06-15-2015, 04:20 PM | #1 |
Rep 17
M235i...jb4 map 1 :thumbdown
hey to all.
i got the 2015 m235. i put the jb4 and driving in map 1. according to the company its sould give 60 hp. in reality the car is weak,Although there is a change. to me its seems that first till 3rd gear is good and 4rd and upper gears are weaks. and i think there's a legging when i touch the gas paddle untill u feal it. can u pleae help me? i am disappointed of this car... rt: (why is all the reviews only Praise this model) |
06-15-2015, 04:37 PM | #2 |
Rep 596
Sorry to hear you aren't enjoying it. What do you normally drive to get the feeling that an m235i is weak? Unless you're experiencing some sort of fault, the car should feel anything but, even stock. Did you have much time driving it stock before you put the jb4 on?
06-15-2015, 05:16 PM | #6 |
384
Rep 548
Are you sure you are running map 1 and not just map 0?
Have you done any updates to the latest firmware? Did you connect everything right? Lots of factors could be affecting your situation. |
06-15-2015, 05:32 PM | #8 |
Rep 926
although I dont have the m235i anymore, i can relate to this post. Map-1 over map-0 doesn't have much of an improvement. Few other people and I were also disappointed in this car despite all the praises which got us switching over to a porsche.
also the symptom of not pulling after 3-4th gear is normal too at map 1. that is fixable once u go map 2+. |
06-16-2015, 08:35 AM | #9 |
Rep 17
it is connected fine, when i connect the laptop, i see map 1.
yes i update the firmware.. i do not use other maps because i been told by jb4 that this is the only map i can use, the other maps required car parts modification. 1.how do i making log file? 2.what i need to change that i will be stage 2. 3. is it imported to replace the charge pipe (i reed that it helping fiil more power and less legging) |
07-06-2015, 10:11 AM | #10 |
Rep 17
sorry for being late...
hey guys,
there are my logs files in zip for 2 test : - 3rd gear , jb4 - map1 in the zip files there is: a) 2 sheets in 1 excel file b) 2 png files of 2 graphs c) 2 jpeg files of 2 specs please notice that in the excel file, there is 2 sheets in 1 excel file. |
07-06-2015, 10:13 AM | #11 | |
Rep 167
07-06-2015, 11:09 AM | #12 |
Rep 190,807
You are hitting 4 psi over stock boost.
Not sure why you are saying this is weak If you want more power add catless DP and E85
07-06-2015, 01:00 PM | #14 | |
Rep 190,807
No i meant 4 psi. Stock boost is not 12 . it is 9-10. On the log you have boost ECU_PSI column gives you stock boost ; Target will give you how much the JB4 is trying to add ; Boost will give you the actual boost. You can see that the JB4 is adding anywhere between 3-4 psi across the RPM range.
07-06-2015, 01:24 PM | #15 |
Rep 397
07-06-2015, 01:50 PM | #17 | |
Rep 190,807
Please make sure when you are asking a question to quote me so i get a notification. Thank you.
07-06-2015, 02:01 PM | #18 |
Rep 17
mike
07-06-2015, 02:09 PM | #19 | |
Rep 190,807
Contact Burger Tuning technical support before changing boost on the JB4.
07-06-2015, 02:13 PM | #20 |
Rep 17
07-06-2015, 02:14 PM | #21 |
Rep 190,807
07-06-2015, 02:26 PM | #22 |
Rep 17
can u please help me to know what is all the specs in the log file ?
1) iat 2) fp_h 3) avg_ign 4) duty cycle 5) trims 6) dme_bt 7) afr 8) afr2 9) meth 10) fp_l 11) ff 12) load 13) clock 14) fuel en 15) pwm 16) WOT only Thanks a lot |
