2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum How reliable has your 2-series car been so far?
      01-19-2017, 07:46 AM   #111
koston
koston's Avatar
Australia
37
Rear fog light failed a week after delivery. Had the dealership replace it but it has died again. I think the actual housing/wiring may be loose.
Haven't had time to take it back, so will probably do it at the first service.
      01-19-2017, 12:30 PM   #112
rwjr44
Drives: 2016 228i
Other than too much wind noise at speed and the output of the headlights, things are going great.
2016 228i 6MT
      01-19-2017, 08:00 PM   #113
harma24
Really? I've found it to be very quiet compared to my other cars.
Family Cars: 1993-2014: 1993 Honda Accord 10th Anniversary Edition | 2014-Present: 2014 Honda Odyssey
Stable-mate: 2019 - present: 2020 230xi Seaside Blue Convertible
      01-20-2017, 10:56 AM   #114
rwjr44
Drives: 2016 228i
It was very quiet when I bought it but is now noisy enough to be an irritation.
2016 228i 6MT
      01-20-2017, 01:05 PM   #115
XutvJet
How many miles and which tires are on the car? Also, if it's cold where you car, cars tend to be a bit noisier and more NVH in general.
      01-20-2017, 01:13 PM   #116
Viffermike
Viffermike's Avatar
Robert Willis Exactly. As tires wear they become more noisy, and as temperatures drop they become more noisy. Same with creaks and such in the interior. Why? Because rubber and plastic have viscosity just like oil and water does, and the lower the temperature, the lower the viscosity.
Things that are normally soft and pliable get harder and less pliable.
--Helmets are for closers.--
2msport204.00
      01-20-2017, 09:11 PM   #117
Chickster
Drives: 2016 M235i and 2011 X5
Most trouble free BMW i've had. 7,900 miles in 17 months and no service needs, other than annual service.
I love the car.
2011 550i, Black Sapphire, Black Nappa Leather, ZSP,ZDH, ZP2,ZCV,ZDA.SAT (delivery on 6/26/10)
2011 X5 xDrive 35i Sport Activity, Black Sapphire, Black Nappa Leather, M Sport (delivery on 5/28/10)
Previous BMWs: 2006 E60 550i, 2001 E46 330cic, 2003 745Li, 2000 M5, 2000 540i
      01-21-2017, 01:36 AM   #118
esp260
Drives: 228i Msport 6MT
Nothing major so far. Nearing 23k miles in 18 months. I did have warped rotors half a year ago (from 2 track days) but BMW replaced it under warranty without question.
Took my car in as well for "drivetrain malfunction" one night. BMW said it was an engine misfire, nothing needed to be replaced/fixed.
No troubles since and no recurring issues.
      01-21-2017, 10:20 AM   #119
rwjr44
Drives: 2016 228i
So I should treat the rubber around the window with some sort of rubber sealant/lubricant?
2016 228i 6MT
      01-21-2017, 12:08 PM   #120
adema24
Drives: 228i
I had a dash rattle that developed within 16k miles. Dropped the car off at the dealer and they fixed it. I've never had a problem with anything else. Well, sometimes when I connect my iphone through usb it spazzes out, but that's because iOS 10 is absolute crap.
      01-21-2017, 06:48 PM   #121
BentZero
BentZero's Avatar
You should search for the thread where ppl are adding the missing weather stripping to the inside of the doors.
Build thread
      01-21-2017, 07:38 PM   #122
raleedy
Drives: 2016 228i 6-speed
Six months, 5.4k miles, no issues.
      01-22-2017, 12:44 AM   #123
BentZero
BentZero's Avatar
Approaching one year. So far so good.
Build thread
      02-04-2017, 08:25 PM   #124
TBro2002
Drives: 2015 335i M-Sport
16,000 miles and mostly trouble free until this week. Right rear Continental run flat developed slow leak. Brought it for repair and Continentals cannot be repaired. So $400 for two new tires. Switched to Bridgestone run flats which can be repaired and got repair or replace warranty.
      02-05-2017, 06:32 AM   #125
morphomeman
morphomeman's Avatar
593
Drives: 2015 M235ix
2016 BMW X3  [0.00]
2015 BMW M235ix  [0.00]
Lubricating the rubber seals will do nothing except leave lubricant on your windows. It's a matter of physics: the rubber gets less pliable as the temperature goes down. You just gotta live with it.
