07-29-2016, 08:40 AM | #23 | ||
Rep 818
steady application of throttle minimizes lag, 0 throttle & then mashing the throttle maximizes lag.. since the turbo was in a vacuum and then immediately expected to produce boost with no exhaust gasses. I don't have the time now, but there are resetting procedures for the transmission. The transmission learns your driving/throttle habits and adjusts itself based off of that for maximum comfort. I've driven several hundreds of BMWs and some are sensitive and others are dull and laggy. The adaptations depend on how you drive it. Quote:
I don't want 100% throttle at 50% actual throttle, then 0 throttle input for the rest of the pedal. That's dumb to me. My car is fast enough to where it doesn't need another system to help me 'think' my car is fast (or faster than what it is). |
07-29-2016, 09:25 AM | #24 | |
Rep 669
Picture this. I coast to an intersection where I cant see cars coming in from either direction, so I let it coast a little further till I stop completely. I want to turn left, and I decide to go and right then I see a car coming in fast. I nail the pedal to the floor in an attempt to move out of the way. My car does absolutely nothing, as if I didn't even press the accelerator. I had held the pedal down for a second, still nothing. Because of all the factors (angle of car, angle of steering, etc), the car decided it was best to not do anything than to risk spinning tires. That was the worst one Ive had. I usually have the same issue at short stops. Stop, quickly look, accelerate. Car takes 1 sec before it even processes the input. Disabling DTC has mostly fixed this problem. Has made the car much more fun to drive too. I used to have an STI. This car sure had turbo lag. But even with turbo lag, a car should start moving or reacting to input, till the turbo kicks in. |
07-29-2016, 09:37 AM | #25 | |
Rep 580
I don't understand why so many people feel that the Sport modes make the throttle too sensitive. Since BMW installed throttle by wire their cars have had less than stellar throttle response even in NA engines. There are any number of kits available to overcome this problem.In a car with Sport mode this isn't necessary,so I use it. It definitely is less laggy and the engine sounds like it is getting the amount of fuel it needs to make maximum power. In Comfort it sounds a bit strangled.Those are subjective impressions,of course. |
amw896582.50 |
07-29-2016, 09:53 AM | #26 |
Rep 15
07-29-2016, 09:56 AM | #27 | |
Rep 15
Yes, I actually posted this after nearly being sideswiped pulling into traffic the other day. I pulled into a tight gap in heavy traffic and the car just basically ignored the gas pedal for about 1 second. That's how you die. When it finally decided to wake up it chirped the tires but I would have been hit if the oncoming car didn't slow down. It's very inconsistent and not like turbo lag which is pretty easy to predict. |
07-29-2016, 09:59 AM | #28 | |
Rep 15
07-29-2016, 10:31 AM | #29 | |
Rep 2,010
Have you taken it to BMW to have this problem checked out?
07-29-2016, 11:03 AM | #30 |
Rep 5,538
Will check mine today. I did notice lag when launching, but I figured it's due to my poor clutch work.
I only use Comfort mode on shitty roads, otherwise I am in Sport. In Comfort car does feel like a M Performance Buick lol )) |
DRitch9.50 |
07-29-2016, 11:56 AM | #31 | |
Rep 669
Given that it fixes itself when I reset adaptations or when I put it in sports mode, I took it as that it was working as intended. Selling the car now. Really wish the M235 xdrive came in manual. That would have been my next car |
07-29-2016, 12:02 PM | #32 |
Rep 5,538
Why do you want xdrive in MA? It's useless here, and RWD is much more enjoyable to drive
07-29-2016, 12:40 PM | #33 |
Rep 2,248
07-29-2016, 12:45 PM | #34 | |
Rep 2,248
Incidentally, Sport mode with 6MT in my new car is very satisfactory -- much more so than with AT, as you still have complete control over shift points and gear selection, including the tallest gear, which Sport mode locks out on the AT because it is such an extreme overdrive gear. |
07-29-2016, 12:46 PM | #35 |
Rep 2,248
You can get a 340i in manual. It's a little bigger, but with the track handling package it should be a great car. Also, RWD with 6MT is a good combination that will -- with adequate winter tires -- get you around in any weather that doesn't require higher ground clearance, which the xDrive doesn't really offer anyhow.
