2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Need help cleaning tachometer face
      05-09-2018, 06:17 PM   #1
MDF164
Drives: ‘18 230i SeaBlu THP
Could someone please recommend a suitable product or technique for removing some sticky adhesive from the face of my tachometer. I am fearful of damaging the tachometer cosmetically using an inappropriate solvent or tool. Please advise. Ty.
      05-09-2018, 06:27 PM   #2
Maynard
Drives: 228iX & M2C
You can probably find more specific advice here in this subforum http://www.2addicts.com/forums/forumdisplay.php?f=576
Personally, I'd start with simple interior cleaner, or rubbing alcohol, and test it on a spot at the edge first to be sure it doesn't fog up the plastic.
      05-09-2018, 06:30 PM   #3
K8_M235i
K8_M235i's Avatar
Drives: CM E36
What kind of adhesive? Kind of a strange place.
Like most things I would start by using the least harsh method and work up from there.
Glass cleaner, goo gone, solvent based instant detailer, rubbing alcohol, wd40. Somewhat in that order.
I would apply product to a microfiber towel and avoid spraying directly on to the tach face to prevent a messy cleanup of a cleanup lol
2015 F80 M3 DCT, Carbon Roof
1998 S54 E36 M3 BMWCCA Club Racing #532 CM
1995 E36 M3 Sunbelt S52
      05-09-2018, 07:04 PM   #4
MDF164
I believe it is the adhesive used by BMW on a clear sticker placed on the interior glass that gives a BMW Assistance phone number and a warning to not lock passengers in the car and to be mindful of pets before adjusting the seats. The car is brand fn new and I had the windows tinted at a place with a good rep. My wife picked up the car and noticed a clear sticker crudely stuck to the tach. She unwittingly removed and disposed of it. Later, I noticed the goo left behind and questioned her. I suspect the tinter put it there not wanting to dispose of the message and was trying to place it in clear view...(and chose the tach...wtf!?).
      05-10-2018, 05:57 AM   #5
Rayscott
Drives: BMW 228ix
Xenit. I use it for removing those PIA window stickers in my detailing business.
      05-10-2018, 07:59 AM   #6
morphomeman
morphomeman's Avatar
593
Drives: 2015 M235ix
2016 BMW X3  [0.00]
2015 BMW M235ix  [0.00]
As always in such matters, you should take it back to the perpetrator, in this case the tinter, who should have the requisite expertise. Why should you have to deal with it?
      05-10-2018, 08:26 AM   #7
RossG1028
Drives: 2017 230i
I would use distilled water on a 100% cotton t-shirt.
      05-10-2018, 08:59 AM   #8
Ron Jeffries
388
Drives: 2018 M240i xDrive convertible
Oh come on. The distilled water is OK, although frankly I think a titrated solution of distilled water and pure ethyl alcohol would be more effective. And the only proper cloth would be pure silk. I’d recommend a scarf from Hermes, if you haven’t the time to go to Como and have one made. Of course, after one use, the scarf is to be disposed of. The cleaning solution, you can drink.
      05-10-2018, 10:13 AM   #9
MDF164
Thank you for your response; however, the Xenit website says they do not recommend using on plastic. The tachometer face is likely plastic, right?
      05-10-2018, 10:34 AM   #10
MDF164
I hear you morphomeman; however, my confidence in their expertise is waning, so I thought it best to throw it out to the forum after my attempt to remove the goo with a Zeiss lens cleaning premoistened wipe failed. I have contacted the tinter and he admits he intentionally placed the sticker on the tach and he has offered to rectify the situation. I feel compelled to proceed cautiously and get advice from another source. Thank you for your response.
