02-19-2017, 10:00 PM | #1 |
Rep 1,931
The brake pad thread
Welcome to the brake pad thread for all bmw m performance brakes, "Blue Calipers"
Many cars including the newer x40's can use the pads listed in this thread. Thank you for reading through the posts before making a recommendation or asking a question. If you used some advice from this thread, give it a like, or some rep. As of 4/1/17: Please click link below to open the spreadsheet. Do not remove or delete any information. It's being shared, its best to download a copy of it and close the web site to avoid corruption. Please add pads and part numbers you find that are not included in this list. https://docs.google.com/spreadsheets...it?usp=sharing
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic Last edited by bryan_G01; 05-12-2019 at 09:26 PM.. |
Anthony235715.00 goodNIGHT106.50 FakeM215.00 N55guy214.00 Liquidpaper451.00 MadOzodi53.00 Dylan861330.00 Kondzio0.00 KjPerry17.50 |
02-19-2017, 10:21 PM | #2 |
Rep 5,262
These are the ones I found:
Race: Pagid RS29 PFC08 (I believe the 991 Cup comes with these) Porterfield R4 Hybrid (street/track): EBC Yellow stuff Street: Porterfield R4-S Stoptech sport |
02-19-2017, 10:31 PM | #3 |
Rep 1,931
can you gather the part numbers and where you found them, etc?
Will a 228i with M-sport brakes work on a m235?
www.nybmwcca.org
02-19-2017, 11:02 PM | #4 | |
Rep 5,262
http://www.hpashop.com/Porterfield-R...x-standard.htm http://www.hpashop.com/Porterfield-R...x-standard.htm I believe the m-sport brakes are the same, option on the 228 and standard on the M-235 |
02-20-2017, 09:52 AM | #5 |
Rep 1,931
If our sponsors would like to chime in on this thread, I will update the list with your site.
www.nybmwcca.org
02-20-2017, 10:23 AM | #6 |
Rep 1,931
m235 Front and Rear Pads are same as these other cars according to EBC:
Make Model Submodel Engine BMW E90 325i N52 3.0L BMW E90 325xi N52 3.0L BMW E90 328i N52 3.0L BMW E90 328xi N52 3.0L BMW E90 330i N52 3.0L BMW E90 330xi N52 3.0L BMW E90 335d M57 3.0L BMW E90 335i N54 3.0L BMW E90 335i N55 3.0L BMW E90 335xi N54 3.0L BMW E90 335xi N55 3.0L BMW E91 325xi N52 3.0L BMW E91 328i N52 3.0L BMW E91 328xi N52 3.0L BMW E92 328i N52 3.0L BMW E92 328xi N52 3.0L BMW E92 335i N54 3.0L BMW E92 335i N55 3.0L BMW E92 335is N54 3.0L BMW E92 335xi N54 3.0L BMW E92 335xi N55 3.0L BMW E93 328Ci All BMW E93 328i N52 3.0L BMW E93 335i N54 3.0L BMW E93 335i N55 3.0L BMW E93 335is N54 3.0L BMW F30 320i N20 2.0L BMW F30 320i xDrive N20 2.0L BMW F30 328d N47 2.0L BMW F30 328d xDrive N47 2.0L BMW F30 328i N20 2.0L BMW F30 328i xDrive N20 2.0L BMW F30 335i N55 3.0L BMW F30 335i xDrive N55 3.0L BMW F30 340i B58 3.0L BMW F30 340i xDrive B58 3.0L BMW F30 ActiveHybrid 3 N55 3.0L BMW F80 M3 S55 3.0L BMW F82 M4 S55 3.0L BMW F83 M4 S55 3.0L
www.nybmwcca.org
Anthony235715.00 BMWZ41914.00 |
02-20-2017, 04:28 PM | #8 |
Rep 5,262
I think these are another option too... 1609 and 1656 are the pad sizes on the F80 which are the same as the 2
http://www.ctbrakes.com/pads.asp?Make=BMW&Model=M3 http://www.ctbrakes.com/brake-compounds2.asp BMW Year Compounds M3 2014-2015 1521 AX6 XP8 XP10 XP12 XP20 XP24 RP2 F80 Chassis - w/Iron Discs* F: CT1609A $251 $264 $277 $291 $305 $336 $357 $320 F80 Chassis - w/Iron Discs* R: CT1656 $234 $250 $265 $279 $293 $323 $342 $307 Maybe the sheet could be uploaded to googledocs so it can be downloaded... Also might be useful to sort the pads by use case so all the similar pads are together on the list... and adding a price range might be helpful too to have an idea of what would be the total damage |
02-20-2017, 06:33 PM | #9 |
Rep 1,931
spreadsheet now on google docs, please see if you can access.