07-30-2016, 09:02 AM | #36 | |
Rep 5,538
Do you use launch control on auto? Isn't that supposed to build the boost in turbo? |
07-31-2016, 09:04 AM | #37 | |
Rep 72
Bozman |
07-31-2016, 09:41 AM | #38 | |
Rep 891
J/K. Seriously though, in 40+ years of driving, all manuals, this is the first turbo car I ever owned. There is no question in my mind that there is a slight hesitation when getting on the throttle in this car unless the turbo is already spooled up. It's really noticeable between shifts when accelerating. It's just a split second, but it makes all the difference. All my previous cars have been NA V-8s, and this is certainly a different experience. My 2005 Mustang wouldn't skip a beat between shifts, and consequently a hard shift into second will lay down two fat thick rubber strips 20 feet long or so, with Traction Control ON. That said, I've tracked this car twice - once at Palmer MA and once at Watkins Glen - and the turbo lag is not a factor on the track. Reason is, the inputs on a track should be smooth, so when easing into the throttle the acceleration is smooth.
Previous: 2018 Camaro 2SS 1LE 6MT; 2015 BMW M235i 6MT; 2015 Mini Cooper F56 6MT; 2005 Mustang GT 5MT; 2003 Mini Cooper R50 5MT |
07-31-2016, 01:47 PM | #39 |
Rep 3,842
For me, M235 performs best in DSC off mode (4 second long press on the button).
Sport mode is ok if you need the nannies in bad weather, but in dry warm conditions DSC off is safe and it will set your car free. The car won't twitch every time it slips just a little bit, this really annoys me. In DSC off the rear end simulates a locking differential and the auto transmission shifts super fast. It's also possible to use the throttle when manual shifting the auto tranny just like you would with a manual transmission but without the clutch. You can make completely smooth shifts this way. In DSC off the steering is tight and the throttle is normal...the car doesn't go any faster with the sensitive throttle in sport mode, we know it is just a head fake. I stopped using sport+ since it seems to exaggerate wheel spin for no reason. By using manual shifting the only lag I get is a split second from a dead stop. By flipping the shifter to the left the auto tranny does a pretty good job but it still gets caught out on occasion. |
08-01-2016, 03:37 PM | #40 |
Rep 261
I've been driving mine for about a year now. What I've noticed is that it's not just a simple turbo lag. The lag is there definitely. However, the throttle map and the ECU's response to it also matters a lot.
Everybody's aware that the gas pedal these days are drive-by-wire and ECU actually controls the juice. While sport mode works to keep the RPM higher for AT's by shifting later, it does nothing for MTs since the driver selects the gear. What sport mode on MTs do is simply remap the throttle curve from a lazy-linear to a more log-shaped curve. I get the same sort of response from my PedalBox. Now there are many who will say that throttle remap is unnecessary and you can get the same feel by mashing the pedal. This is not borne out in my tests and what I find is mashing the pedal does not give the same sort of feel as a more aggressive map. I have a theory that the ECU interprets throttle input's dv/dt slew rate and assigns an "urgency" rating, with higher dv/dt generating a higher "urgency". And that my right foot on a flat curve simply cannot generate the dv/dt that matches one from the remapped throttle. |
08-01-2016, 04:22 PM | #41 |
Rep 15
I have a service appointment for something else this week. I am going to talk to them about it then and schedule another one if necessary.
08-01-2016, 04:26 PM | #42 | |
Rep 15
08-01-2016, 04:43 PM | #43 |
Rep 8,942
If you're still not happy after the service appointment and they've verified nothing wrong with the car, rather than getting rid of it right away I'd try a Dinan tune. I say Dinan for a number of reasons. Yes it's the most expensive but you're already having issues so the warranty is good. And if it doesn't help, you can return it and you're only out the $200 install. They say 3 days but I just got one on my dad's sport wagon and they agreed to a week since getting up there in the middle of the week was a hassle. Seems like a good thing to try before taking a beating getting rid of the car.
08-01-2016, 07:03 PM | #44 |
Rep 2,248
I'll try again. I've experienced this in my 528i. It's frightening. It feels like the engine room is on strike or just ignoring the command from the bridge. It is completely solved by moving the transmission lever to the left into "S". It's a transmission software issue.
Tags |
auto, m235i, throttle response, xdrive |
