04-01-2020, 04:25 PM | #1 |
Rep 107
Dorch Stage 1 HPFP Review - W/Logs
Hi Guys,
So I just installed the Stage 1 HPFP from Dorch, and here are my impressions so far. Customer service was fantastic, I received the pump after submitting the VIN, but unfortunately since my build date is right on the cusp of production date changes I was sent the wrong wiring harness. A quick call and VM prompted a return call with 1 hour. A new harness was sent overnight the next day. The pump install itself took us less than 3 hours. Great instructions and build quality seemed solid. First run and I could immediately tell my fueling issues were addressed. After reviewing the logs it's clear as day the capacity is much greater. OEM pump +PI - E85 @ 77% PSI dips to 766 PSI https://datazap.me/u/m248/e77?log=1&data=3-10-19-20-21 Dorch Stage 1 HPFP +PI - E85 @ 84% PSI stable entire run https://datazap.me/u/m248/new-dorch-...ata=3-19-20-21
2014 F33 435i M Sport N55 EWG - MHD - Wagner HFC - VRSF 6" Race FMIC, CP & TIC - GFB DV+ - FuelIT Stage 3 525 - EOS PI - Turner Strut Brace - Bilstein B14 - M-LSD - Turner Aluminum Subframe Mounts - PowerFlex Adjustable LCA & TS Bushings - H&R Sway Bars - Dorch Stage 1 HPFP
04-04-2020, 12:47 PM | #2 |
Rep 191,092
Thank you for sharing
