2Addicts | BMW 2-Series forum BIMMERPOST Universal Forums General BMW News and Cars Discussion Turbo E36 M3 -- It's under the knife!!.....I EXCITE!
      01-20-2010, 03:30 PM   #155
IL X5 M60i
IL X5 M60i's Avatar
Drives: 2025 X5 M60i
Originally Posted by gonzo View Post
Look at all that gook.
A little secret. Ball bearings.
"Everything is ball bearings these days"
      01-20-2010, 03:35 PM   #156
Sniz
Sniz's Avatar
659
Drives: e92 335 - gone // e36 M3 turbo
thats called excessive oil blow by and blown oil seals on the old turbo!
I'll have it all cleaned up and looking spanking new soon
      01-20-2010, 03:43 PM   #157
gonzo
gonzo's Avatar
Drives: as many as possible
Yep. It's because of the ball bearings.
Seriously. Looking good. She will breathe better/easier for sure.
      01-20-2010, 03:50 PM   #158
Sniz
Sniz's Avatar
659
lol at that movie reference...love it.
I was pretty shocked at how pristine those pistons and cylinder walls look after 86k miles!!! almost 25k of those have been turbo'd. Proves the tuning was top notch.
      01-20-2010, 04:12 PM   #159
anthony @ eas
anthony @ eas's Avatar
Drives: R56 Cooper S
Nice. Thanks for taking the time to take all those photos.
      01-20-2010, 05:06 PM   #160
GreenPlease
GreenPlease's Avatar
Drives: BMW 335i e92
The cylinders look great! Got to love I6s. When they're well put together they'll last forever
Cars>Women
      01-20-2010, 05:26 PM   #161
Sniz
Sniz's Avatar
659
I was absolutely shocked at the condition....in a good way of course!!!
no marring, etching, signs of any detonation, etc.
the pistons look fantastic.
      01-29-2010, 04:20 PM   #162
Sniz
Sniz's Avatar
659
head is back from the machine shop along with my wastegate piping. Apparently the flanges on both ends were pretty well warped from the welding, explains why I couldnt get rid of the exhaust leaks!!
and the pooch looking at me like i'm crazy for having the head in the kitchen island like some sort of HP shrine
      02-04-2010, 01:45 AM   #163
JerzeySux
UrMother
South Korea
37
Drives: 335xiE92
Wow your cars cleaner than my 08 coupe DAMN
My Car drives on Sour Diesel and Haze.
Dutch and Green Palma's for Octane Boost
Poor Man's BMW Owner.
      02-04-2010, 02:34 PM   #164
Sniz
Sniz's Avatar
659
start cleaning!
it didnt come to me that way I can assure you.
      02-04-2010, 03:12 PM   #165
MisterSkiMask
Drives: I Can not say
This is getting exciting again!
      03-04-2010, 08:23 PM   #166
Sniz
Sniz's Avatar
659
hey guys, i'm back!!!
Went thru a pretty bad sinus reconstruction in early in early February and then the crazy ass blizzards we've had around here so no work on the car in wayyyy too long.
Here is where I am now. Thanks to a great member here I got a great rundown on how to properly prep the block in car and get ready for oringing. Local member Boris is lending me his oring tool, thanks man!
Today's progress, more will happen Saturday as i'm slammed tomorrow w plans in the evening.
1st step
sealing the cylinders so no metal shavings or wd40 (which will be used as lubricant for the honing stones I'll be using on the block later) enter the cylinder which could certainly cause damage.
I've been trying to figure out the best way. What I ended up was using 3" PVC screw in end caps and sanding down the threads to get just under a 3 3/8" OD which pretty closely seals the cylinder. I had to cut off the end blocks on the caps and glue them to the underside to reduce their height.
2 of the cylinders I cut a few circles w a 3.5" hole saw, or I should say Adam did. Put those on top of the PVC caps to bring the level up to make it easier to seal with Silicone.
Here is the end result, all nicely siliconed up so seal it. Silicone will be easy to remove after the block prep is done.
close up to see the level, its close to the block height but I made sure it was below by a few mm for clearance.
More to come and i'll try and keep it as detailed as possible.
For more good news and a bit of fun, Adam got some new wheels for his ESS s/c M5
I am in love with these wheels, wish I could find a set for my M3. 18x9.5" in the rear and only 19lbs! Wrapped in 275 Ps2's in the rear. He's still having traction issues at the top end of 2nd gear and into 3rd.
and hows this for a clean interior on an e39, freshly detailed and a nice coat of Poorboy's Leather Stuff, the seats drank it up....and god the smell is good!
and a great addition to the garage, tankless hot water heater FTW!!!!
Adam hard at work
Giggity!! No more freezing hands baby
      03-04-2010, 08:40 PM   #167
DisGuy
Drives: M Three Powah
damn that m5 is so clean. makes me so jealous, i wish i owned one.
      03-04-2010, 09:56 PM   #168
Sniz
Sniz's Avatar
659
yeah man its a fantastic car, he put a ESS supercharger on it a little bit ago, now added the Fiske wheels....I dont think he's done either. Its a super super clean example and fast as stink!
estimated 460whp or so. We'll see soon enough.
See here:
      03-06-2010, 10:46 AM   #169
Sniz
Sniz's Avatar
659
BLOCK PREP
many thanks to Don - dcvee for this technique, he was nice enough to take his time and explain this in a PM to me. Thanks man!
1st up
use plastic scrapers you can pick up at Home Depot for a few bucks and lacquer thinner to get the top of the block clean, removing all gasket material.
