2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum M240i brake noises
      04-09-2024, 04:05 PM   #1
beeian
Drives: M240i
M240i brake noises
Hi, I recently purchased a 2019 M240i and I have been having these weird brake creaking sounds when I press the brakes after starting the car and it seems to disappear after the car warms up. The sound comes up when I put the car in D and slowly release the brakes and when I come to a stop. I'm thinking maybe I need new brake pads and rotors unless this is the notorious m brake sound.
https://www.dropbox.com/scl/fi/wgntg...48djafod9&dl=0
      04-09-2024, 04:14 PM   #2
Shirazkhan
No_Country
28
Drives: bmw
That does not sound normal.Remove the wheels and have a look see.
      04-09-2024, 06:41 PM   #3
amutti
Drives: 2021 Convertible M240i Xdrive
Sounds to me like the brakes arent engaging, then engaging. Like they are sticking. Any stutter or skipping feeling in the pedal? Have you checked the brake fluid level? Is it only the rear brakes?
      04-09-2024, 08:29 PM   #4
beeian
Drives: M240i
It's only the front brakes, I don't feel any stutters or anything the car feels perfectly fine. I haven't checked the brake fluid level but I am going to go check and ill get back to you.
      04-09-2024, 08:30 PM   #5
beeian
Drives: M240i
I just moved I haven't had a chance to take off the wheels but ill take that into consideration.
      04-10-2024, 02:44 PM   #6
beeian
Drives: M240i
So I ended up taking the vehicle to a bmw specialist and turns out the noise is completely normal. I guess since I’m out in Houston our humidity causes the brakes to creak.
      04-11-2024, 02:25 PM   #7
Shirazkhan
No_Country
28
Drives: bmw
Ok.Then the video just made it sound weird.But now u can have peace of mind.
      04-12-2024, 02:28 PM   #8
morphomeman
morphomeman's Avatar
593
Drives: 2015 M235ix
2016 BMW X3  [0.00]
2015 BMW M235ix  [0.00]
The brakes on all the BMWs we have owned squeal on first use after a long rest. And the larger the diameter, the more they squeal. Next time, look at the disks and you will see how rusted they are. It's the nature of the beast.