      05-11-2018, 12:51 AM   #11
CP911
Drives: '18 M240i 6-speed Coupe
Good old WD-40 works miracles on sticker residue. Have been using it to remove sticker goo since I was a kid and it has never let me down. Spray on a soft microfiber cloth and saturate a small spot on the cloth. Then, use the tip of your finger to gently push the soaked part of the cloth into the sticker gunk, basically dabbing it from the outside edge of the residue spot towards the center. The sticker residue will soften up rather quickly and with continued gentle dabs and swipes with your finger, it will basically liquify and lift right off and into the microfiber cloth.
WD-40 isn't abrasive and I've never seen it harm or even stain any type of plastic or metal. If you are gentle with the microfiber, you shouldn't have any damage to the plastic window. At the end, use the same technique with a damp (with water) microfiber cloth to remove the oily WD-40 residue off the plastic window surface. It will wipe right off and leave the surface dry and totally clean of all solvents.
I personally would try the above before wasting money on fancy cleaning products or asking for more trouble by taking the car back there.
Good luck!
CP911
      05-11-2018, 10:24 AM   #12
aerobod
aerobod's Avatar
3626
Using the sticker itself to remove glue residue is very effective. If you take an area of the sticker that is still sticky, touch it on the residue then quickly remove it with a snapping motion, then repeat a number of times, the residue will have an affinity for the adhesive on the sticker if it is pulled off in the right way, as it has a much higher tensile strength than shear strength.
      05-11-2018, 11:47 AM   #13
pz619
Drives: F87 M2C 6MT, Tesla 3
You mean Turpentine?
(Apparently this is a new trend)
      05-11-2018, 01:50 PM   #14
cxp213
cxp213's Avatar
313
Water is the universal solvent so that's the first thing you should try if you're worried. I don't know why people keep recommending alcohol on plastic but that's not a good idea, especially if the concentration is higher. I'd try a glass cleaner, WD40, or GooGone.
Because it's a sticker... If a part of broken or damaged, I can understand but it'd be stupid to drive out to someone so that they can remove a sticker residue that you can do yourself in less than a minute.
      05-11-2018, 02:58 PM   #15
morphomeman
593
Drives: 2015 M235ix
2016 BMW X3  [0.00]
I bet OP has by now spent enough of his time (and ours) to go back and forth to the tinter twice.
      05-11-2018, 03:26 PM   #16
Maynard
Drives: 228iX & M2C
Granted there is the 'they did it, let them fix it' ethos, but there is that 'they did it b/c they are idiots' thing to contend with. If tintman hacks up his dashboard and gauge face trying to scrape it off with an Xacto he'll regret it.
      05-11-2018, 04:03 PM   #17
Ron Jeffries
388
Dremel, maybe?
      05-11-2018, 04:06 PM   #18
MDF164
This.
      05-11-2018, 06:37 PM   #19
Rayscott
Drives: BMW 228ix
Oh, I thought it was glass. You could be right. A plastic polish might work.
      05-11-2018, 07:06 PM   #20
MDF164
Good news...the goo has been safely removed! A recap of the events starting, of course, with things that did not work....
1. Zeiss lens cleaning wipe (pre-moistened w/ isopropyl alcohol). The failure of which prompted me to ask for help.
2. Distilled water w/ 100 % cotten towel.
3. Glass cleaner w/ 100% cotten towel.
And then....
4. WD-40 w/100% cotten towel (and Q-tip applicators moistened w/WD-40 for the crevices), followed by microfiber w/glass cleaner and winner, winner, chicken dinner! Looking good...
Truly appreciate the help from the forum. Thanks for your time.
FWIW: Before allowing the dbag tint man to “rectify” his sloppy mess, I would have rather entrusted Ron J. and his Dremel tool to handle the clean-up. (But only if he sports a silk scarf and steadies his hand with a cleaner solution cocktail).
      05-12-2018, 08:20 AM   #21
Rayscott
Drives: BMW 228ix
Good determination, glad you got it fixed.
      05-15-2018, 08:24 AM   #22
Maynard
Drives: 228iX & M2C
I suggest you now apply a solution of about 50% ethanol internally - preferably a single malt variety.