2 honing block in 6"x2"x1" in both coarse and fine from McMaster.
The coarse block before being used.
Now that I had the block all sealed up, I can use wd40 for honing oil without it getting down into the bores and damaging things.
started with the coarse block, wet it with wd40. Start from the front of the block by cyl 1 and with the stone hanging over each side of the block use even pressure and small circular movements and grind all the way to the back of the block. Keep the stone hanging over the block at all times!
Work from front to back, then back to front. This is one pass. I did 2 passes with the coarse, keeping it well lubed. Then wipe clean with lacquer thinner and do 1 more pass.
here is what the block looked like after 2 passes.
Then use the fine block and do 3 passes with the same technique.
Me hard at work, shoulders started getting tired!
Again clean the block really well w the LT.
Now take some 400 grit aluminum oxide wet sand paper and wrap it around one of the blocks, wet with wd40...spray the block too. Make 6 passes with the sandpaper. this will really smooth it out and bring up the shine.
and you end up with this after you clean it all up.
and after the bore plugs are removed and cleaned.
Originally Posted by Matutino View Post
Waiting for full write up Sr.!
ask and you shall receive
      03-06-2010, 11:45 AM   #170
O-cha
O-cha's Avatar
218
Drives: Mcoupe
What about the oil and coolant passage ways...
      03-06-2010, 12:13 PM   #171
Sniz
Sniz's Avatar
659
they will be flushed, oil pan is coming off once the head and transmission go back on. New oil pump nut and pan gasket are sitting next to the car.
      03-07-2010, 07:21 PM   #172
Sniz
Sniz's Avatar
659
Spent the afternoon working on the car again. Spoke with Donovan and Boris today picking their brains on how to use the Isky Groov-Matic oringer. Once I really took a good look at the thing it was pretty obvious how it worked. they did however have a few very helpful hints that I put to good use.
Before I get into this at all, quick question........how much of the .041 copper wire should I leave exposed above the block? I've heard between .015 and .008, thats a big difference. Any defenite answer for use with a MLS hg??
anywho. 1st thing is 1st. The tool is pretty sweet, does a great job assuming your patient and use your head.
My car as it stands before I started today. It was SOOOO nice to be able to work with garage doors open instead of huffing kerosene fumes all afternoon. Bring on the warm weather!!!
Adams sweet Ranger bass boat, cant wait to spend some time out on the water chasing the hogs this year :redspot
Ok, the important stuff
Important that the block is well prepped BEFORE you begin this. Dont oring before you prep the block.
The Isky Grooooooooooooov-Matic. This one belongs to Donovan so I put in this little shameless plug for MaxPsi. Thanks man, HOVA ended up sending it to me instead of back to D. I was going to borrow Boris's but this showed up Friday....might as well use it right?
It has 3 adjustments. The 1/2" bolt on top pushes the 4 "spanners" out to make solid contact with the cylinder walls and place the 4 pins on top of block. There are 2 allen screws that control the distance outside the bore you cut and another for depth. Thats it really.
I decided to tape up the coolant/oil passages again to keep the grease and shavings out. I'm still going to flush these passages before reassembly but might as well not get thick grease down there.
After the grease was applied along the cylinder walls to help the oringer move and on top of the block to catch the shavings.
1st step for adjustment.....setting the cutting distance outside the bore. On the S52 you need to do a figure 8 style oring so they will intersect between each cylinder. YOu just have to play with the settings and get it right. Per Boris's advice I put a nice thick layer of grease on top, set the depth to not really cut into the block but just the grease and adjusted from there. Ended up with this after setting depth a tiny but below the block to see a cut.
pretty good!
Now for depth. Since we use a .041 wire you cut 4 pieces of it, put them under the 4 pins, then use a feeler gauge under the cutting blade to set your depth. I started with .031 under the blade to cut .01 into the block. Then moved down from there until I had cut .016 into the block making .015 of the wire exposed. If I need to cut in more I can, but I cant add the material back so I stopped there.
You can see the 4 pieces of wire here
and clearer here, also note the feeler under the blade for depth adjustment.
Start at either cyl 1 or cyl 6 and kick that blocks ass.....seemed 8-12 full rotations were needed for each cut.
Meeting in the middle nicely
Somewhere in the middle of the job
all finished for today :buttrock, as you can see the pins rotating on top of the block will clean the grease away.
Tomorrow I hope to install the wire assuming I get the answer I need on the depth.
      03-07-2010, 07:34 PM   #173
CubanJJ09
Drives: like an asshole
2007 BMW 335i  [6.18]
Awesome diy instructions. I'd never do this but nice to see how it's done. Looking forward to the next steps.
      03-07-2010, 08:11 PM   #174
JerzeySux
UrMother
South Korea
37
Drives: 335xiE92
This is gonna be crazy.
After everything is done and finished with how much $ are you gonna be down and how much you looking to resale if you do decide to part with it and what numbers are you expecting in finished project?
Just the exterior of that M3 looks flawless. Thinking to get rid of my 335 after warrantys gone and get a e36 M3 as well.
      03-07-2010, 08:18 PM   #175
O-cha
O-cha's Avatar
218
Drives: Mcoupe
You had the transmission out as well? It would take you maybe 30 minutes to get the rest of the engine out then... your nuts.
Nice progress, gonna be a beast.
      03-07-2010, 08:41 PM   #176
FStop7
I like cars
FStop7's Avatar
Vatican City State
331
Drives: M6
I EXCITE!
