04-22-2014, 04:07 PM | #1 |
Rep 841
Air curtains intake?
BMW advertises their Air Curtains technology for the 2 Series Coupe. I had assumed that the intake for the air curtains were the outermost vertical section of the front fascia. I got a chance to look closely at a 235 today at the NYIAS, and that section is non functional. The thin, vertical black "grill" is actually closed off.
Looking at the trailing edge of the forward portion of the front wheel well, I can see a tall thin outlet which might be the outlet for the air curtain. Which means the intake must be from one of the main bumper openings. It probablyisn'tthe main center one, so it must be one of the outer ones, but both those look like they have cooling radiators (oil?). So the air either has to pass through the radiators -- or divert around them -- before flowing out the wheel well to form the air curtain. But then I can't see the air building up enough "ram force" to form an effective curtain. Can anyone shed any light on this? |
04-22-2014, 05:00 PM | #2 |
Rep 269
I noticed that as well. The base model 228i I test drove had functional air curtains through the outermost vertical sections, beside the fog lights. On my 228i M Sport, like that M235i you saw, the sections are blocked off with a black plastic grill. I haven't examined further, but maybe this weekend I'll have a closer look to find a route for the air
04-23-2014, 10:27 PM | #4 |
Rep 6,934
Drives: 2018 M2 AW DCT
Looks like the two European M235i have the M Performance front splitter installed.
04-24-2014, 02:31 PM | #5 |
Rep 189
I thought I read somewhere it depended on what transmission you had. Could be wrong, but check both manual and auto and see if one has it and the other doesn't.
04-28-2014, 10:21 PM | #7 |
Rep 862
Drives: '19 M2 '21 X5
Took a look at mine (m235i Canadian / NA same difference). It definitely has the outlet on the inside from the front wheel for the curtain.
I think the air comes in from the 2 slits on the far outside edges of the bumper air ducts. You can see it on the red car in the above picture. So the black blanked off section (which mine also has) must be for something else. Basically I think it has curtains but I don't really know for sure. |
07-08-2016, 02:34 PM | #8 |
Rep 61
Just spoke to my BMW dealer in FL and his response was "that's only on the 228, not the M235", although you can get the part for a 228 and replace the closed version on the M235
07-08-2016, 03:40 PM | #9 |
Rep 5,538
Ask him why are they advertising Air Curtains on M235i on BMW website. And ask him for the part number for open ones. It makes zero sense to have them open on 228 and make another part for M235i to block them. The opening is there on both
07-08-2016, 04:05 PM | #10 |
Rep 721
07-09-2016, 07:04 PM | #11 |
Rep 1,753
Mine are closed :/ MY16
07-10-2016, 09:32 AM | #14 |
Little Deuce Coupe
391
Rep 635
Drives: SO M2C
Production dates don't seem to matter, but as suggested on another thread, the pics of open air curtain vents all seem to be on cars with closed left sided aux cooler intakes, while closed curtain vents are paired with open aux coolers.
ex: 2004 Thermonuclear Yellow RX-8|6MT
ex: 2015 Estoril Blue M235i |6MT|slicktop|MP exhaust - PCD 2020 Sunset Orange M2C|6MT|Black 788s |
07-10-2016, 11:42 AM | #15 |
Rep 5,538
All m235i have open aux coolers, at least in USA
07-10-2016, 12:31 PM | #16 |
Little Deuce Coupe
391
Rep 635
Drives: SO M2C
Not the convertibles, at least through last year. Note that the posted 235 pics showing open curtain intakes are all 'verts or non-US cars.
07-10-2016, 12:45 PM | #17 | |
Rep 5,103
07-10-2016, 12:59 PM | #18 |
Rep 5,538
07-10-2016, 02:41 PM | #19 |
Rep 1,753
Yeah, seems to be the case. Mine is a MY16 coupe in the US.
07-10-2016, 02:45 PM | #20 |
Little Deuce Coupe
391
Rep 635
Drives: SO M2C
That's my suspicion based on what people have posted, but I have zero idea why, either. Convertibles do lack the left hand aux cooler in the US as do most (maybe all) non-US 235s. If this correlation is true, why would the curtain be useful if the right side cooler vent is open, but not the left? It's an open part vs a closed part, so there can't be cost savings. The front wheels/tires should be the same size on staggered and square cars, so that can't be it. This is really bugging me.
07-10-2016, 03:03 PM | #21 | |
Rep 5,538
07-25-2017, 09:06 AM | #22 |
Rep 176
The whole thing is very strange and like many BMW fitments, not clear why they have done what they did. I have a 2016 F23, 235 eng, 8SP Auto, NA spec, canadian car with open air curtain vents but no auxiliary rad in the LH side. Its totally closed. To add another kink my brake cooling ducts which are on either side of the intercooler/main rad are blocked off with panels inside the wheel wells. Why have them if they are blocked off? (I have removed them. ) So why do some cars require the extra rad for cooling and some not?
