10-31-2014, 03:18 PM | #67 | |
Rep 872
A loss over stock air box?
Current: 2023 M2
PAST: 2022 Audi E-tron GT, 2021 Lexus LC 500, 2020 Maserati Ghibli S, 2015 M235i, 2014 Audi TTS, 2012 Lexus IS-F, 2009 BMW 135i, 2004 VW GTI |
10-31-2014, 03:19 PM | #68 |
What goes here?
454
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
BMS intake fs.
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
10-31-2014, 04:32 PM | #70 |
Rep 536
The stock airbox intake with a high flow filter is best for sure !! i have said this more than once !! vbox data i have gathered validated this and is very repeatable
10-31-2014, 04:55 PM | #71 |
Rep 860
What high-flow filter are you using? Any others with recommendations?
"Anima sana in corpore sano"
10-31-2014, 05:05 PM | #72 |
Rep 536
Hi TTBEAR hope your well mate !! I use the K&N drop in filter and have the AFE intake deflector installed to ram cooler air into the stock airbox works really well for me.... you also remove the rubber flap over the top of the vent to make it work flow and fit correctly !! http://afepower.com/shop/details_new...rtno=54-12208&
10-31-2014, 08:55 PM | #74 |
What goes here?
454
Rep 1,356
fs = For sale
2019 G30 M550i
10-31-2014, 09:15 PM | #76 | |
Rep 3,320
I'd be interested in a video of this , its kinda hard to believe but then again I've been wrong before |
10-31-2014, 09:52 PM | #77 | |
Rep 678
What was the install like? Looks as if the bumper has to be pulled to install? I have not seen any dyno pulls of stock vs BMS. makes me wonder if it would still loose peak numbers on the stock tune or with the jb4? Perhaps just a dinan thing or perhaps stage II dinan would fair better with BMS intake? It will be interesting to see if and when we get some real world numbers of the Dinan Stage II when it gets released. That is looking to be a closed box intake, my personal preference. I am guesstimating the dinan intake to come in at $1200 based on pricing I have seen for other series.
2022 M4 Comp X 2021 M440ix - Sold 2015 M235 - Sold |
10-31-2014, 09:57 PM | #78 | |
Rep 536
Hi There G-Mann no bumper removal !! just the right hand side grill !! Pretty simple and effective install... can be alittle fiddly due to space restriction , but take your time it all lines up pretty sweet !! I have noticed the IAT drops by around 3 degrees which doesnt sound like much but when pushing the envelope on performance it all helps !! I also note the IAT drops alot faster after heat saok due to the additional air flow into the airbox !!
10-31-2014, 11:13 PM | #79 | |
Rep 860
I knew there was a reason I was holding back on purchasing an intake
10-31-2014, 11:44 PM | #80 |
Rep 536
11-01-2014, 05:40 AM | #81 |
Rep 70
11-01-2014, 12:19 PM | #82 |
Rep 1,040
Okay, time for a custom intake system now. Run to Home Depot and get about 5 feet of dryer hose and Duct tape. Cut a opening in the firewall and pass the hose from one of the interior air vents to the intake snorkel in the engine. Run the A/C on Max recirculate and close off the rest of the interior vents to keep from freezing to death. This will stop all this heat soak nonsense!
11-01-2014, 12:43 PM | #83 | |
Rep 70
11-02-2014, 01:20 AM | #86 |
Rep 4,525
Chaddy
I have similar set up but with an AFE dry drop in. Can you elaborate some more on the rubber flap removal ? When I installed my ram air scoop, all I saw was the oem rubber gaiter which is reinstalled to secure air scoop. Thanks |
11-03-2014, 08:45 PM | #87 |
Rep 100
After my disappointing results with the ER non catted DP-400/450-no gain over stock down pipes,I figured I would try the K&N drop in first before an open intake.
I have not been back to the dyno but did not pick up any trap speed when I ran it at the strip. trapped even lower! Another 12.0 but only 113mph although the DA was much higher compared to the day of my PB 11.49@114.3 with the stock filter.Also added a can of Torco to E30 so I am sure octane was higher. I have a BMS intake waiting to go on but may be I can return it since it is still in the box and buy the one Alz0rz has for sale as he is local.Let me know hw much you want for it, boss. Plan to get back to a dyno after the intake since all the local tracks are closed(may get one more run this year in Morocco near Chicago as I have run as late as mid-Nov in the past) |
11-03-2014, 10:23 PM | #88 |
Rep 3,427
Well nothing surprising tregarding a drop-in...changing the filter will have absolutely zero effect on performance.
All dynos have shown consistent 8-10 RWHP and 20 RWTQ gains with an intake (BMS and aFe), so I'd be curious to see Fletch F. Fletch's dyno procedures. Hood closed without proper fans to simulate airflow, then of course you can expect a loss of power. However that's not realistic since if you're driving, there's usually air hitting the front of the car. Usually. Another member on F30Post who is also as methodical as olaosunt and has his 335i GT 8AT at the track often (and also owns a fast Mustang. Go figure.) gained a consistent and repeatable 0.1 and 1 MPH with just the addition of an aFe intake. Those are results in line with expectation...small, but results none the less. |
