04-05-2024, 10:44 AM | #1 |
Rep 1
Stiff clutch springs?
Hi all,
I wanted to ask for some advice regarding the clutch on my 2016 218i F23. I've had it 6 months and I'm still struggling to get used to the clutch - as it's a lot stiffer than any car I've had in the past. This also makes it difficult to get the biting point every time without judder. Although it does engage well. However, whilst driving the other day, I noticed if I have the footwell heating on, the clutch pedal eases. Which makes me think it's to do with the springs heating up and becoming looser. Does anyone have any experience of this or know how to potentially make the pedal lighter and easier to feel the bite? Any help would be greatly appreciated 😊 |
04-05-2024, 06:29 PM | #3 |
Rep 1,817
Clutch engagement on my car is about 1 to 1.5" (2.5-4cm) travel, is that too much? I did install a clutch stop (spacer at the end of travel) but rarely bottom out on it. The judder is a "BMW thing" and I've seen several reviewers comment on it.
You may just need to adjust your seating position or practice how far to press the clutch when shifting. |
04-05-2024, 06:30 PM | #4 |
Rep 1,020
Pretty sure most of the resistance you feel is going to be the actual clutch release springs (via hydraulics), not in the footwell. Yes there are some in the pedal assembly, you could try lubricating them, but I doubt it will make a difference.
Strong springs are almost certainly better than the alternative. Not sure this is a problem unless there are other symptoms. |
