06-22-2020, 03:27 PM | #1 |
Rep 20
Will this burble tune damage my car?
Hey! My 2015 N55 M235i has been tuned to MHD stage 1!
Specs: BMS CP, Eisenmann sport exhaust. OEM dp with cat! I've enabled the "soft" burble tune for 1.2 seconds in sport mode. Is this bad for my car? Video clip: https://drive.google.com/file/d/1TYs...w?usp=drivesdk |
06-23-2020, 09:53 AM | #3 |
Rep 20
06-23-2020, 10:45 AM | #4 |
Rep 191,109
I do not recommend burbles on stock cats.
WolfGTI716.00 OldCrow7xx72.50 |
06-25-2020, 11:01 AM | #6 |
Rep 178
You're literally the pro here so I'm not attempting to disagree with you...
... But I have a stock M235i that only has an axle back delete. Stock tune, stock down pipe. On hot days driving in sport mode, if I hold a gear on deceleration I can trigger massively loud gunshot noises at around 2500-3000 rpm. As far as I am aware, this is par for the course along the entire BMW M/Msport range, meaning this is considered normal operation. If that is the case, why would "burbles" be bad for the stock catalytic converter which I believe utilizes the same core material as high-performance aftermarket street-legal down pipes? |
06-25-2020, 12:35 PM | #7 | |
Rep 191,109
You are probably fine with mild burble, of course whats considered mild is subjective and thats where it gets tricky
07-03-2020, 09:40 AM | #8 |
Driver - Autocross
75
Rep 178
I mean, i use to have my shit firing gun shots and flames out the back so i'd say it's fine. It will wear out the cat faster but if you remove that and set it light you'll be fine.
16 M235xi 8ZF Black on Red FBO: Xhp trans tune -BMS Intake - VRSF Catless DownPipe - VRSF CP - VRSF Muffler delete/resonator - n22 plugs - MHD stage 2+ 95map - Wagner EVO II Preformace IC - Rear seat delete - weight reduction/stripping -FTP 18.5in rims - Hawk HPS front pads - StopTech STR 660 fluid
06-03-2022, 02:31 PM | #9 | |
Rep 3
So what is a safe timing/aggression with an MHD burble on completely stock DPs and Turbos? Also, is it possible to only have the burble tune on Sport Mode? Is this safer? |
06-04-2022, 10:33 AM | #10 |
Rep 191,109
Since I have not seen any cat failures due to the burble, it's safe to say you can use any burble level on any downpipe safely.
06-04-2022, 03:37 PM | #11 |
Rep 709
I just picked up a 2015 yesterday and it has an afe intake and a p3 digital vent gauge on the driver side vent. The exhaust looks and sounds stock but it does have low gurgles on deceleration. How can I find out of it has and what tune it has.
06-06-2022, 12:32 AM | #12 | |
Rep 30
A bit confused as I have seen you on other threads say you run max burbles on your shop's m4. Appreciate if you could clarify! |
06-06-2022, 12:35 AM | #13 | |
Rep 30
You can try holding the resume button, this is the map switcher for BM3 would see the rpm gauge go to 1000 (or any other x000). |
06-06-2022, 09:04 AM | #14 | |
Rep 191,109
I always recommended to not max out the burble on stock downpipes. But with all the data we have now, I don't see enough data showing cat failures due to the bubble tune. I cannot remember a single failure, but you say it happened at least once. Even then, 1 out of tens of thousands is not enough. It also could be due to a defective cat and not the burble.
06-06-2022, 09:43 PM | #15 | |
Rep 30
Yea I think its probably a defective cat as well, some people were arguing on if the welds broke first then it melted. Heres the thread btw, thought I originally linked it https://f30.bimmerpost.com/forums/sh....php?t=1693551 |
06-06-2022, 09:55 PM | #16 |
Rep 30
Heres the other one thread where it happened. N55 as well
https://f87.bimmerpost.com/forums/sh...0#post27017700 |
06-07-2022, 08:56 AM | #17 | ||
Rep 191,109
Like everything else in life, there is a risk but in this case from the data we have its very low.
wantam235i4.00 |
Tags |
burble tune, mhd, stage |
