05-24-2016, 07:29 PM | #23 |
Rep 3,066
B58 is a great engine - pulls hard and the 8AT is even smoother (8AT50HP) than the M235i 8AT (8AT45HP). Honestly, I don't think you can go wrong. I made the switch from 340 to M235i because I had the chance to jump on one with LSD. Otherwise, I would have stayed with 340i. If 240i + LSD is available then I don't want a M2 anymore :-)
05-24-2016, 07:50 PM | #25 |
Rep 2,214
What's changing exactly?
D
05-24-2016, 08:01 PM | #26 |
Rep 5,538
05-24-2016, 09:39 PM | #27 | ||
Rep 1,117
Drives: 2015 BMW M235i
05-24-2016, 10:51 PM | #28 | |
Rep 53
Drives: 2017 M2 LBB DCT
Even though I had to go with an auto this time due to increasing troubles with my left knee, my biggest takeaway from the test drive is that the auto rev matching manual made me sad. |
05-25-2016, 02:41 AM | #30 |
Rep 261
Maintenance is only worth a few hundred to me and isn't enough to sway my decision on a $50K car. I've always consider it a gimmick to build consumer confidence instead of a real value.
05-25-2016, 08:24 AM | #31 | |
Rep 5,538
Last time I got like 4-5 oil changes, 1 brake fluid change, and front brakes and rotors replaced for free. That's about $1200-1300 worth of work at the dealer. If you can get that done for free I think it could be worth it. edit: they might have replaced front and back, i forgot Last edited by Kolyan2k; 05-25-2016 at 06:07 PM.. |
05-25-2016, 09:03 AM | #32 |
Rep 5,262
rotors and pads won't be covered on the new plan either
05-25-2016, 09:16 AM | #33 |
Rep 227
Which depending on the car can be $1500-$2k of value.
Current
19' G05 X5 40i 03' e46 M3 Convert. Past09' e90 335d, 11' E70 X5d, 16' F22 M235xi |
05-25-2016, 12:48 PM | #35 | |
Rep 9,134
05-25-2016, 01:00 PM | #36 | |
Rep 5,372
The additional power of the B58 is a welcomed addition for sure, but we all know adding more power to the N55 is quite easy and cheap. BMS is still sorting through the tuning aspects of the B58 and is only recommending Map 1 for their B58 tunes on customer cars as there are still some hiccups and things to be learned about B58 and its new DME. |
05-25-2016, 01:35 PM | #37 |
Rep 261
05-25-2016, 01:37 PM | #38 | |
Rep 1,154
05-25-2016, 01:41 PM | #39 |
Rep 261
Since timing chain is not a wear item I'm not overly concerned. The drive belts on the other hand do need periodic replacement and I would like to do that myself.
05-25-2016, 05:25 PM | #40 | |
Rep 5,262
Basically you didn't make use of the money you pre-paid for brakes and rotors when you bought the car |
05-25-2016, 05:35 PM | #41 |
Rep 261
They get used when needed. I've had to do some hard braking, but most of the time it's just coasting and light braking. I got pretty good gas mileage (29mpg+ for 2/3 hwy 1/3 local) even though I have a lead foot. Repeated cycle of hard acceleration and braking is what wastes gas.
05-25-2016, 06:11 PM | #42 | |
Rep 5,538
But again, could be an issue could be not, and even if its an issue, we are talking closer to 100k miles when it can fail |
05-25-2016, 06:45 PM | #43 |
Rep 63
Whenever I have to pull the motor in a car I own, that means time to build it and make power. So if I HAD to pull the motor for some maintenance issue... then it just becomes and excuse to go crazy
05-25-2016, 07:10 PM | #44 | |
Rep 5,262
