2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum M235i top speed - is it really limited ?
      04-12-2014, 09:29 AM   #1
D.
Drives: M3
Can anyone tell me whether the top speed on the M235i is electronically limited to 130 mph or not ?
I am reading conflicting information on this: BMW USA's site (M235i specs page) shows the top speed as limited at 130 mph and next to it shows [155], which I take it to be the actual top speed if there was no limiter.
On the other hand, the test drive report I saw on Car & Driver's site shows the top speed reached on track as 155 mph.
If it is limited indeed, it will be a deterrent from getting an M235i. I mean, why pay for 320 horses if you will never be able to use them all ?
Any information will be very much appreciated.
      04-12-2014, 09:34 AM   #2
SmallTownBoy
Drives: '14 M235i 6MT PSS BSM
If you order the car with the summer performance tires (Michelin PSS) the limiter is set at 155 mph. Any other tire option (run flat, a/s) gets a limiter set around 130 mph.
      04-12-2014, 09:42 AM   #3
D.
Drives: M3
Thank you very much.
I wish the BMW USA website provided this clarification.
      04-12-2014, 10:04 AM   #4
D.
Drives: M3
SmallTownBoy,
what is a good deal on a lease for the M235i ? I am looking for a 2- or 3-year lease.
I sat in one the other day ... I really don't like that console they have put to the right of the dashboard. He said it is for showing the status of the various electronic instruments, and all that, which I really don't care about. It takes up space and adds weight for no useful function.
Does your car have this as well ? Do you find it useful at all ?
      04-12-2014, 10:13 AM   #5
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
SmallTownBoy,
D, thats the idrive screen. I suggest you learn about the car before putting out $44k. Theres alot of info in this forum, the sticky thread on the 2 series has alot of info and if you still cant find it, we can help you out. Search is also helpful
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      04-12-2014, 10:19 AM   #6
D.
Drives: M3
      04-12-2014, 10:21 AM   #7
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
I edit my post....theres a "sticky" thread from the site admins and its all about the 2 series...check it out
2006 325xi (Sold)
      04-12-2014, 12:59 PM   #8
SmallTownBoy
SmallTownBoy,
+1 on ska's reply. Take the time to research the brand and model before buying. Read the sticky threads here and at 2addicts.com, lots of great info on pricing and configuration options. There are multiple threads on leasing concepts and deals.
As for me, I'm in Canada and our deals (especially for ED) and lease rates can't compare to the U.S. I bought mine and took ED on March 8. I highly recommend it!
My "console" is smaller since I did not get Nav.
      04-14-2014, 01:33 AM   #9
John Morgan Evans
Drives: BMW E46 M3
155 is the electronic limit with the better tires, but the car will be able to go faster based on the gearing if the limiter is taken off. I imagine the car will be able to hi 170-180.
      04-14-2014, 07:22 AM   #10
ManCityFan
Drives: Evo IX MR
suspect you'd hit drag limits well before 180.
      04-14-2014, 08:45 AM   #11
overcoil
Drives: M235i 6spd
If you buy a M235 with all/season tires and the restricted top speed, if you go to the dealer at a later time and have summer performance tires with higher speed rating installed - can the dealer techs remove the top speed restrictor of the car?
      04-14-2014, 03:06 PM   #12
MTP335
Drives: 2018 M3
Interested in this as well.
      04-14-2014, 03:43 PM   #13
MTP335
Drives: 2018 M3
Where are you getting this info from?
When I called BMW Genius, and they said all M235i are limited at 155 regardless of Tires.
      04-14-2014, 04:00 PM   #14
golf4501
Drives: 2020 M2C
2020 BMW M2C  [0.00]
It's clearly stated on the web site and the original build documents I got.
But of course, so was a 600 watt 16 speaker HK stereo, and touchless trunk release....
      04-14-2014, 04:05 PM   #15
MTP335
Drives: 2018 M3
It states that a governor is set according to tire selection?
My info came from BMW genius, the number is on BMWUSA's site.
      04-14-2014, 04:23 PM   #16
golf4501
Drives: 2020 M2C
2020 BMW M2C  [0.00]
yes here it is from bmwusa.com when you select Summer tires:
Double Spoke Ferric Gray light alloy wheels (Style 436M) with 18 x 7.5 front, 18 x 8.0 rear and 225/40 front, 245/35 rear Michelin Pilot SuperSport performance tires1, 2 (includes increased top-speed limiter)
      04-14-2014, 04:40 PM   #17
MTP335
Drives: 2018 M3
It's very misleading.
But it still says nothing about run-flats getting a decreased limiter.
      04-14-2014, 04:42 PM   #18
SuitedUp
Drives: 228i MSport
It would contradict the fact that I got the increased speed for selecting MSport package on my 228, but they only come with runflats. Never saw anything about the tires changing it at all.
      04-14-2014, 04:49 PM   #19
golf4501
Drives: 2020 M2C
2020 BMW M2C  [0.00]
process of elimination. run flats= all season=lower speed limiter. There are only 2 options for tires:
Summer (w/ higher speed limiter)
All-seasons (e.g. run flats/lower speed limiter)
The only exception is the poster who somehow got Bridgestone Summer RFT. Who knows what he got for speed limiter (one way to find out though )
      04-14-2014, 08:19 PM   #20
SmallTownBoy
Check the guides. Selecting the a/s tire option "deletes" the high speed limiter. Confirmed it several times with BMW before I bought. Sounds like you need a new genius.
      04-14-2014, 08:25 PM   #21
Lucky13
Lucky13
Drives: 2014 M235 manual, 2020 X3 30X
M Sport on 228 gets you summer performance run flats not all season unless you want all season. I do not believe that the summer performance run flats are limited to 130. I had my E93 335 up to 141 with Bridgestone Summer Performance run flats the original factory tires and I doubt my speedometer was off 11 mph.
1995 325i, 1996 328ci, 1997 528i, 1997 Z3 2.8, 2000 528i, 2001 X5 3.0, 2001 330i Convertible, 2002 M3 Convertible, 2003 M3 Coupe, 2004 M3 Coupe, 2004 Z4 3.0, 2004 X3 3.0, 2007 X3 3.0, 2007 335i Convertible, 2013 X1 28 sdrive, 2014 M235 manual, 2020 X3 30i Xdrive
      04-14-2014, 08:35 PM   #22
SmallTownBoy
My posts are all related to the M235i. The guide was explicit about my model and the info confirmed by my dealer and BMW.
I don't have any info on the 228i with summer perf rft.