      02-05-2017, 07:33 AM   #126
123Britt
Drives: 15 M235i AT
Can't say I agree
Sure the rubber maintains it stiffness at lower temps however, the proper seal lube quiets the creaky door seals. As for window seals & quiet -- I have seen the additional rubber door seal (found on diesel models) which can be retrofitted to petrol cars.
You only have to live with what you tolerate!
      02-07-2017, 08:09 AM   #127
podkaz
podkaz's Avatar
Drives: 2011 M3; 2017 X1 MSPORT
2011 BMW M3  [0.00]
2 years in and 16.7 k. pretty much problem free, except warps rotors around 15k. no hard driving, just occasional spirited drives.
      02-07-2017, 10:35 PM   #128
Larry7995
Drives: 2015 M235i xdrive
Yesterday the driver side window electronics failed. It is supposed to lower the window about 1/2 inch, you shut the door, then it raises the window back up, well the door will not even shut now unless I lower the window myself, which poses a problem when you are getting out of the car. Anyway, it is going to be dropped off tomorrow.
Last fall I had a cooling fan fail. Got all sorts of warnings about shutting it down right away etc. so I had to call and get roadside assistance to pick it up.
One day the battery died out of the blue, not sure whether that was "operator error"
Had to replace a run-flat about 9 months after I bought it.
Got hailed on, got that fixed, looks good as new.
Shined it all up the other day and took it to a bike ride where another older BMW owner was present, she commented on my awesome car
I am still thinking maybe I want an arctic blue ZL1 in 2018 but the BMW has a hitch and a bike rack!
      02-10-2017, 10:19 PM   #129
Larry7995
The really nice thing about the BMW is the 4 year warranty, my car is fixed but I have to get the diagnosis tomorrow. Briefly service advisor said I need to start it more often in times that I am exclusively driving my Colorado. At least that was the initial theory,the battery starts going low and the comfort features are shut off? But I drive it 40 miles too the dealer so the battery should have been charged back up. He said the battery is ~ $400?
Had a hernia fixed today so not driving anything for a few days!
      02-11-2017, 09:41 AM   #130
bimmerfile
bimmerfile's Avatar
621
Drives: 2019 BMW X2 F39
Originally Posted by Larry7995 View Post
Yesterday the driver side window electronics failed. It is supposed to lower the window about 1/2 inch, you shut the door, then it raises the window back up, well the door will not even shut now unless I lower the window myself, which poses a problem when you are getting out of the car..............................................
What was the issue with the drivers window and what was the fix?
2019 X2
      02-13-2017, 12:28 PM   #131
Larry7995
They put a new battery in and did the electronics reset. I bought in late 2015 so kind of soon for a battery fail, but they warrantied it. Schomp has been a good shop for me. They suggested I get a battery tender for extended bad weather periods where I drive my Colorado exclusively. They are driving it over to me just after lunch.
      03-06-2017, 03:03 PM   #132
crabu2
Drives: Truck and ...
Originally Posted by Xiaoxi View Post
Those are not even close to enough mileage to begin gauging reliability. You'd have to cross the 100,000mi threshold to start judging.
Most people do not have that luxury. Most people are driving 80k-200k mile single cars for 8-12 years. Ask the average car buyer how impressed they'd be that our BMW has lasted an amazing 28,000 km.
28K km is a joke! My beater car is an '07 Camry and I've got 250K miles on it.. Yes a 1/4 million miles and out side of basic maintenance, the only thing it needed as an O2 sensor.
I've run Jeeps, Rams and Fords to over 200K miles too... For me a reliable car is one where I consistently hear of people going 200K miles with basic maintenance. Any new car these days should get 100K miles.. If not, it's not engineer and/or built well.
I'm looking to get my 1st BMW and the reliability is what's scaring me the most. My friends that have or had them all seem to have had small issues like wiper and or window motor problems. None have told me they were stranded on the side of the road, but they've all also gotten rid of their cars once 100K miles hits.. They get terrified for some reason of crossing 100K miles on a BMW. I don't understand why..
