2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Valve Cover Replacement
      04-03-2023, 11:20 AM   #1
123Britt
Drives: 15 M235i AT
At just under 85K -- Oil leaking from VC -- went ahead and replaced with OEM Mahle VC.
I believe that the photos show that the old cover was full of hardened & crusty oil carbon type stuff. Although the old cover was not warped or cracked that I could tell - the small passage ways for the PCV oil separator would be difficult to properly clean ~ glad I change the Cover and not just the gasket.
On my old N54 engine I had just changed out the gasket.
The gasket on this R&R was brittle and would snap crack at the lower locations of the cover close to the exhaust manifold (heat cycle issue for sure).
Note: OCI have been at 5K miles with PP Euro 5W-40
Rear most (3) Cover bolts were difficult to access but using my 1/4 flex extension it was doable and was even able to torque all 3. I did oil prime by leaving the injectors unplugged but it is not necessary. Followed up with clearing codes with my Autel OBD Scanner.
overcoil3075.50
Cos270608.50
      10-15-2023, 04:31 AM   #2
este
N54 to N55
este's Avatar
66
Drives: e92 335i (sold) / M235i 6mt
Going to tackle job soon, any specific guides or video you followed?
      10-15-2023, 06:58 PM   #3
John in VA
Drives: 2015 228i M Sport
Check https://www.youtube.com/results?sear...rt+valve+cover
este66.00
