2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning noise coming from front left suspension.
      03-09-2024, 12:46 AM   #1
Bmw turbo
Drives: Bmw m235xi
Hi guys. I have a 2015 bmw m235i xdrive. The car makes a noise like I’m driving on fresh fallen snow. Especially when I’m turning the wheel to the left, backing out of a parking lot, or driving into one. Does anybody know what could cause this issue? I have already changed the strut mount bearing and tightened the pinch bolt(as some people suggested). The car only makes the noise when it’s loaded( wheel on the ground). When I lift the car, the noise goes away. Would appreciate any advice.
Thanks.
      03-09-2024, 11:17 AM   #2
freakystyly
Drives: F22 B58 6MT
Sounds like the same issue as https://www.2addicts.com/forums/show....php?t=2088215 on the front page.
      03-09-2024, 12:30 PM   #3
Bmw turbo
Drives: Bmw m235xi
My symptoms are a little different than his. Mine still makes that noise in park, whereas his makes it only in drive or reverse. I also had someone turn the wheel while I held the cv axle to feel for the clunking, but I didn’t feel anything. You can’t hear the noise at all from outside, but you can hear it inside the car. Also you can feel it through the stearing wheel
      03-18-2024, 11:28 PM   #4
Bmw turbo
Drives: Bmw m235xi
Does anyone have any other suggestions? Much appreciated!
      03-21-2024, 03:55 PM   #5
Bmw turbo
Drives: Bmw m235xi
Figured it out. It ended up being the plate under the motor(mounts to subframe) that wasn’t as tight as it could have been. There are about 8 bolts. Make sure they are all tight. Hopefully this will help someone.
