2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Oil Pan Gasket
      03-24-2024, 09:42 PM   #1
Ericwj7
'14 M235I
Drives: BMW M235i
Oil Pan Gasket
Hi all, I have a 2015 m235I with 65,000 miles on it. My oil pan gasket leaks not huge but it's there after the VC & the OHCG are all done now.
Is this common for this model and year with my mileage?
Since I don't lose much oil, is it something I should attend to sooner or later?
Thank you for any experience with my model and year if you have had to do it either or have not had to?. : cool!:
      03-28-2024, 02:04 PM   #2
123Britt
Drives: 15 M235i AT
Sameboat Here
VCG + OFHGs all Replaced and now I am at 95K Miles and my oil pan is starting to leak like yours. Not sure it can be replaced without removing the subframe.
I am sure someone has a work around .
      03-29-2024, 09:11 PM   #3
Ericwj7
'14 M235I
Drives: BMW M235i
Thanks, I believe you do have to drop the subframe to do the job. so far mine is more of a weeping condition still holding off till I need to replace my electric water pump and anything else down there as it's a lot of time to do this job. Let me know when you tackle it.
Tags
#oilpan #m235i #n55 #oilleaks
