolfGTI's Avatar
2015 BMW X1  [0.00]
Wow interesting. I wish I knew could tell you different but I do not. I hope you find a solution.
From Terry @ BMS
      05-17-2018, 10:00 PM   #18
The solution is to utilize the app based gauge set within the JB4 Mobile App, which shows me what an awron gauge would, just not nearly as clean and oem+ in appearance. Definitely more a “want” than a “need”.
First world problem, no doubt lol
SebsM2652.00
WolfGTI716.00
      05-20-2018, 05:26 PM   #19
mfan225
Drives: 16 M235i
I have a P3 gauge installed. Love it!