Everyone should be able to view and edit. I also purchased the PFC08's through my contacts, should be available in 2 weeks and will fit Msport brakes (i was told). I will update with part numbers once I have them.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic Last edited by bryan_G01; 02-20-2017 at 06:45 PM.. |
Anthony235715.00 |
02-21-2017, 08:03 PM | #10 |
Rep 2,214
No experience in this car, yet. But I can vouch on the PFC-08 pad, as being a great endurance pad, with a great operating range, and ability to swap back to factory pads without the need to swap rotors.
I ran the PFC-08's on 370mm 4 pot TT-RS Brembo fronts combined with Carbotech XP-10's on the rear and it was the best road track setup I've ever used. I plan to do the same or similar on the M235i if not the Pagid's or Race Technologies LLC RE10's. All great pads, just some dialing in to be done when it comes to vehicle weight and distribution. For example, on the TT-RS setup, I had the 370mm rotor up front and RS6 335mm rear rotors. This rear rotor upgrade allowed me to run a pad with more initial "bite" to balance the "nose dive" effect from having a heavy duty brake system up front. If I ran the PFC-08's all around, I would probably run into the nose-dive effect again, as the front will absorb most of the inertia and take the grunt of the brake load. With a more aggressive pad in the rear, it moves the bias slightly rearward and helps alleviate that issue. Hope that makes sense? The only $.02 I can apply at the moment, lol
Anthony235715.00 Taunto281.50 |
02-22-2017, 10:13 AM | #11 | |
Rep 1,541
I usually run a less aggressive pad in the back for RWD. I didn't do that with the 235i though. Pagid on all 4 felt great.
Dylan861330.00 |
02-22-2017, 10:17 AM | #12 |
Rep 1,541
I added some Pagid info to the sheet.
02-22-2017, 01:41 PM | #13 |
Rep 845
I'm gonna throw my hat in for the EBC Yellowstuffs.
They are very respectable HPDE pads and are completely tolerable on the street (some low speed low pressure breaking in stop and go has a little squeal) once they are properly bedded. Yes, PCF-08's or Carbotechs or Porterfields are better race pads, absolutely, but they cannot be driven on the street. These can be (quite comfortably). And they will stand up to some seriously heavy abuse on track with the right brake fluid (I run Torque RT700, but any high temp fluid will do -- ATE, Gastrol, Endless, etc.). Also, they aren't terribly expensive. Highly recommend.
02-22-2017, 09:14 PM | #14 | |
Rep 5,262
And I can get the ebc yellow for $230 shipped which is less than half the price as the pagid A bit off topic but anybody have seen the new hankook RS4? Might switch to those once the RE-71r are don |
02-23-2017, 10:16 AM | #15 | |
Rep 1,541
I'm talking purely from a pad fade perspective.
02-23-2017, 10:23 AM | #16 | ||
Rep 845
02-24-2017, 04:56 PM | #17 | |
Rep 187
Will dust heavily after hard breaking. The red stuff (ceramic) keep my wheels much cleaner. |
02-24-2017, 04:58 PM | #18 |
Rep 845
Agreed on the squeal and dusting. Personally I don't care about brake dust (badge of honor for using "good" brake pads), but I totally understand those who want super clean wheels. However, the first thing you normally have to give up for "good" brake pads is the dusting unless you get carbon ceramic pads/rotors.
02-24-2017, 05:23 PM | #19 | |
Rep 5,262
Liquidpaper451.00 SteveInfante604.00 |
02-24-2017, 07:17 PM | #20 |
Rep 986
I use wheel wax between wheel cleanings
http://www.autogeek.net/wheelwax.html I ran the stock OEM sports, and the EBC yellows so far on a far amount of HDPE's last year. About 20,000 street miles plus 6 days on each set... not bad. I like the EBC yellows and would use them again. They work great on the street. A little bit more initial bite than needed for regular daily driving/stop-n-go, but it's bearable. Some slight noise. But they stop good combined with ATE 200. |
bryan_G011164.50 |
02-26-2017, 01:35 PM | #21 | |
Rep 1,931
Im going to try them for DD and track.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic Last edited by bryan_G01; 11-27-2017 at 10:48 AM.. |
03-02-2017, 07:27 PM | #22 |
Rep 1,931
bump. try to keep this on first page, or make it a sticky.
www.nybmwcca.org
